Always Reply Using HTML Format in Outlook
› Developer › Always Reply Using HTML Format in Outlook
Last reviewed on May 5, 2017     59 Comments
Applies to: Outlook (classic), Outlook 2007
I'm often asked how to set Outlook to always reply in a specific format. While I don't recommend changing the reply format (because the sender choose the format for a reason), you can change it using a macro.
How do I set Outlook to always reply in HTML or RTF? When replying to, or forwarding, an email that is in plain text format, it always uses plain text. I want to force it to use RTF or HTML. I know I can change it every time, but I want it to be automatic.
The answer: Outlook does not offer a way to always use a specific format for all replies, be it RTF or HTML. You need to either change it on each message or write VBA macro to change the format. (You can force plain text replies to all messages by using the option to read all mail in plain text.)
We do not recommend always using HTML format (and certainly not RTF format) because you cannot be 100% sure that the sender is not using a smartphone or other device to read and reply to their mail. Many devices use plain text, either by default or as an option to the user and you should avoid changing the format on replies unless you have a valid reason - such as highlighting text, inserting tables or using bullet points. If you are replying with basic paragraphs of text, respect the sender's choice of plain text format.
Absolutely do not use RTF format for any message unless you know for a fact that the recipient will be reading it in Outlook (or OWA), otherwise they will get a plain text message and a winmail.dat attachment.
One of the readers of our Outlook Daily Tips mailing list posted the following macro. It was tested on Outlook 2007 and Outlook 2010 but should work on other versions.
Choose if you want to reply in HTML or plain text in this line:
'olFormat = olFormatPlain '(*1) - always use plain text
olFormat = olFormatHTML '(*2) - always use HTML
In the macro below, reply, forward, reply to all is generated using HTML.
If You want it to be in plain, comment out the HTML line and uncomment the plain text line, like this:
'olFormat = olFormatHTML '(*2) - always use HTML
And don't forget to disable macro warnings!
The Code
Copy and paste the code from this page into your ThisOutlookSession project.
In Outlook, press Alt+F11 to open the VBA editor and expand Microsoft Outlook Objects then double click on ThisOutlookSession to open it in the editing pane and Ctrl+P to paste the code.
Click the button to run the macroThis macro runs on application start up and monitors reply events. To test it without restarting, you can click within the Application_Startup macro and press the Run button in the Toolbar.
You'll also need to set macro security to allow the macro to run. While the low setting is OK for testing, we recommend using SelfCert to sign the macro if you are using it long-term.
Option Explicit
Private WithEvents oExpl As Explorer
Private WithEvents oItem As MailItem
Private bDiscardEvents As Boolean
Private olFormat As OlBodyFormat
   Set oExpl = Application.ActiveExplorer
   bDiscardEvents = False
   'olFormat = olFormatPlain        '(*1) - reply using plain text
   olFormat = olFormatHTML        '(*2) - reply using HTML
Private Sub oExpl_SelectionChange()
   Set oItem = oExpl.Selection.Item(1)
Private Sub oItem_Reply(ByVal Response As Object, Cancel As Boolean)
   If bDiscardEvents Or oItem.BodyFormat = olFormat Then
   Cancel = True
   bDiscardEvents = True
   Dim oResponse As MailItem
   Set oResponse = oItem.Reply
   oResponse.BodyFormat = olFormat
   oResponse.Display
Private Sub oItem_ReplyAll(ByVal Response As Object, Cancel As Boolean)
   Cancel = True
   Set oResponse = oItem.ReplyAll
   oResponse.Display
Private Sub oItem_Forward(ByVal Forward As Object, Cancel As Boolean)
   Cancel = True
   Set oResponse = oItem.Forward
   oResponse.Display
Always Reply using Plain Text, Change Header
This version of the oItem_Reply macro always replies using plain text and changes the header block at the top of the message from this:
 -----Original Message-----
 Sent: Friday, November 18, 2016 3:14 AM
 Subject: Exchange Messaging Outlook: Goodbye RPC over HTTP
To this:
 On Fri, Nov 18, 2016 at 03:14:18, EMO wrote:
This macro will always use plain text. If you want to maintain the format and only change the header, use the code sample from In-line reply style in Outlook.
