Apply a View to a Folder using a Macro
› Developer › Apply a View to a Folder using a Macro
Last reviewed on December 4, 2018     17 Comments
In the thread at OL10 add views to 'my tasks'> navigation pane, users are disappointed the list of views was removed from the Navigation pane in Outlook 2010. While this macro won't add the views list back, it can make it easier to switch between your favorite views.
You'll need to create one macro and one button on the QAT or ribbon for each view you want to use, so it's not practical to use with a large number of views, but will be useful for a few of your most-used views.
If you add the Change View command to the QAT (Quick Access Toolbar) accessing the lesser-used views will be a couple of steps less than using the View ribbon.
Add Current view command to the QAT
To use the macro, press Alt+F11 to open the VBA editor. Right click on Project1 and choose Insert > Module. Paste the macro into the new module, one for each button you want to create.
Make the following changes to each macro:
  • Change the macro name (Sub GetAssignedView()) so it is unique for each macro. I use the view name in the macro name.
  • Change the name of the view in each macro (Set objView = objViews.Item("Assigned")) to match the name of the desired view.
  • While Set objViews = Application.ActiveExplorer.CurrentFolder.Views allows the macro to work with the folder you are viewing, the view needs to be available for the selected folder. If it's not listed in Change Views when you are viewing the folder, it's not available.
Don't forget to check your macro security settings!
After creating your macros:
  1. Go to File, Options, Customize Ribbon or Quick Access Toolbar
  2. In Choose commands from select Macros
  3. Select your macro and click Add
  4. Repeat for each macro
Note: If you are adding the views to a ribbon, you need to add a New Group to either your most used tab or add a New Tab to add the group to.
 Dim objViews As Views
 Dim objView As View
' Applies view to select folder
 'Get the view
'apply the view
 objView.Apply
Assign View to Folder and Subfolders
This macro applies the view to the selected folder and it's subfolders (but not nested subfolders), after first checking to see if the folder is the correct type (Contacts in this example.)
To use, select either the parent folder and run the macro.
Sub SetViewSubFolders()
 Dim CurrentFolder As Outlook.folder
 Dim i As Long
 Dim objView As View
 Set CurrentFolder = Application.ActiveExplorer.CurrentFolder
 Set objViews = CurrentFolder.Views
 'Get the view
'apply the view
 objView.Apply
For i = CurrentFolder.Folders.Count To 1 Step -1
 Set olNewFolder = CurrentFolder.Folders(i)
    For Each olNewFolder In CurrentFolder.Folders
' use if to apply to specific folder type
    If olNewFolder.DefaultItemType = olContactItem Then
        Debug.Print olNewFolder.Name
        Set objViews = olNewFolder.Views
        objView.Apply
Next i
Folder TypeDefaultItemType
CalendarolAppointmentItem
ContactsolContactItem
JournalolJournalItem
MailolMailItem
NotesolNoteItem
TasksolTaskItem
Apply a View to Nested Subfolders
This macro is based off of Michael Bauer's Folder: Expand all Folders macro and works on nested folders. The view is assigned in the LoopFolders macro.
Public Sub AssignViewtoFolders()
  Dim Ns As Outlook.NameSpace
  Dim Folders As Outlook.Folders
  Dim CurrF As Outlook.MAPIFolder
  Dim F As Outlook.MAPIFolder
  Dim ExpandDefaultStoreOnly As Boolean
  Set Ns = Application.GetNamespace("Mapi")
  Set CurrF = Application.ActiveExplorer.CurrentFolder
    Set F = Ns.GetDefaultFolder(olFolderInbox)
    Set F = F.Parent
    Set Folders = F.Folders
    LoopFolders Folders, True
  'DoEvents
  Set Application.ActiveExplorer.CurrentFolder = CurrF
Private Sub LoopFolders(Folders As Outlook.Folders, _
  ByVal bRecursive As Boolean _
  For Each F In Folders
    Set Application.ActiveExplorer.CurrentFolder = F
    If F.DefaultItemType = olContactItem Then
        Debug.Print F.Name
        Set objViews = F.Views
        objView.Apply
    If bRecursive Then
      If F.Folders.Count Then
        LoopFolders F.Folders, bRecursive
Use the Macro with Multiple Views
To use this code with multiple views, you can create a public string and use a macro to assign a View name to the string then call the assign view macro.
