How to Create Messages Using Data in an Excel File
› Developer › Code Samples › How to Create Messages Using Data in an Excel File
Last reviewed on December 26, 2014     4 Comments
This macro assumes an Excel file (CSV, XLS*) is structured in the following format, although you can easily change the code to fit your format. The subject is the same for all messages, however, it could come from the spreadsheet instead.
excel sheet
Column A: Email address for the To field
Column B: Email address for the CC field (if used)
Column c: Email address for the BCC field (if used)
Column D: First line of body
Column E: Second line in body
Create message from excel workbook
To use this macro, prepare and save an Excel file then paste the code in Outlook and run it. The macro will ask you to select the Excel file then create the messages.
Sub CreateMeetingsfromCSV()
    Dim xlApp As Object 'Excel.Application
    Dim xlWkb As Object ' As Workbook
    Dim xlSht As Object ' As Worksheet
    Dim rng As Object 'Range
    Dim objMsg As MailItem
    'Set xlApp = New Excel.Application
    strFilepath = xlApp.GetOpenFilename
    If strFilepath = False Then
        xlApp.Quit
        Set xlApp = Nothing
    Set xlWkb = xlApp.Workbooks.Open(strFilepath)
    Set xlSht = xlWkb.Worksheets(1)
    Dim iRow As Integer
    Dim iCol As Integer
    iRow = 2
    iCol = 1
    While xlSht.Cells(iRow, 1) <> ""
 With objMsg
  .To = xlSht.Cells(iRow, 1)
  .CC= xlSht.Cells(iRow, 2)
  .BCC = xlSht.Cells(iRow, 3)
  .Subject = "This is the subject"
' send plain text message, use olFormatHTML for formatted mail
   .BodyFormat = olFormatPlain
' can use 2 or more cells to create the body
' use .HTMLBody if you want to format words
  .Body = xlSht.Cells(iRow, 4) & vbCRLF & xlSht.Cells(iRow, 5)
  .Importance = olImportanceHigh
  .Display ' .Send to automatically send it
        iRow = iRow + 1
    Wend
    xlWkb.Close
    xlApp.Quit
    Set xlWkb = Nothing
    Set xlApp = Nothing
Formatting Text
You can format text within the messages by using HTML format and HTML tags. The tags can go with the spreadsheet text:
This is the order number: 12345
Or, to format the text in one cell or the entire message, wrap the text in HTML tags, as shown in the example below.
  .BodyFormat = olFormatHTML
  .HTMLBody = xlSht.Cells(iRow, 4) & vbCRLF & "" & xlSht.Cells(iRow, 5) & ""
How to use macros
How to Create Messages Using Data in an Excel File was last modified: December 26th, 2014 by Diane Poremsky
  • Import meetings from a CSV or XLSX file
  • Create Outlook Folders from a List of Folder Names
  • Copy data from Outlook email tables to Excel
  • Send Email to Addresses in an Excel Workbook
  1. Kevin says
    January 5, 2015 at 7:48 am
    Why can't the subject line come from the spreadsheet as well?
      January 5, 2015 at 8:30 am
      It can - the person who had the question that triggered the article was doing a mail merge and needed one subject. Reference the cell in the same way it's used for the other fields - if you want something like "order #1234 was shipped" you can do it like this:
      .subject = "Order #" & xlSht.Cells(iRow, 4) & " was shipped". You can put the body together in the same manner - use vbcrlf for new lines.
  2. Michael says
    December 25, 2014 at 10:25 am
    Hi there :)
    I have a small question: Is it possible to not choose .BodyFormat = olFormatPlain and instead send an e-mail using Rich text?
    I was wondering if it was possible to change the font size of the body of the e-mail.
    Thank you for the easy to understand e-mail.
      December 26, 2014 at 11:13 am
      You don't want to use rich text (RTF) with non-Outlook (they'll get plain text) or internet email addresses (they might get html, they might get plain text). You would use HTML format, and it should be set in the email, not converted from RTF to HTML by outlook.
      You can change the font in the message body if using HTML. (the format should go before the body line too) It's easiest if you are changing the entire message, not just a section. Use olformathtml and set the font size using word vba commands - a sample is here: https://www.slipstick.com/developer/word-macro-apply-formatting-outlook-email/ It's also possible to use HTML tags when constructing the body - either use html tags around words in the spreadsheet (Column d: This is the # number: <b>12345</b>) or in the code (sample below) - and use HTMLBody
      .htmlBody = xlSht.Cells(iRow, 4) & vbCRLF & "<em>" & xlSht.Cells(iRow, 5) & "</em>"
      Sample of formatted text
Latest EMO: Vol. 31 Issue 13