Option Explicit
' Reply
   Cancel = True
' these two lines change the format and add > to the plain text reply
oItem.BodyFormat = olFormatPlain
oItem.Actions("Reply").ReplyStyle = olReplyTickOriginalText
 afterReply
Private Sub oItem_Forward(ByVal Response As Object, Cancel As Boolean)
   Cancel = True
oItem.Actions("Forward").ReplyStyle = olReplyTickOriginalText
 afterReply
   Cancel = True
oItem.Actions("Reply to All").ReplyStyle = olReplyTickOriginalText
 afterReply
Private Sub afterReply()
 Dim datestr As String
Dim orgBody As String
Dim myBody As String
Dim newBody As String
Dim name As String
Dim pos
Dim b
Dim Lines
Dim myLine
' Delete the signature from the top of the message
    Dim objDoc  As Object 'Word.Document
    Dim oBookmark As Object 'Word.Bookmark
    Set objDoc = oItem.GetInspector.WordEditor
    Set oBookmark = objDoc.Bookmarks("_MailAutoSig")
    If Not oBookmark Is Nothing Then
        oBookmark.Select
        objDoc.Windows(1).Selection.Delete
'if you want to add a signature at the end
'Set objFSO = CreateObject("Scripting.FileSystemObject")
''Edit the signature file name on the following line as needed'
'Set objSignatureFile = objFSO.OpenTextFile("C:\path-to-signature.txt")
'sig = objSignatureFile.ReadAll
'objSignatureFile.Close
name = oItem.SentOnBehalfOfName
datestr = Format(oItem.SentOn, "DDD, MMM dd, yyyy at HH:mm:ss")
' - Remove Outlook-style reply header
orgBody = oResponse.Body
pos = InStr(orgBody, ">") - 1
myBody = Mid(orgBody, pos + 1)
b = 0
Lines = Split(myBody, vbNewLine)
For Each myLine In Lines
If b > 4 Then
newBody = newBody & myLine & vbNewLine
b = b + 1
' Put new body together
oResponse.Body = "On " & datestr & ", " & name & " wrote:" _
& vbNewLine & newBody & vbNewLine '& sig
   oResponse.Display
'close the message you are replying to without saving changes
' (it was converted to plain text)
oItem.Close olDiscard
How to use the Macro
To check your macro security in Outlook 2010 or 2013, go to File, Options, Trust Center and open Trust Center Settings, and change the Macro Settings. In Outlook 2007 and older, it’s at Tools, Macro Security. If Outlook tells you it needs to be restarted, close and reopen Outlook. Note: after you test the macro and see that it works, you can either leave macro security set to low or sign the macro.
Application_Startup macros run when Outlook starts. If you are using an Application_Startup macro you can test the macro without restarting Outlook by clicking in the first line of the Application_Startup macro then clicking the Run button on the toolbar or pressing F8.
Always Reply Using HTML Format in Outlook was last modified: May 5th, 2017 by Diane Poremsky
  • Macro to Reply, ReplyAll, or Forward and File
  • VBA Sample: Do Something When Reply is Clicked
  • Copy attachment names when replying
  • Replying to Sent Messages
Subscribe
Notify of
59 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Brian Kelly
February 7, 2023 5:20 pm
Many thanks for this--it was an excellent example that helped me to implement this. I would note that it does not support the Use Case where someone Declines a Meeting Request and you want to respond to their Decline note, because it does not handle MeetingItems, but that was relatively easy to fix once I figured that out--just need a similar oMeetingItem object as the oItem object in the example above. I also modularized it such that the real meat of the code is in one function that is called by the various event handlers.
One issue that I hit, however, is that when this is implemented, the content of the Reply is all considered "new text", which means that when I hit send and the spellchecker kicks in, it does not check solely my actual reply, but the entire thread, even though the "Ignore original message text in reply or forward" is checked.
I will look into determining if there is a way to prevent that, but if anyone has any ideas how I can avoid this, I would love to hear them.
0
0
Thomas Kahn
October 30, 2020 2:41 pm
Sadly this script did not work for me in Outlook 2019. But using AutoHotkey I got it to work. As soon as I open a plain text message AHK quickly switches to the Format menu, selects HTML and switches back, it's barely noticable. This script can be found in this thread on the Microsoft Forum:
https://social.technet.microsoft.com/Forums/ie/en-US/d55e55d5-f8d4-4358-85cc-cc17d5d92b51/outlook-2010-always-reply-using-html-format-option
Search for AutoHotkey.