Like this:
Public strView As String
Sub NewView()
strView = "New View"
GetAssignedView
Sub View1()
strView = "View1"
GetAssignedView
 Dim objView As View
 'Get the view
 Set objView = objViews.Item(strView)
'apply the view
 objView.Apply
Open the Calendar pane to a specific Calendar and view
Use this code to open a specific calendar using a specific view every time you switch to the calendar module.
To use: paste into ThisOutlookSession, change the name of the view (it's case sensitive), then click in Application_Startup and click Run. Switch navigation pane folders to test.
Dim WithEvents objPane As NavigationPane
    Set objPane = Application.ActiveExplorer.NavigationPane
Private Sub objPane_ModuleSwitch(ByVal CurrentModule As NavigationModule)
  Dim objModule As CalendarModule
  Dim objGroup As NavigationGroup
  Dim objNavFolder As NavigationFolder
 If CurrentModule.NavigationModuleType = olModuleCalendar Then
     Set objModule = objPane.Modules.GetNavigationModule(olModuleCalendar)
     Set objGroup = objModule.NavigationGroups("My Calendars")
'' Change the 2 to start in a different folder
     Set objNavFolder = objGroup.NavigationFolders.Item(2)
     objNavFolder.IsSelected = True
 Dim objView As View
 Set objView = objViews.Item("New view 4")
 objView.Apply
  Set objNavFolder = Nothing
  Set objGroup = Nothing
  Set objModule = Nothing
View Object (Outlook)
Apply a View to a Folder using a Macro was last modified: December 4th, 2018 by Diane Poremsky
  • Use a macro to open the Calendar to appointment date
  • How to prevent changes to Outlook views
  • Select Multiple Calendars in Outlook
  • Apply custom views to all folders
  1. Marc Couture says
    December 27, 2025 at 11:03 am
    Thank you! This was what I looked for.
    However, I don't know if I understand well, it seems to me that in SetViewSubFolders(), the view is applied to each folder in CurrentFolder through both the For i and the For Each loops, so that with N folders, the code is applied N^2 times.
    So, instead of :
    I used :
    [code to apply the view]
      For Each olNewFolder In CurrentFolder.Folders(i)
    [code to assign the view]
    and it worked as intended (on only one level of sub-folders).
      April 24, 2026 at 10:07 pm
      Yeah, as written it applied to all nested subfolders.
  2. Peter says
    January 24, 2022 at 1:17 am
    Thanks! This works well.
    I now have a "WORKING" View showing only categorised emails. I can work in here easily without new emails popping in and breaking my concentration. I also have a "PROCESS NEW" View that shows uncategorised emails. Any new ones or ones that haven't been processed yet show up here.
  3. Robert F says
    June 30, 2021 at 6:04 am
    While it was helpful I found your article confusingly written.
    Example 1: Before you show any of the code for the macro you say, "Make the following changes to each macro" and then list changes that need to be made. Without having first seen the macro without the changes, there is no context.
    I find with instructions for anything it is far better to show what "X" is before telling the reader, "Change X as follows".
    Example 2: You write "Change the macro name (Sub GetAssignedView()) so it is unique for each macro. I use the view name in the macro name."
    What is the macro name? Is it the word "Sub" or "GetAssignedView" or ??? What text in that name am I supposed to change? Is the view name supposed to be inserted in the inner set of parentheses? Or should the text "GetAssignedView" be changed for the view name? Or ???
