Outlook's Rules and Alerts: Run a Script
› Outlook › Rules, Filters & Views › Outlook’s Rules and Alerts: Run a Script
Last reviewed on July 14, 2021     155 Comments
Using the "Rules and Alerts" option to "run a script", the list of scripts to run is empty. What makes a script appear in the list?
The argument must by type MailItem or MeetingItem for the subroutine to be available in the Rules Wizard in Outlook 2007. In Outlook 2010 and 2013 (and up), PostItem also works.
You need to avoid processing messages using more than one rule when you are using a run a script rule. Run a script rules should be placed at the top of the rules list and include the "stop processing" action.
All actions should be in the script - don't combine actions in the rule with the run a script rule. Include all of the actions you want to take on the items that meet the rule's conditions in the VBA procedure.
Something like this:
Public Sub ShowMessage(Item As Outlook.MailItem)
'code
Using VBA Editor
Open Outlook's VBA editor by pressing Alt+F11 and expand Microsoft Office Outlook Objects then double click on ThisOutlookSession.
Script in the VBA Editor
You'll type or paste the code into the module, then create the rule with the 'run script' Action and select this script
Create a Run a Script Rule
After the script is written, you need to add it to a rule.
If you have Outlook 2016 and run a script action is missing, see "Run-a-Script Rules Missing in Outlook" for the fix.
  1. Open Rules Wizard. In Outlook 2010 and 2013, it's on Outlook's Home ribbon,
    Rules > Manage Rules & Alerts. Look on the Tools menu in older versions.
    Open Rules Wizard
  2. Click New Rule.
  3. Select Apply Rule on messages I receive and click Next.
  4. Select your conditions and click Next.
  5. Select Run a script action (near the bottom).
    The finished run a script rule
  6. Click on a script.
    Select the script
  7. Select your script, click OK.
  8. Click Next then finish the rule.
For best results, all actions should be in the script.
  • Filter mail when you are not the only recipient
  • Process Mail that was Auto Forwarded by a Rule
  • Run a Script: Send Autoreply with Date
  • Filter messages containing spam or other words
  • Creating an AND rule in Outlook Rules
  • Search PDF Attachments and Forward
  • Run-a-Script Rules Missing in Outlook
  • How to Process Mail After Business Hours
  • Create Appointment From Email Automatically
  • Talking Reminders
  • Receive a Reminder When a Message Doesn't Arrive?
  • Delegates, Meeting Requests, and Rules
  • Run Rules Now using a Macro
  • Automatically Add a Category to Accepted Meetings
  • Save and Rename Outlook Email Attachments
  • Use a Rule to delete older messages as new ones arrive
  • Outlook AutoReplies: One Script, Many Responses
  • Use VBA to move messages with attachments
  • Run a script rule: Reply to a message
  • Sort messages by Sender domain
  • Use a Macro to Copy Data in an Email to Excel
Additional Information:
  • How to create a script for the Rules Wizard in Outlook (MSKB)
  • Retrieving Internet Headers Using VBA in Outlook 2007/2010
Outlook's Rules and Alerts: Run a Script was last modified: July 14th, 2021 by Diane Poremsky
  • out of office rules
    Show a Desktop Alert when Rules move messages
  • A simple run a rule script marks Outlook messages read when the messag
    Use a run a script rule to mark messages read
Subscribe
Notify of
155 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Mario
July 31, 2023 10:33 am
Hello Diane, greetings from Brazil!
We have a doubt in outlook and needs your help:
In my company , we need automate some tasks in Outlook. For example, when we apply some tag in email, we want these email tagged be moved to folder automatically.
I know that outlook web and outlook desktop have rules that i can automate many tasks, like move email to folder from tag, sender, subject, etc, that rules works when emails are sended and received.
I found these manual task in Outlook desktop that move email to folder after i tagged that email manually. In these task, we need click on button "Run Rules Now" manually:
https://filestore.community.support.microsoft.com/api/images/d58b5400-c18c-426d-84fa-0a934716c28e?upload=true
https://filestore.community.support.microsoft.com/api/images/b7a0c5d8-e7e9-41f6-a131-b074cd359483?upload=true
however, in my company we need automate tasks after email arrive in inbox.
This is my doubt: is possible create automatic task for when i apply tag in email received, these email be move to folder automatically? there are script or macro related?
Thanks a lot!!
Mario
0
0
mishu36
August 10, 2021 6:41 am
hi, i am trying to use "run a script" but in my "Outlook 2019", but that option is missing.
i tried to use the registry hack of "EnableUnsafeClientMailRules" but it also not working. i want to use a way around but for that i need to execute VBA Macro before outlook rules can be run. Can you please guide me on this.
here is my action plan sequence:
  1. run vba code
  2. run outlook rules
0
0
Author
Reply to  mishu36
November 2, 2021 4:12 pm
Did you restart Outlook after setting the key?
If you ended the registry yourself, try using the exported key from this website.
0
0
Rakesh Kumar
January 31, 2021 12:56 am
Hello Brother,
My script is not showing in Run a Script.
2
0
Author
Reply to  Rakesh Kumar
February 2, 2021 12:52 am
Did you put it in ThisOutlookSession? Try putting the script in a new module instead.
The macro 'name' needs to be in this format:
0
0
josue aguirre
August 4, 2020 1:24 pm
Hello, can you please help me with a problem?
I have a rule in Outlook that runs a script, but it suddenly doesn't work anymore. And when I want to change this rule or create a new one I get a message:
"This rule will only be executed when you check your email ..."
2
0
swinn
June 11, 2020 11:44 am
Discovered the hard way that if the Sub you are trying to invoke with an Outlook Rule has an Optional parameter, the Rule Editor won't display it for you to select.
0
0
egenc
March 27, 2020 2:30 am
I have added script but can't see it in rule page.
0
0
Author
Reply to  egenc
June 1, 2020 11:14 pm
The script needs to be named in this format, preferably in a module (not thisoutlooksession) - you don't need to call the mail object Item, but you do need it in the ().
1
-1
Isaac
Reply to  Diane Poremsky
July 29, 2020 5:45 pm
It's exactly the opposite. It MUST be in the thisoutlooksession, and CAN'T be in a regular module.
1
0
Author
Reply to  Isaac
July 29, 2020 9:15 pm
No, it will work in either, but it is recommended to put it in a module. I've had instances where it was not 'seen' if in thisoutlooksession, but none where it was not seen in a module.
0
0
ardi
December 16, 2019 2:43 am
how to use in outlook 2016
0
0
Michael
November 21, 2019 3:53 pm
I'm trying to use the "Send a message to someone when a reminder fires" macro from this page: https://www.slipstick.com/developer/send-email-outlook-reminders-fires/, but it seems like the parameters of that code aren't compatible with what's required for the Rules Wizard to recognize it as a script.
0
0
Latest EMO: Vol. 31 Issue 3
wpDiscuz
Never see this message again.
Move Comment
