Sort messages by Sender domain
› Outlook › Email › Sort messages by Sender domain
Last reviewed on October 8, 2018     28 Comments
A user wanted to know how to sort email messages by domain. Although you can filter by domain simply by typing the domain name in the address field, you can't sort as easily.
You can create a custom Formula field using this formula: right([SearchFromEmail],len([SearchFromEmail])-InStr(1,[SearchFromEmail],"@"))
Use a formula to get the domain name
Unfortunately, you can't sort by formula fields. However, custom Text fields are sortable and you can use a macro to add the domain to the custom field.
How to display the sender's email address in Outlook to add the sender's email address field to the view.
To use the first macro, select the messages then run the macro. To add the domain field to messages as they arrive, you'll need to use the run a script rule below.
Macro for selected messages
Public Sub SetDomain()
    ' From http://slipstick.me/1
    Dim Selection As Selection
    Dim obj As Object
    Dim strDomain
    For Each obj In Selection
         Set objMail = obj
           strDomain = Right(objMail.SenderEmailAddress, Len(objMail.SenderEmailAddress) - InStr(objMail.SenderEmailAddress, "@"))
         Set objProp = objMail.UserProperties.Add("Domain", olText, True)
         objProp.Value = strDomain
        objMail.Save
        Err.Clear
    Set currentExplorer = Nothing
    Set obj = Nothing
    Set Selection = Nothing
If you use Exchange server, the field will contain the Exchange x.500 address for mail from Internal senders. The easiest fix is to use an if statement to look for an @ sign. No @ sign means it's internal email. You can then enter your domain for these senders or use their alias.
         Set objMail = obj
    If InStr(1, objMail.SenderEmailAddress, "@") > 0 Then
        ' strDomain = "yourdomain.com"
        ' use this for the alias - you may need to use /cn in on-prem
         strDomain = Right(objMail.SenderEmailAddress, Len(objMail.SenderEmailAddress) - InStrRev(objMail.SenderEmailAddress, "-"))
Create the custom field and add it to your view
To add the custom field to the view follow these steps:
Add a custom Domain field to the view
  1. Close or reduce the size of the reading pane so the From, Subject, Received date and other fields are on one line
  2. Right click on the row of field names and then choose Field Chooser from the menu
  3. Click New and type Domain in the Name field
  4. If User-defined field in [folder] is not visible, select it, then drag the newly created Domain field to the row of field names
Click on the Domain name to sort..
Sort by the domain name
Run a script rule
Use the following macro in a run a script rule. If you need instructions, see Outlook's Rules and Alerts: Run a Script.
Public Sub SetDomainScript(Item As Outlook.MailItem)
    ' Fromhttp://slipstick.me/1
    Dim strDomain
       strDomain = Right(objMail.SenderEmailAddress, Len(objMail.SenderEmailAddress) - InStr(1, objMail.SenderEmailAddress, "@"))
         Set objProp = Item.UserProperties.Add("Domain", olText, True)
        Item.Save
Add the Sent To domain
This macro gets the first email address a message is sent to and adds it to the Domain field. You could loop through the entire recipient list and get all addresses or domains, but the list is a simple text list and sorts by the first domain, making it less useful.
This macro works on both incoming messages and messages in your sent folder.
Public Sub SetToDomain()
    Dim obj As Object
    Dim strDomain
 Dim recips As Outlook.Recipients
 Dim recip As Outlook.Recipient
 Dim pa As Outlook.propertyAccessor
 Dim Address As String
 Dim lLen
 Const PR_SMTP_ADDRESS As String = "http://schemas.microsoft.com/mapi/proptag/0x39FE001E"
         Set objMail = obj
' This gets the first recipient's address
 Set recips = objMail.Recipients
 Set recip = recips.Item(1)
 Set pa = recip.propertyAccessor
 Address = LCase(pa.GetProperty(PR_SMTP_ADDRESS))
 lLen = Len(Address) - InStrRev(Address, "@")
         strDomain = Right(Address, lLen)
        objMail.Save
        Err.Clear
    Set obj = Nothing
Create other fields
You can customize the macro to work with other fields. In this example, I'm adding a text field containing the received date formatted in Month day format. Don't forget to use a unique name for the field!