0
0
Kalan
August 14, 2017 3:52 pm
I would really like to know what smartphone can't read HTML email... It's 2017 all Android and iOS phones can read HTML, also if your webmail can't read HTML email you need to have your provider change that ASAP.
1
0
Author
Reply to  Kalan
August 14, 2017 4:02 pm
there are still a few that can't do HTML but it's not just about the device supporting it, it's also the "cost" of html in data. My sister does not have unlimited data and her only internet access is through the phone; converting her messages to html would add about 10 kb to each message. It's not just cellular providers who set data limits - not everyone has unlimited data.
1
-1
Rossy001
June 17, 2016 10:41 pm
Hello Diane. Thank you for this! I have successfully implemented your code, except not the "Change the Reply Font" code you provided, quoted here again. Where do I insert this code, please?
oResponse.HTMLBody = " " & oResponse.HTMLBody
0
0
Reply to  Rossy001
June 19, 2016 10:00 pm
Add the line between these if there is a not a line that sets the HTMLBody already in the code.
oResponse.Display
0
0
John Batts
June 23, 2015 3:21 pm
Thank you for this post. I hope that there is something that can be modified to allow me to bypass the problems that I have.
Specifically, there are instances where my Reply to a message assumes some formatting from the original message, causing the spacing between paragraphs to be abnormally big. Additionally, when I Reply to a message from someone in South Korea, the lines become justified and then break the words at irregular spots without hyphenation.
I can correct this by choosing Format Text-->Styles-->Change Styles-->Style Set-->Reset to Quick Styles from Template
I would love it if there was a way to automatically do this! It only impacts HTML-based messages - I don't recall seeing this issue if the original post was a pure text-based message. And I don't necessarily want to override from Text to HTML, out of respect for the recipient. But I don't want to have to do the process described above every time I type a message to one of those problematic recipients.
0
Christoph
January 19, 2013 5:58 am
Thanks for this script.
I'm using it but when I reply to an email, the font changes to Times New Roman.
I need Verdana, 10pt, grey. How can I change that?
In the settings of Outlook 2010 are the right font settings.
0
0
Reply to  Christoph
January 21, 2013 11:34 am
This happens because Outlook uses word as the editor - you can change the font fairly easily, but changing the font size is a little more complicated and i don't have a sample that does that. You'll add the oResponse.HTMLBody line as shown in this snippet - and can remove the bodyformat line.
oResponse.HTMLBody = " " & " " & oResponse.HTMLBody
oResponse.Display
0
0
zsolt
Reply to  Diane Poremsky
March 27, 2014 4:07 am
This code does not work, there is a synthax error in the font definition line and also in. bDiscardEvents = False
0
0
D Poremsky
Reply to  zsolt
March 27, 2014 6:21 am
it looks like the conversion from WordPress to Disqus messed the code up. Every "&" should be "&" - it was converted to the html code for &. (The = multiplied too.)
0
0
D Poremsky
Reply to  zsolt
March 27, 2014 7:17 am
The correct code (assuming it doesn't get messed up again) is
[code]oResponse.HTMLBody = "<font face=" & Chr(34) & " verdana" & Chr(34) & "> <font color=" & Chr(34) & " green" & Chr(34) & "> " & oResponse.HTMLBody[/code]
The 2 closing font tags were added by the web software too. Outlook will rewrite the color tags to CSS and properly close the tags when you hit Send.
I updated the article to include this line of code.
0
0
josh wilson
September 28, 2012 12:43 pm
i love the the above code, any way to insert me signal to it
0
0
Andy Wright
April 13, 2012 2:46 am
Thanks for this, with the altering of Macro security this now works just fine.
I had the problem mentioned by other poster whereby the signiature is inserted in plain text not HTML.
My way round the problem is to set outlook to not automatically add a sig to replies.
I then click reply and then click insert signiature
The sig has a few lines of text in my preferred font above the sig image, so I can then just click in that section and start typing in the desired font.
Yes this is a bit of a faff, but it leaves me with $30 to spend on beer instead :)
0
0
Reply to  Andy Wright
April 17, 2012 4:37 am
Beer is better than outlook. :) Depending on your version of Outlook, you can customize the toolbar, ribbon, or QAT to make the Insert signature command a step away, reducing your effort further.
0
0
Latest EMO: Exchange Messaging Outlook 2026 Archives
wpDiscuz
Never see this message again.
Move Comment
