Use a macro to create a rule to move messages
› Developer › Code Samples › Use a macro to create a rule to move messages
Last reviewed on December 4, 2018     No Comments
This code sample is in response to ASIF, who posted a question at OutlookForums:
I wanted to create a rule which will create "BLUE-July 20 - 26" sub-folder under SKY folder on every Sunday 1 AM . This should be created every Sunday. I want mails to transfer to the above folder to the week they belong to as soon as they arrive to inbox.
This is doable using VBA, however, one requirement is that Outlook needs to be running Sunday at 1 AM.
Create an appointment with the subject "Create new Blue folder" and a color category called "Update Sky". Set appointment time and add a reminder that fires at 1 AM every Sunday (I'm using a 0 minute reminder.) If you use a different subject or category, you'll need to update the macro. Don't forget, it's case sensitive.
Create an appointment with a reminder
In ThisOutlookSession, create the application reminder rule to run the CreateFolderRule macro. The BeforeReminderShow macro dismisses the reminder in this occurrence.
Private WithEvents olRemind As Outlook.Reminders
 Set olRemind = Outlook.Reminders
If Item.MessageClass <> "IPM.Appointment" Then
If Item.Categories <> "Update Sky" Then
  CreateFolderRule
Private Sub olRemind_BeforeReminderShow(Cancel As Boolean)
    For Each objRem In olRemind
            If objRem.Caption = "Create new Blue folder" Then
                If objRem.IsVisible Then
                    objRem.Dismiss
                    Cancel = True
                Exit For
        Next objRem
Right click on ThisOutlookSession and choose Insert > Module. Paste the following code into the new module.
Sub CreateFolderRule()
 Dim colRules As Outlook.Rules
 Dim oRule As Outlook.Rule
 Dim colRuleActions As Outlook.RuleActions
 Dim oMoveRuleAction As Outlook.MoveOrCopyRuleAction
 Dim oFromCondition As Outlook.ToOrFromRuleCondition
 Dim oExceptSubject As Outlook.TextRuleCondition
 Dim oFolder As Outlook.Folder
 Dim oMoveTarget As Outlook.Folder
 Dim BlueDate As String
' Create the folder name
BlueDate = "Blue " & Format(Date, "MMMM dd") & "-" & Format(Date + 7, "dd")
 'Specify target folder for rule move action
 'Set oFolder = Application.Session.GetDefaultFolder(olFolderInbox)
 Set oFolder = Application.Session.GetDefaultFolder(olFolderInbox).Parent.Folders("Sky")
' Set the folder, if it doesn't exist, create it
 Set oMoveTarget = oFolder.Folders(BlueDate)
If oMoveTarget Is Nothing Then
    Set oMoveTarget = oFolder.Folders.Add(BlueDate)
 'Get Rules from Session.DefaultStore object
 Set colRules = Application.Session.DefaultStore.GetRules()
 'Create the rule by adding a Receive Rule to Rules collection
 Set oRule = colRules.Create("Move to Sky", olRuleReceive)
' We're moving all messages; if you wanted to set conditions,
' do it here.
' Set oFromCondition = oRule.Conditions.From
' With oFromCondition
' .Enabled = True
' .Recipients.Add ("Diane Poremsky")
' .Recipients.ResolveAll
' End With
'Action is to move the message to the target folder
 Set oMoveRuleAction = oRule.Actions.MoveToFolder
 With oMoveRuleAction
 .Enabled = True
 .Folder = oMoveTarget
' We aren't using exceptions, but this is where exceptions would be set
' Set oExceptSubject = oRule.Exceptions.Subject
' With oExceptSubject
' .Enabled = True
' .Text = Array("fun", "chat")
' End With
 'Update the server
 colRules.Save
For more information, see Rules.Create Method (Outlook)
How to use macros
Use a macro to create a rule to move messages was last modified: December 4th, 2018 by Diane Poremsky
  • Running Outlook Macros on a Schedule
  • Create Tasks from Email and move to different Task folders
  • Enable or Disable an Outlook Rule using Reminders
  • Create a List of Rules
Subscribe
Notify of
0 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Latest EMO: Vol. 31 Issue 3
wpDiscuz
Never see this message again.
Move Comment