Tip: if you want to sort by a date field, use "yyyy mm dd" for the date format, use olDateTime instead of oltext.
strDomain = Format(objMail.ReceivedTime, "mm/dd/yyyy")
Set objProp = objMail.UserProperties.Add("MyDate", olDateTime, True)
Public Sub SetDate()
    Dim obj As Object
    Dim strDomain
    Dim objMail As MailItem
         Set objMail = obj
   ' make changes here
      strDomain = Format(objMail.ReceivedTime, "MMM dd")
         Set objProp = objMail.UserProperties.Add("MyDate", olText, True)
         objProp.value = strDomain
        objMail.Save
        Err.Clear
    Set obj = Nothing
To use the macros with other Outlook item types, you only need to change the item type in the Dim statements:
Dim objMail As TaskItem
And the field:
strDomain = Format(objMail.CreationTime, "MMM dd yyyy")
And, of course, you might want to change the field name and type:
Set objProp = objMail.UserProperties.Add("ThisField", olDateTime, True)
Yes, it would be less confusing to use a generic object name, like objItem, but as long as the field is supported by the declared object, it will work.
How to use macros
Sort messages by Sender domain was last modified: October 8th, 2018 by Diane Poremsky
  • Display the Recipient Email Address in the Sent Items Folder
  • Create a Custom Numbering Field for Outlook messages
  • How to sort the Outlook Calendar by Birthday
  • This macro demonstrates how to pick up the sender's address and use it
    New Message From Sender
Subscribe
Notify of
28 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
erkan
March 7, 2020 12:01 pm
is there any way to make this macro stay there forever and set a shortcut or button?
So if i click that buttom, it should sort according to domain?
0
0
Rajiv
June 10, 2018 3:58 am
Dear Diane, I added a New Column, named DOMAIN, selected all the messages in my Inbox, around 10000, and ran the macro. First it took ages to populate the Domain field values. Second upon clicking Sort, it simply was not doing it, descending or ascending. Then I noticed, it does some sort of sorting, but could understand it is an extremely slow process. The same process I tried in another mail folder, with 250 messsages, and I was able to sort and group by Domain values. Kindly help me implement the same process for my Inbox, as I really want to clear all the Junk/Useless mails, which are from around 3000 senders, but if I can group them by Domain, it would be a few hundred.
Sorting the messages according to the number of messages based on Domain values, instead of alphabetic sequence, would be the next step, but this can be a secondary goal. Thanks for your kind help.
0
0
Author
Reply to  Rajiv
November 1, 2018 12:37 am
Yeah, its definitely a slow macro - it needs to touch every message. I don't believe t can be speeded up. Sorry. (Sorry I missed this earlier).
1
0
Enrique Nicolas
June 26, 2017 12:31 pm
Hey, i share the method to folder sent.
For Each aObj In Application.ActiveExplorer.Selection
Set oMail = aObj
Set recips = oMail.Recipients
sTmp = recips.Item(1).Address
If InStr(1, sTmp, "@") > 0 Then
sDomain = Right(sTmp, Len(sTmp) - InStr(sTmp, "@"))
If InStr(1, sTmp, "/o=") > 0 Then
sDomain = "att.com"
nPos = InStr(1, sTmp, "=")
nNext = InStr(nPos + 1, sTmp, "/")
nLen = nNext - nPos
sDomain = Mid(sTmp, nPos + 1, nLen - 1)
sDomain = Right(sTmp, Len(sTmp) - InStrRev(sTmp, "-"))
' sDomain = Right(oMail.SenderEmailAddress, Len(oMail.SenderEmailAddress) - InStr(1, oMail.SenderEmailAddress, "@"))
Set oProp = oMail.UserProperties.Add("NewDomain", olText, True)
oProp.Value = sDomain
oMail.Save
Err.Clear
0
Steve
May 10, 2017 7:03 am
Great tips.
