Folder Home Pages aren't available
› Problems › Folder Home Pages aren’t available
Last reviewed on May 1, 2019     28 Comments
October 12 2017 A security update released on October 10 2017 removes the Home Page tab from Outlook 2010, 2013, and 2016. This change was made for security reasons but because so many applications use Folder Home Pages, Microsoft has a registry key available to re-enable folder home page support.
home page tab is missing
An earlier update, back in 2011, removed folder home pages from non-default data files. If you need to use a folder home page in a non-default folder, you'll also need to set the NonDefaultStoreScript value at the bottom of this page.
Remember: if a registry key doesn't exist, you'll need to create it!
Outlook 2016
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Office\16.0\Outlook\Security
DWORD: EnableRoamingFolderHomepages
Value: 1
Outlook 2013
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Office\15.0\Outlook\Security
Value: 1
Outlook 2010
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Office\14.0\Outlook\Security
Value: 1
home page tab is restored
Do it for me
Outlook 2016 Outlook 2013 Outlook 2010
Relevant KB articles are Outlook 2016: KB4011162; Outlook 2013: KB4011178; Outlook 2010 is KB4011196.
Folder Home Pages in Non-Default Data files
Problem: When you right-click on any of the folders that are listed down the left hand side in Outlook and choose Properties and then Home Page tab, the Home Page feature is disabled, preventing you from changing the address.
The home page setting is disabled in non-default data files "by design", beginning with Outlook 2007. If you want to use a folder home page in other data files and the URL field is grayed out, you'll need to configure a registry key to enable it.
You need to edit the following registry key and add the NonDefaultStoreScript value:
Outlook 2016
HKEY_CURRENT_USER\Software\Policies\Microsoft\office\16.0\outlook\security
DWORD: NonDefaultStoreScript
Value Data: 1 (Hexadecimal) to enable.
Outlook 2013
HKEY_CURRENT_USER\Software\Policies\Microsoft\office\15.0\outlook\security
Outlook 2010
HKEY_CURRENT_USER\Software\Policies\Microsoft\office\14.0\outlook\security
Outlook 2007
HKEY_CURRENT_USER\Software\Policies\Microsoft\office\12.0\outlook\security
After setting the registry value, you may need to restart Outlook for it to take effect.
Note that the Show folder home page checkbox is disabled (grayed out) until you enter a URL in the Address field.
Folder Home Page Properties sheet
Do It For Me
If you don't want to edit the registry, download and run the appropriate reg file for your version of Outlook.
Outlook 2016Outlook 2013Outlook 2010
Outlook 2007
You cannot add a URL to the Address box on the Home Page tab in Outlook 2007 MSKB (also applies to Outlook 2010)
Outlook does not support rendering all types of folder home pages
Folder Home Pages aren't available was last modified: May 1st, 2019 by Diane Poremsky
  • Outlook Folder Homepages are missing
  • Start Outlook using a different VBA Project file
  • Set an End Date on Recurring Appointments
Subscribe
Notify of
28 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Andrew
November 5, 2017 7:47 pm
Thanks Diane,
I have tried the above registry fixes but it does not seem to work for 64-bit operating systems (W7/W10) with 32-bit Office installations? I have tried restarting Outlook as well as the entire computer with no luck. It does work for 32-bit operating systems with 32-bit Office installations. It does work for 32-bit operating systems with 32-bit Office installations.
Are there any other registry tweaks needed for 64-bit OS'?
0
-1
Author
Reply to  Andrew
January 1, 2018 12:16 am
It's working here on 64bit windows/ 32 bit outlook. (I used the ready to use reg file for outlook 2016.)
0
0
Charlie
October 19, 2017 11:31 am
The most recent update to the Oct 2017 KB was perfect. FYI, you must close Outlook, add the missing DWORD and then re-open Outlook for this to take effect. Thank you sooooo much!
0
0
Phil
October 16, 2017 9:18 am
Does not work for me, windows 7 here. Tab "Homepage" is missing on folder properties
0
0
Author
Reply to  Phil
October 16, 2017 2:47 pm
Did you restart Outlook or Windows? Policies keys are only read at startup.
0
0
jeff white
October 12, 2017 6:44 pm
the registry key fixes didn't work for me. i did find the Microsoft security update that's causing this. you just need to uninstall the update. KB4011178 this is for office 2013 for office 2010 you need to uninstall KB4011196 and the homepage tab will re-appear
0
0
Author
Reply to  jeff white
October 12, 2017 6:54 pm
Did you restart Outlook? That is required with policy keys.
0
0
Ian
October 12, 2017 5:48 pm
I am glad that this was added to Outlook 2010.
0
0
Jan van Veldhuizen
October 12, 2017 3:24 pm
I found a solution in a Microsoft Technet forum.
Add this Registry key:
[HKEY_CURRENT_USER\SOFTWARE\Policies\Microsoft\Office\16.0\Outlook\Security]
"EnableRoamingFolderHomepages"=dword:00000001
Just tested it, and it works !!
0
0
Author
Reply to  Jan van Veldhuizen
October 12, 2017 4:58 pm
Was just coming to post the suggestion to try that key. Damn Microsoft. :)
I'm not sure if they are removing it for good (suspect so) but it's working in the insider build without the key.
0
0
Jan van Veldhuizen
October 11, 2017 9:31 am
Additional info: I tried to solve it programmatically, but the folder properties WiebViewOn and WebViewURL in the folder object throw an exception now. Have they been removed in the end?
Does that really mean that there is now only one place left to plug an HTML page into Outlook? (The Outlook Today page)
0
0
Author
October 12, 2017 1:00 am
I'm using a folder home page in build 1710 - it's my sharepoint home page. (I set it through properties & the key on this page is not set) I don't know if it makes a difference, but it's set as a trusted site in control panel, Internet Options, Security tab.
i used the sample code at https://msdn.microsoft.com/en-us/library/bb176545(v=office.12).aspx with Outlook 2016, version 1708 (current channel) and it works fine. (Microsoft.com is not on the trusted list on the test computer).
0
0
Author
October 12, 2017 1:01 am
oh, BTW, i am using the default store. That is probably why its working here... will test with a none-default store.
0
0
Author
Reply to  Diane Poremsky
October 12, 2017 1:14 am
ok... with a non-default store and using slipstick.com as the FHP url, it works, but the page has some scripts that cause errors. I used the macro from msdn to set the microsoft page as a FHP - it works fine, no errors.
(They tightened Outlook security some over the summer, but FHP are not blocked completely.)
0
0
Jan van Veldhuizen
October 11, 2017 8:56 am
The registry key is still read in the latest version (according to Procmon), but it doesn't do nothing anymore, apparently
1
-1
Latest EMO: Vol. 30 Issue 33
  • Office Outlook Add-ins
  • Direct Connect to Office 365
  • Create a rule to delete mail after a number of days
  • New Outlook: Show To, CC, BCC in Replies
  • Insert Word Document into Email using VBA
wpDiscuz
Never see this message again.
Move Comment
