Imported Addresses are Missing from Address Book
› Problems › Imported Addresses are Missing from Address Book
Last reviewed on December 5, 2024     1 Comment
Applies to: Outlook (classic), Windows
If you have Contacts in the Contacts folder but they are not accessible when you click on the To button, and they were not imported, see Outlook Contacts are missing when you click the To button for a common problem affecting Microsoft Outlook.
Addresses imported into the Contacts folder may not appear in the Address Book display and may not show all fields when Inserting Addresses in Microsoft Word Documents.
This happens because the e-mail address has not been "resolved," using the Check Names function. Resolved addressees are underlined in the E-mail fields in the Contacts record.
resolved contact address
Open each contact and click the Check Names button on the ribbon or click in the address field and press Ctrl+K should resolve the addresses or you can use a macro or PowerShell to automate the process.
As written, this macro runs on the default contacts folder in your Outlook profile.
Resolve Addresses using VBA
Public Sub ResolveEmailAddresses()
Dim objContact As Outlook.ContactItem
Dim objItems As Outlook.Items
Dim objContactsFolder As Outlook.MAPIFolder
Dim obj As Object
Dim olRecip As Recipient
'  On Error Resume Next
Set objOL = CreateObject("Outlook.Application")
Set objNS = objOL.GetNamespace("MAPI")
Set objContactsFolder = objNS.GetDefaultFolder(olFolderContacts)
Set objItems = objContactsFolder.Items
For Each obj In objItems
  If obj.Class = olContact Then
    Set objContact = obj
    With objContact
'Email1
    Set olRecip = objNS.CreateRecipient(.Email1Address)
      If olRecip.Resolve Then
        .Email1Address = olRecip
        Debug.Print olRecip
        MsgBox .Email1Address & " Not resolved"
'For Email2
    Set olRecip = objNS.CreateRecipient(.Email2Address)
        .Email2Address = olRecip
        Debug.Print olRecip
        MsgBox .Email2Address & " Not resolved"
'For Email3
    Set olRecip = objNS.CreateRecipient(.Email3Address)
        .Email3Address = olRecip
        Debug.Print olRecip
        MsgBox .Email3Address & " Not resolved"
Err.Clear
Set objOL = Nothing
Set objNS = Nothing
Set obj = Nothing
Set objContact = Nothing
Set objItems = Nothing
Set objContactsFolder = Nothing
PowerShell version to resolve addresses
This PowerShell works on the selected contacts folder.
Unlike VBA, PowerShell does not require security changes in Outlook.
Like VBA, it will not work with new Outlook.
clear
$olApp = New-Object -ComObject Outlook.Application
$olNS = $olApp.GetNamespace("MAPI")
$ContactsFolder = ($olApp.ActiveExplorer()).CurrentFolder
$Items = $ContactsFolder.Items
ForEach ($contact In $Items) {
# check for contact lists
if ( $contact.Class -eq 40 ) {
$objContact = $contact
#Email1
    $olRecip = $olNS.CreateRecipient($objContact.Email1Address)
      if ($olRecip){
      If ($olRecip.Resolve){
        $objContact.Email1Address -eq $olRecip
        } else  {
        write-host $objContact.Email1Address " Not Resolving"
        } else {
#For Email2
    $olRecip = $olNS.CreateRecipient($objContact.Email2Address)
    if ($olRecip -eq ""){
        $objContact.Emai2Address -eq $olRecip
        } else  {
        write-host $objContact.Email2Address " Not Resolving"
        } else {
#For Email3
    $olRecip = $olNS.CreateRecipient($objContact.Email3Address)
        $objContact.Email3Address -eq $olRecip
         } else  {
        write-host $objContact.Email3Address " Not Resolving"
        } else {
The macro on this page should be placed in a module.
Using PowerShell Scripts
PowerShell ise
Saving PowerShell Scripts
Imported Addresses are Missing from Address Book was last modified: December 5th, 2024 by Diane Poremsky
  • Update Contacts with a New Company Name and Email Address
  • Make the Address Book show only e-mail addresses, not fax numbers
  • Send an Email to All Addresses on a Contact
  • Create an Appointment at the Contact's Address
  1. David M Williams says
    April 7, 2020 at 11:23 am
    I was so excited to read your article and to resolve my Outlook address book. Unfortunately when I ran the macro for Outlook for O365, it didn't work. Do you have any suggestions?
    David
