Links in Outlook open in a sidebar in Edge
› Outlook › Links in Outlook open in a sidebar in Edge
Last reviewed on January 25, 2024     3 Comments
Applies to: Outlook on the web
A user had a question about Outlook and Edge:
"I use Microsoft 365 Personal on a Windows 11 PC. I have my Outlook.com account in Outlook. When I click on a link, it opens in Edge, with the message in a sidebar. How do I prevent the Edge sidebar from opening?"
Outlook message in sidebar
Go to edge://settings/sidebar, select Outlook and turn it off. This link should take you right to the Outlook setting:
edge://settings/sidebar/appSettings?hubApp=8682d0fa-50b3-4ece-aa5b-e0b33f9919e2
If you prefer navigating with menus:
  1. Click on the ellipsis or three-dots in the top-right corner of Edge to display the menu
  2. Choose Settings near the bottom of the menu
  3. Select Sidebar on the left. This page has the options for the right sidebar.
  4. Turn the right sidebar off you don't want to use it.
  5. To change which apps are shown on the sidebar, select App and notification settings
  6. Select Outlook from the list of apps and move the slider to the left to turn it off.
If Edge is not your default browser and classic Outlook is opening links in Edge instead of your preferred browser, change this in File > Options > Advanced. Near the top is Open hyperlinks from Outlook in. Select Default browser.
Open Outlook links in the default browser
Outlook emails open next to web links in Microsoft Edge
For administrators:
View emails and web links side-by-side with Outlook and Microsoft Edge - Outlook
Links in Outlook open in a sidebar in Edge was last modified: January 25th, 2024 by Diane Poremsky
  • Using Outlook’s ‘View it in a web browser’ with Edge
  • Outlook Links Won't Open In Windows 10
  • Outlook Error: Google Couldn't sign you in
  • Use FireFox as the Default Browser to Open Links
  1. Tom Holland says
    November 26, 2024 at 3:20 pm
    Finally found the way to stop having Edge open my email in the sidebar whenever I click on a link in Outlook! Thank you for sharing this.
  2. Phil Reinemann says
    November 20, 2024 at 7:16 pm
    Thank you, Diane. Your link above got me there!
    I cannot navigate there. Settings, "sidebar" is now (20241120, Version 130.0.2849.80) under "Copilot and sidebar", and when I navigate there the only apps and notifications is Copilot.
    I even searched Settings and it didn't find Outlook anywhere.
    In any case, this is for someone else who has the problem. I don't, even though all my Edge setting say to show it... except, I have sidebar turned off. I'm thinking that saved me.
      November 26, 2024 at 10:05 pm
      If you arent using an outlook.com address (or Microsoft 365 business), you shouldnt have a problem with it.