    Example 3: You write, "Change the name of the view in each macro (Set objView = objViews.Item("Assigned")) to match the name of the desired view."
    Again, what text in that parenthetical should be changed? Should I just change "Assigned" to be the name of the desired view or ???
  4. Witzker says
    March 25, 2018 at 12:08 pm
    Is it possible to read all exiting vievs for contacts, open a box with the list to click on the view to show it up?
      March 26, 2018 at 12:37 am
      To the best of my knowledge, no, not using VBA.
  5. Stu says
    February 6, 2016 at 9:54 am
    aloha Diane..
    i am using the vba code to expand all the mail folders. It works perfectly on my PC, but when i try to apply the same to another PC, it fails. i remarked the "on error resume next" and a pop up shows the operation failed. when i debug, it highlights the following line. Set Application.ActiveExplorer.CurrentFolder = F
    the only difference between the 2 PC's is one has a microsoft exchange account.
    what am i missing?
    and thank you for your time and sharing your insight....i really appreciate it!!!
    Sub ExpandFolders()
    ' On Error Resume Next
    ExpandDefaultStoreOnly = False
    If ExpandDefaultStoreOnly = True Then
    Set F = F.Parent
    LoopFolders Ns.Folders, True
    DoEvents
    DoEvents
    If bRecursive Then
  6. Brent says
    January 22, 2016 at 3:04 pm
    I am trying to come up with a Macro that specifically expands the In-Place Archive (Online Archive) and sub-folders on startup. Is there any code to accomplish this?
      January 22, 2016 at 10:14 pm
      See if the macro here works with the archive folders - https://www.vboffice.net/en/developers/expand-all-folders/
  7. phxphun says
    May 14, 2015 at 2:34 pm
    I tend to prefer keeping my hands on the keyboard, so Alt+F1 followed by Ctrl+F1 is probably going to work best for me... with about the same effort as the reading button. Thanks for the suggestion though!
  8. phxphun says
    May 12, 2015 at 6:38 pm
    I have two basic modes in which I use Outlook - managing email and reading email. I like to set my Outlook view to best accommodate each mode. When I'm reading emails the Ribbon and Navigation Pane should both be hidden and unhidden all other times.
    For quickly switching between my two views, I'd simply like to combine the functionality of Ctrl+F1 (Hide Ribbon) with the functionality of Alt+F1 (Hide Navigation Pane) into a single action.
    Can this be done through a short macro assigned to a hotkey combination?
      May 13, 2015 at 11:10 pm
      No, it can't be automated... however have you tried the reading buttons in the status bar? It might not get you the exact format you want (the ribbon isn't affected) but should come close. It's the buttons in the status bar on the far right, next to zoom.
  9. Phillip says
    December 13, 2014 at 8:19 pm
    I would like the macro to apply a specific view to all sub-folders in my inbox.
    thanks,
    Phil
      December 14, 2014 at 1:02 pm
      I updated the article to include a macro to apply a view to the selected folder and subfolders.
      https://www.slipstick.com/developer/apply-view-to-folder-using-vba/#subfolders
  10. Miguel Gamboa says
    October 24, 2013 at 8:50 am
    Yes, macros are enabled. Moreover, I put a breakpoint in function Application_Startup() and I see execution stop on debug. But the same behavior does not occur to objPane_ModuleSwitch(). When does outlook invoke the objPane_ModuleSwitch?
  11. Miguel Gamboa says
    October 24, 2013 at 5:00 am
    Nothing happens when I run the macro Application_Startup. I do not understand either how was supposed to be performed the objPane_ModuleSwitch, If it is not being invoked anywhere.
      October 24, 2013 at 6:30 am
      The view is applied when you switch modules. Application_Startup means it is enabled when Outlook starts, or you can kick start it by clicking in the app startup macro and clicking Run.
      Is macro security set to low? Check in Trust Center, Macro security.
  • Calendar Printing Tools
