Processing Incoming E-mails with Macros
› Developer › Processing Incoming E-mails with Macros
Last reviewed on November 4, 2021     25 Comments
The Rules Wizard is great for a lot of things when automatically processing incoming e-mails. However, when there's that one certain thing that you can't do with it, you can always be the Wizard yourself and write your own rules with VBA. However, one of the greatest challenges for developers programming with Outlook is learning how to effectively hook into application events. While it is relatively easy to gain access to objects on the fly, it is not entirely obvious where, when or how these objects should be managed. If Outlook automation was anything like most object models, it would be very straightforward.
Imagine this "fantasy" code:
Sub WorkWithNewMail()
Dim objAllNewMail As Outlook.Items
Dim objMyEmail As Outlook.MailItem
Set objOutlook = New Outlook.Application
Set objAllNewMail = objOutlook.NewMail
For Each objMyEmail In objAllNewMail
'Do something with every e-mail received
Wouldn't this make things easier! Unfortunately, there is no magical NewMail collection. You have to build it, and hook into it at the proper time. What is essential is instantiating the necessary objects when Outlook starts. To begin, open the Visual Basic Editor (ALT+F11) and open the ThisOutlookSession module from the Project Explorer window. The first code that we need to add are module level variables that we'll declare in the general declarations section of the module at the top:
Option Explicit
Private objNS As Outlook.NameSpace
Private WithEvents objNewMailItems As Outlook.Items
The most important object in this example is objNewMailItems, as we'll soon see. The "WithEvents" statement means we are declaring this object in a way that will allow us to access not only the properties of that object, but also the events that the object exposes.
Now, we have to hook these variables up. The ThisOutlookSession module is special compared to the regular modules that you usually insert into a VBA project in Outlook - it has a "built-in" Application object variable already declared. This way you don't have to add a "Private WithEvents objApp As Outlook.Application" line or something similar in the general declarations section of the module. With that in mind, add this procedure:
Dim objMyInbox As Outlook.MAPIFolder
Set objMyInbox = objNS.GetDefaultFolder(olFolderInbox)
Set objNewMailItems = objMyInbox.Items
Set objMyInbox = Nothing
This is essentially where it all begins. As the name of the Application_Startup event indicates, this loads when Outlook launches and is essential to ensure that we gain access to e-mails delivered to the Inbox. This is done by hooking up an event aware procedure tied to the Items collection that we retrieve from the MAPIFolder object we set from the Inbox folder. The event where all the processing on incoming e-mails occurs will be here:
Private Sub objNewMailItems_ItemAdd(ByVal Item As Object)
'Ensure we are only working with e-mail items
If Item.Class <> olMail Then Exit Sub
Debug.Print "Message subject: " & Item.Subject
Debug.Print "Message sender: " & Item.SenderName &" (" & Item.SenderEmailAddress & ")";
And that's really all there is to it! The Item object is checked to ensure that it is a MailItem object before we work with it any further.
Once it is validated, we can work with all the properties and methods of the MailItem object to do whatever we want with it. Just printing out the subject line and sender information to the Debug window like the example above is pretty boring, but there are all kinds of possibilities using code to work with e-mails in ways that the Rules Wizard can't handle:
- write e-mail info to a database
- automatically save attachments to the file system
- lookup the sender's Contact item and start a Word mail merge using their mailing address
- parse the message body for line items to be added to a spreadsheet
Those are just a few examples, but as long as whatever you want to do has an Object Model it can be done - you don't just have to automate Outlook or other Office applications.
There are a few caveats to mention though. If a large number of items are added to a folder at that same time, the ItemAdd event may not fire.
However, you can get around this if you use Outlook 2003 or newer. The NewMailEx event provides a list of all the unique EntryID values for e-mails that were delivered during the last Send/Receive cycle. These values can be used to retrieve each e-mail individually as in the ItemAdd event by using the NameSpace GetItemFromID method.
