Macro to Print Outlook email attachments as they arrive
› Developer › Macro to Print Outlook email attachments as they arrive
Last reviewed on September 30, 2014     228 Comments
Today's entry in the lazy programmer series involves tweaking the code sample at Attachment: Print received attachments immediately so that it works with 4-character extensions and also with 64-bit Outlook 2010 or 2013. (The original macro works with 32-bit Outlook).
For third party add-ins and utilities, see Print Email (and Attachments) on Arrival
The code looks at the last 4 characters, including the period and will work as long as you use 4 characters in each extension we want to check.
Case "xlsx", "docx", ".pdf", ".doc", ".xls"
To use the macro with 64-bit Outlook, you need to add PtrSafe to Declare:
Private Declare PtrSafe Function ShellExecute Lib "shell32.dll" Alias _
Print received attachments immediately code sample
Original code was written for 32-bit Outlook and 3 character file extensions.
To use, open the VBA editor using Alt+F11 and paste the following code into ThisOutlookSession. Edit the code as needed then click in the Application_Startup() macro and press Run button (F8). This starts the macro without the need to restart Outlook.
' Written by Michael Bauer, vboffice.net
' //www.vboffice.net/en/developers/print-attachments-automatically
' use  Declare PtrSafe Function with 64-bit Outlook
Private Declare Function ShellExecute Lib "shell32.dll" Alias _
  "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, _
  ByVal lpFile As String, ByVal lpParameters As String, _
  ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
  Dim Ns As Outlook.NameSpace
  Dim Folder As Outlook.MAPIFolder
  Set Folder = Ns.GetDefaultFolder(olFolderInbox)
  Set Items = Folder.Items
  If TypeOf Item Is Outlook.MailItem Then
    PrintAttachments Item
Private Sub PrintAttachments(oMail As Outlook.MailItem)
  Dim colAtts As Outlook.Attachments
  Dim oAtt As Outlook.Attachment
  Dim sFile As String
  Dim sDirectory As String
  Dim sFileType As String
  sDirectory = "D:\Attachments\"
  Set colAtts = oMail.Attachments
  If colAtts.Count Then
    For Each oAtt In colAtts
' This code looks at the last 4 characters in a filename
      sFileType = LCase$(right$(oAtt.FileName, 4))
      Select Case sFileType
' Add additional file types below
      Case ".xls", ".doc", "docx"
        sFile = sDirectory  & oAtt.FileName
        oAtt.SaveAsFile sFile
        ShellExecute 0, "print", sFile, vbNullString, vbNullString, 0
Print attachments then move the message
If you want to print the attachment then move the message to another folder, you'll either need to add the move code to the ItemAdd macro or add another macro and call it from the ItemAdd macro.
In this example, I'm adding a new macro and calling it from the ItemAdd macro, after the PrintAttachments macro is called.
    MovePrintedMail Item
At the end of the module, after the PrintAttachments macro, add the move macro. This macro assumes the "move to folder" is a subfolder of the Inbox. Don't forget to change the mailbox name, using the name as it appears in the Folder list (it's your email address in newer versions of Outlook).
Sub MovePrintedMail(oMail As Outlook.MailItem)
  Dim objDestFolder As Outlook.MAPIFolder
   Set objDestFolder = Session.Folders("mailbox name")._
     Folders("Inbox").Folders("Printed")
     oMail.Move objDestFolder
  Set objDestFolder = Nothing
Print Attachments on Selected Messages
To convert the macro to print attachments on a selected messages as needed, you need to remove the startup and itemadd macros and either use code that picks up the selected item or loops through the selected items.
This version will work either one or more selected items.
' Based on macro written by Michael Bauer, vboffice.net
Private Sub PrintAttachmentsSelectedMsg()
 Dim oMail As Outlook.MailItem
 Dim obj As Object
 'On Error Resume Next
For Each obj In ActiveExplorer.Selection
Set oMail = obj
  Dim sFile As String
  sDirectory = "C:\Users\Diane\Docs\"
      sFileType = LCase$(Right$(oAtt.filename, 4))
        sFile = sDirectory & oAtt.filename
Use Acrobat's Printer Options
If you own Adobe Acrobat, you can set the pages you want to print and "shrink to fit" using the PrintPages function of Acrobat:
Function PrintPages(nFirstPage As Long, nLastPage As Long, nPSLevel As Long, bBinaryOk As Long, bShrinkToFit As Long) As Boolean
To use Acrobat's object model, you need to set a reference to Acrobat in the VB Editor's Tool, References dialog box.
This will not work with Reader, you need to own Acrobat. I tested it with Acrobat X but it should work with any version of Acrobat. To the best of my knowledge, both Acrobat Standard and Acrobat Pro include OLE support.
Change the Select Case code in the PrintAttachments macro to the following. If you are only printing PDF files, you can remove the Case statement that prints Excel and Word files.
To print no more than first 2 pages, use AcrobatPrint sFile
' Print PDF
     Case ".pdf"
        AcrobatPrint sFile, "All"
After changing the Select case block, add the AcrobatPrint macro to your module, inserting it after the PrintAttachments macro.