Also see my column formula:
IIf(InStr([SearchFromEmail], "@") = 0, "", Mid([SearchFromEmail], InStr([SearchFromEmail], "@") + 1))
And info here
http://stackoverflow.com/questions/43849213/can-i-add-a-custom-email-domain-column-in-outlook/43889643#43889643
0
0
Tony
May 27, 2016 12:14 pm
How to remove the field andits contents if the Macro did not work correctly? I run the AddDomain Macro and it worked on the emails coming from outside my company but for the emails that come from inside my company the field added something like this: "/o=company/ou=exchange admin...". I will like to undo what I did until I figure out how to adjust the script. Any ideas?
0
0
Author
Reply to  Tony
August 25, 2016 10:54 am
That is normal. On other pages i have examples using left/right functions that get just the alias from the exchange x500 address or you can use an if statement something like
' to get the exchange alias in office 365 exchange online
' strDomain = Right(objMail.SenderEmailAddress, Len(objMail.SenderEmailAddress) - InStrRev(objMail.SenderEmailAddress, "-"))
' or in on-prem
' strDomain = Right(objMail.SenderEmailAddress, Len(objMail.SenderEmailAddress) - InStrRev(objMail.SenderEmailAddress, "/cn"))
0
0
Author
Reply to  Diane Poremsky
August 25, 2016 11:17 am
BTW, just changing this line should erase the value from the field -
objProp.Value = "" (it might only work if you do it immediately and won't work if you use the formula method to set the field - you'll need to change the formula or delete the field)
0
0
Liora
March 28, 2016 3:19 am
I have to use the above script on inbox , and use the proprties:
PropTag=PidTagSenderSmtpAddress_W
NmidInteger=0x5D01
In the script there is an object relaited recipient, I need to relait to sender
Thank
0
0
Badan
November 12, 2015 4:30 am
Thanks, Diane, this is very useful. However, for some reason when I run the script rule this line is not able to extract the domain name:
It gives nothing. I added on Error resume next and changed objMail with Item but still this line is not working. What could be the issue?
0
0
jeanphi
October 20, 2015 8:43 am
I am again. Here's the code. I'm in my .txt file the number of items per sender. But not write in column D (created previously) What is the solution? PS I am not a developer, I try to learn. ----------- ub CombienMailsDate() Dim objOutlook As Object, objnSpace As Object, objFolder As MAPIFolder Dim Sender As Outlook.AddressEntry Dim mail As String Dim myItems As Outlook.Items Dim dict As Object Dim msg As String Dim aObj As Object Dim oProp As Outlook.UserProperty Set objOutlook = CreateObject("Outlook.Application") Set objnSpace = objOutlook.GetNamespace("MAPI") On Error Resume Next Set objFolder = ActiveExplorer.CurrentFolder If Err.Number 0 Then Err.Clear MsgBox "No such folder." Exit Sub End If Set dict = CreateObject("Scripting.Dictionary") Set myItems = objFolder.Items myItems.SetColumns ("SenderEmailAddress") For Each myItem In myItems mail = myItem.SenderEmailAddress If Not dict.Exists(mail) Then End If dict(mail) = CLng(dict(mail)) + 1 Next myItem On Error Resume Next ' Output counts per sender: msg = "" For Each o In dict.Keys msg = msg & o & ": " & dict(o) & " items" & vbCrLf On Error Resume Next For Each aObj In Application.ActiveExplorer.Selection Set oMail = aObj If o = myItem.SenderEmailAddress Then Set oMail = aObj Set oProp = oMail.UserProperties.Add("D", olNumber, True)… Read more »
0
0
Latest EMO: Vol. 30 Issue 36
  • Syncing Outlook with an Android smartphone
wpDiscuz
Never see this message again.
Move Comment