Private Sub Application_NewMailEx(ByVal EntryIDCollection As
String)
Dim objEmail As Outlook.MailItem
Dim strIDs() As String
Dim intX As Integer
strIDs = Split(EntryIDCollection, ",")
For intX = 0 To UBound(strIDs)
Set objEmail = objNS.GetItemFromID(strIDs(intX))
Debug.Print "Message subject: " & objEmail.Subject
Debug.Print "Message sender:" & objEmail.SenderName &" (" & objEmail.SenderEmailAddress & ")"
Set objEmail = Nothing
Note: The Outlook 2003 VBA help file seems to indicate that NewMailEx only works with Exchange Server mailboxes. This is not true - try it and see with POP or IMAP accounts.
Finally, don't expect this code to process e-mails the way server-side based rules do. Outlook of course has to be running for your code rules to work. For requirements where e-mail needs to be processed 24/7, see the Exchange SDK for information on building Event Sinks that run on the server.
To take this example further, there may be situations where you need to interact with e-mails that are opened rather than received. This involves a different approach and is explained in this article: Getting a Handle on Your E-mails with VBA
How to Use VBA
Copy and paste the code from this page into your ThisOutlookSession project. To do this, click within the code, Select All using Ctrl+A, Ctrl+C to copy.
In Outlook, press Alt+F11 to open the VBA editor and expand Microsoft Outlook Objects then double click on ThisOutlookSession to open it in the editing pane and Ctrl+P to paste the code.
For more detailed instructions and screenshots, see How to use Outlook's VBA Editor
Processing Incoming E-mails with Macros was last modified: November 4th, 2021 by Eric Legault
  • How to use an ItemAdd Macro
  • To automatically add recipients to Contacts in Outlook using VBA
  • Get the mailbox name from properties
    Process items in a shared mailbox
About Eric Legault
An Outlook developer MVP since 2003, Eric has completed several dozen projects using the Outlook/Exchange/SharePoint platforms, from COM Add-Ins to custom Forms, desktop applications and Windows Service applications. When not working, Eric keeps busy building relationships with technical communities via social media and by contributing to online support forums, writing technical articles and editing technical books and speaking at conferences around the world on Outlook and Office development. Eric Legault+
Subscribe
Notify of
25 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
AmronN
May 17, 2023 12:35 pm
I have multiple email accounts/mailboxes set up in my Outlook. (my personal company account, a mailbox for windows problems, a mailbox for unix problems, and another mailbox for network problems), and I want to see if there is any way to determine the execution of one or the other code in a macro , depending on which account/mailbox the emails arrive. That is to say, if an email arrives in the Windows mailbox, a certain code of the macro is executed, if it arrives in the Linux mailbox, it executes another code within the macro and so on, executes one or the other code within a macro depending on a Which mailbox/account (FMB) does the mail arrive? Is it possible? Any ideas?... Thanks
0
0
Vic
May 7, 2022 12:38 pm
Thanks a lot for the instructional.
I am trying to figure out a way to trigger different modules based on different subject lines. The goal is to forward email without an FW in the subject line and a 'forwarding' header in the body of the mail. For that, I use the outlook rule which runs a script
Sub SendNew(Item As Outlook.MailItem)
Dim objMsg As MailItem
objMsg.Body = Item.Body
objMsg.Subject = "FW: " & Item.Subject
objMsg.Recipients.Add "alias@domain.com"
objMsg.Send
works great. problem is, I want for different names in the subject line to trigger different modules which in return will send to different email addresses. It appears that VBA accepts only one project and I cannot figure out a way to select various modules in 'rules' it offers only 1 script.
0
0
Wil Heeren
October 21, 2020 12:53 pm
Hello
Nice macro but here is what i would like to do.
I have several email accounts but for 1 particular account i would like to when a new email comes into that account.
1) open the email
2) reply to
3) insert an oft
4) send
5) close the email
If this is at all possible ?
0
0
Saby
November 9, 2017 1:42 am
Hi ,
It is really working great .The only drawback I see is to use this code we have to keep outlook opened for all the time .Is there any way we can get the mails even if the Outlook is closed?
Please provide me solutions .