Public Sub AcrobatPrint(FileName As String, PrintMode As String)
     Dim AcroExchApp As Acrobat.CAcroApp
     Dim AcroExchAVDoc As Acrobat.CAcroAVDoc
     Dim AcroExchPDDoc As Acrobat.CAcroPDDoc
     Dim num As Integer
     Set AcroExchApp = CreateObject("AcroExch.App")
     Set AcroExchAVDoc = CreateObject("AcroExch.AVDoc")
     ' Open the pdf file
     AcroExchAVDoc.Open FileName, ""
     Set AcroExchPDDoc = AcroExchAVDoc.GetPDDoc
     ' Get the number of pages for this pdf
     ' Subtract one because the count is 0 based
     num = AcroExchPDDoc.GetNumPages - 1
     If PrintMode = "All" Then
     ' Print Entire Document
     ' Last value is shrinktofit
           Call AcroExchAVDoc.PrintPages(0, num, 2, 1, 1)
           If num = 0 Then
               ' If one page, print document
               'Print first two pages
                Call AcroExchAVDoc.PrintPages(0, 1, 2, 1, 1)
     AcroExchApp.Exit
     AcroExchAVDoc.Close (True)
     AcroExchPDDoc.Close
Run a script version
This code sample is used in a run a script rule and deletes the message after printing the attached pdf.
to use, add the macro to a module, create a rule with the conditions you want to use and select run a script as the only action then select this script. For more information, see Run a Script rules.
  Dim sFile As String
  sDirectory = "C:\Users\Diane\Documents\Attach\"
      sFileType = LCase$(Right$(oAtt.FileName, 4))
      Case ".pdf", ".doc", "docx"
     oMail.Delete
How to use macros
  3. Make sure folder in the sDirectory path exists; if not, change it to a folder that exists.
  4. Click in the Application_Startup macro and press Run (or F8) to kick start it without restarting Outlook.
  5. Send yourself a message with a Word document attachment. Outlook should print it on arrival.
Macro to Print Outlook email attachments as they arrive was last modified: September 30th, 2014 by Diane Poremsky
  • Search PDF Attachments and Forward
  • Save Messages and Attachments to a New Folder
  • Save and Open an Attachment using VBA
  • Use VBA to move messages with attachments
Subscribe
Notify of
228 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
ramesh
April 22, 2021 3:49 am
Dear ,
thanks for the script is working fine , but i need to print specific print instead of default printer ,currently "ShellExecute 0, "print", sFile, vbNullString, vbNullString, 0" is printing directly to default  printer .
and it  prints  irregularly if pdf  , to solve this issue , i add "sleep 3000" after the shellexecute.
 how to select a specific printer.,
how can solve it .
0
0
Author
Reply to  ramesh
April 22, 2021 8:32 am
No, you can't change the printer in Outlook.
You can try changing the default before printing - then change it back.
Dim Wsh As Object
  Set Wsh = CreateObject("WScript.Network")
  Wsh.setDefaultPrinter "the printer name"
repeat the lines above with the usual default printer name to change it back.
0
0
ramesh
Reply to  Diane Poremsky
April 24, 2021 1:03 am
Thanks diane, for the reply , it is working , but is it possible to right a program to execute this , means that find the default printer on before and save as string , change later it as default.
it is much appreciated .
Best regards
0
0
Sridar
October 20, 2020 10:02 am
HI
Kindly provide code to print the attachment in ascending order based on the first 11 Digit of the attachment name .
0
0
Author
Reply to  Sridar
April 22, 2021 8:23 am
the attachments will be printed in the order the attachment's app processes and renders them - to control the order you would need to use a 3rd party utility.
0
0
David Sivewright
December 18, 2019 11:41 pm
Im getting a syntax error. with this.
Set objDestFolder = Session.Folders("ap@hipco.com").
Folders("Inbox").Folders ("Printed")
0
Author
Reply to  David Sivewright
December 18, 2019 11:45 pm
Which line is erroring?
0
0
Carl
December 18, 2019 5:12 pm
How would the VBA code be modified to include situations when the email message has another email message as an attachment and that second email message has the pdf, etc. file attachment that you want to automatically print?
0
0
Author
Reply to  Carl
December 18, 2019 11:19 pm
You would need to open (using .display) the second email than use application.ActiveInspector.CurrentItem to reference it - then you can open the attachment
0
0
Carl
December 19, 2019 10:25 am
0
Patrícia Costa
November 6, 2019 5:36 am
Hello!
I would like to print the PDF file from certain emails (with the same subject), also, in this file I just want to Print the second page. How should I proceed to create this rule and Macro?
Thank you,
Patrícia
0
0
Author
Reply to  Patrícia Costa
November 6, 2019 3:52 pm
The first 2 numbers in this line are first page to print, last to print - but the page numbers are zero-based - so 0 = page 1, 1 = page 2. Therefor, you use 1,1 as the first 2 numbers to print only page 2:
Call AcroExchAVDoc.PrintPages(1,1, 2, 1, 1)
https://www.poremsky.com/office/print-pdf-vba/
0
0
Alex Gamboa
June 14, 2019 11:36 am
I am currently using a trial version of the EZDetach add-in for outlook to automatically save attachments from incoming emails onto a folder on my desktop and then automatically print those attachments. I am trying to find a way to filter through those attachments to be able to auto print three different types of invoices to three different colors of paper. I either want it to auto print to different trays or purchase more printers and have each invoice print to a different printer. Please let me know if this is possible
0
0
Joe
September 13, 2018 3:08 pm
Will this code work with Nitro Pro?
0
0
Author
Reply to  Joe
September 13, 2018 4:00 pm
It might, since it just calls up the default application and uses shell commands. I dont have nitro to test it though.
0
0
Steven
June 26, 2018 8:37 am
I am using the script to print then delete the attachment, but it seems that it is double printing some of them and not printing others. The odd thing about this is that they all show up in the deleted folder as they should and in the order they should with no duplicates. Very strange. Any ideas?
0
0
Latest EMO: Vol. 30 Issue 36
  • Syncing Outlook with an Android smartphone
wpDiscuz
Never see this message again.
Move Comment
