New Message From Sender
› Developer › New Message From Sender
Last reviewed on July 2, 2012     6 Comments
This macro demonstrates how to pick up the sender's address and use it for a new message. This was originally put together for a user who wanted to send email using the address of one of several shared mailbox automatically. Beyond using it for redirecting mail, it's more of a concept macro, showing how to grab the sender's address from an email email. Otherwise, it's probably not very useful to most people.
Public Sub SendFromAddressOfCurrentEmail()
    Dim Selection As Selection
    Dim currentItem As Object
    Dim currentMail As MailItem
    Dim smtpAddress As String
     For Each currentItem In Selection
        If currentItem.Class = olMail Then
            Set currentMail = currentItem
            smtpAddress = currentMail.SenderEmailAddress
Dim oMail As Outlook.MailItem
' Send new message
' Set oMail = Application.CreateItem(olMailItem)
'Send reply
Set oMail = Application.ActiveExplorer.Selection(1).Reply
oMail.SentOnBehalfOfName = smtpAddress
      oMail.Display
To send a message using the To address, change smtpAddress = currentMail.SenderEmailAddress to smtpAddress = currentMail.To
New Message From Sender was last modified: July 2nd, 2012 by Diane Poremsky
  • Macro to Resend Sent Message
  • Use a macro to Reply with boilerplate text
  • Choose the account to send a reply from
  • Mail merge and Send from a Distribution Group
  1. Dieter Leyendecker says
    September 12, 2013 at 2:19 am
    Thanks Diane, then Dimming was the problem. Changing item to object is the solution. And after changing the loop I could read all mails in a specific folder. Now my challenge is to find a solution to read all folders as I don't know how many levels of folders I need to work through. But I will find a solution, I'm sure. Many many thanks for your excellent and quick support.
      September 12, 2013 at 6:07 am
      i have a macro here somewhere that walks all folders. Here it is: Save attachments - it will give you an idea of how you need to walk the folders to hit each one.
  2. Dieter Leyendecker says
    September 10, 2013 at 3:04 am
    Hi Diane, sorry for the late reply. Error message while reading PST items is "Type mismatch" (see picture below). it reads 45 of 263 correctly. So I expect not a problem in read loop. The skipped messages look quite normal. It reads messages with attachments and long one as well as short ones. Very strange. any other idea?
    Routine looks like this:
    Public Sub CopyItems(fPstReadFolder, fDestFolder)
    Dim olItems As Outlook.Items
    Dim olItem As Outlook.MailItem
    Dim olFolder As Outlook.Folder
    Dim fPstFolder As Outlook.Folder
    Dim fPstSubFolder As Outlook.Folder
    Dim vFold As Variant
    Set olItems = fPstReadFolder.Items
    noOfMails = 0
    ' On Error Resume Next
    For Each olItem In olItems
    ' Move Mail to Folder
    olItem.Move fDestFolder
    noOfMails = noOfMails + 1
    Next olItem
      September 10, 2013 at 9:03 am
      any meeting requests or non-mail items? This: For Each olItem In olItems is asking "for each mailitem in the folder..." Dimming olItem As object might work (will move everything) or use an if -
      if olitem = olmailitem then
      'move
      else
      end if
      oh, i see the on error resume next is commented out. Does it work if you remove the '?
  3. Dieter Leyendecker says
    September 4, 2013 at 1:40 am
    Hi Diane, I think you are the best address for my issue. I try to copy/move all eMails from a PST file into my mailbox by creating a new folder in my mailbox with similar name like the PST file. I'm facing 2 problems now:
    1. VBA is not reading all items from the PST file
    2. It only works with Item.Move - Item.Copy shows error message
    any idea? so my code works, but not completely as expected.
    Hope you find some time to answer
    Best regards from Switzerland
    Dieter
      September 4, 2013 at 8:35 pm
      What is the error message?
      Is there anything similar with the items the macro skips? If its moving every other messages, its how you are looping - you need to step backwards.