Saby
0
0
Admin
Reply to  Saby
November 21, 2017 12:53 am
Sorry, no. Outlook needs to be open to use a macro. The only option when outlook is closed is server-side rules.
0
0
Peter Braun
January 14, 2017 3:23 pm
Hi, Thank you very much for posting. I thought I had left this comment yesterday but it seems to have disappeared now. Did I do something wrong? Maybe I just didn’t post it correctly… I’m trying to run a version of your code to watch a particular folder for new items. The problem is that when I try to set my WithEvents variable, it seems to disappear after the Application_Startup sub finishes: it’s empty in in my watch window when I run other subs and the ItemAdd sub I built on it doesn’t fire when an item is added. I know I’ve assigned my variable to the right folder because the correct subject prints from the Debug.Print clntFldrItms.item(1).Subject line. I also know that the Application_Startup sub runs on startup because every time I open Outlook, the VBA editor opens and code has stopped at the Stop command. I’m using Outlook 2016 with an IMAP email address (gmail). All code is in ThisOutlookSession. Code below. Any help you can provide would be really appreciated. Thank you! Peter Option Explicit Public WithEvents clntFldrItms As Outlook.Items Private Sub Application_Startup() Dim clntFldr As MAPIFolder Set clntFldr = Application.Session.GetDefaultFolder(olFolderSentMail).Folders("Client Emails") Set clntFldrItms = clntFldr.Items Debug.Print… Read more »
0
0
Peter Braun
January 13, 2017 11:32 am
Hi, I'm having a problem with trying to use this code because my Outlook.Items variable disappears after the Application_Startup sub finishes. I've put all code in ThisOutlookSession, see below for what it is. I know it runs because the Stop is executed on startup (it's just there for troubleshooting). I've also Debug.Print the item(1) in the collection and it's correct. I feel like it's a simple mistake but for the life of me I can't figure it out. Using Outlook 2016 (mistake?). I've found another Slipstick post on this so posted there too. Hope not to be too annoying. Thank you in advance for any help you can provide. Peter Option Explicit Public WithEvents clntFldrItms As Outlook.Items 'https://www.slipstick.com/developer/itemadd-macro/ 'https://www.slipstick.com/developer/processing-incoming-e-mails-with-macros/ Private Sub Application_Startup() Dim clntFldr As MAPIFolder Set clntFldr = Application.Session.GetDefaultFolder(olFolderSentMail).Folders("Client Emails") Set clntFldrItms = clntFldr.Items Debug.Print clntFldrItms.item(1).Subject Stop End Sub Private Sub clntFldrItms_ItemAdd(ByVal item As Object) Dim bChar As String bChar = "/:*?â„¢""® &lt;&gt;|.&amp;@#_+©~;-+=^$!,'" &amp; Chr(34) Dim saveName As String If item.Class = olMail Then saveName = item.Subject For x = 1 To Len(bChar) saveName = Replace(saveName, Mid(bChar, x, 1), "-") Next x item.SaveAs "C:UsersUserGoogle Drive8 - VBA workPreparation for Assisted ResponderSent Messages Folder" &amp; _ saveName &amp; ".msg", olMSG… Read more »
0
0
Vit
November 7, 2016 8:07 am
Can you help me? How to adapt this macro for few accounts?
0
0
Admin
Reply to  Vit
February 6, 2017 1:19 am
You need to use ItemAdd macros if they are shared mailboxes - you need to 'watch' each folder - or use rules and run a script if they are added as accounts in your profile (itemadd will also work with accounts, but rules are usually easier).
0
0
Richard
September 4, 2015 12:57 pm
Well what do you know? After ticking the 'Permanently delete...' option in global settings, it worked! And BTW, AutoArchive does appear to work on non-default accounts. It did for me, anyway. Thanks for your help, Diane.
0
0
Admin
Reply to  Richard
September 4, 2015 9:58 pm
Thanks for the update. They may have changed the behavior of autoarchive - it used to only work on the default data file. I'll have to retest it, it's been a few years.
1
0
Latest EMO: Vol. 31 Issue 3
wpDiscuz
Never see this message again.
Move Comment
