Automatically Create Contacts From Messages
› Developer › Automatically Create Contacts From Messages
Last reviewed on April 1, 2026     19 Comments
This macro will go through the messages in a folder and create a contact for each sender
A user needed to solve this problem:
My contact list on a prior system was deleted. I imported all of my emails into my new Microsoft Outlook 2003 but going through all the emails individually to add contacts is horrible when you have thousands of emails. Does anyone have the micro basic code to set up a macro to add contacts from the personal favorite folder?
The user is right - its a slow, painful process to select each message, right click and choose Add to contacts. This macro solves the problem by automating the process - it goes through each message in the selected folder and creates a Contact for the sender.
For utilities that can do this or if you want to add the addresses of all people you send messages to (either new messages or replies) see Add addresses automatically to Microsoft Outlook Contacts.
This macro will work in any folder, on all selected items in that folder.
Any selected mail items will be harvested. Because Ken wanted to only use the OOM and so it's not restricted to 2007 or later only, he didn’t use the MAPI properties for SentOnBehalfOf* other than for name. So the email addresses may not be accurate (for example mails sent to a mailing list will often show as sent by the list address, not the actual sender.)
To use it, copy the code to Outlook's VB editor. If you need to run it on several folders, add a toolbar button for it. Select the messages you want to create contacts from and run it.
Tip: it might be helpful to copy messages from sender's whose address you want to save to a new folder then run it on that folder. This will allow you to peruse the messages and select just the sender's whose address you need saved.
Create Contacts for All Senders in a Folder
This macro is compliments of Outlook MVP and developer Ken Slovak from https://www.slovaktech.com
Ken adds: "If this were 2007 or later code only I’d use PropertyAccessor to pick up the PR_SENT_REPRESENTING_ADDRTYPE and PR_SENT_REPRESENTING_EMAIL_ADDRESS properties instead of using SenderEmailAddress and SenderEmailAddressType."
' The AddAddressesToContacts procedure can go in any Module
' Select the mail folder and any items to add to contacts, then run the macro
Public Sub AddAddressesToContacts()
Dim folContacts As Outlook.MAPIFolder
Dim colItems As Outlook.Items
Dim oContact As Outlook.ContactItem
Dim oMail As Outlook.MailItem
Dim obj As Object
Dim oNS As Outlook.NameSpace
Dim response As VbMsgBoxResult
Dim bContinue As Boolean
Dim sSenderName As String
Set oNS = Application.GetNamespace("MAPI")
Set folContacts= oNS.GetDefaultFolder(olFolderContacts)
Set colItems= folContacts.Items
For Each obj In Application.ActiveExplorer.Selection
If obj.Class = olMail Then
Set oContact= Nothing
bContinue= True
sSenderName= ""
Set oMail = obj
sSenderName = oMail.SentOnBehalfOfName
If sSenderName = ";" Then
sSenderName = oMail.SenderName
Set oContact = colItems.Find("[FullName] = '" & sSenderName & "'")
If Not (oContact Is Nothing) Then
response = MsgBox("This appears to be an existing contact: " & sSenderName & ". Do you still want to add it as a new contact?", vbQuestion + vbYesNo, "Contact Adder")
If response = vbNo Then
bContinue = False
If bContinue Then
Set oContact = colItems.Add(olContactItem)
With oContact
.Body = oMail.Subject
.Email1Address = oMail.SenderEmailAddress
.Email1DisplayName = sSenderName
.Email1AddressType = oMail.SenderEmailType
.FullName = oMail.SenderName
.Save
Set folContacts = Nothing
Set colItems = Nothing
Set oContact = Nothing
Set oMail = Nothing
Set obj = Nothing
Set oNS = Nothing
How to use VBA
Copy and paste the code from this page into your ThisOutlookSession project. To do this, click within the code, Select All using Ctrl+A, Ctrl+C to copy.
In Outlook, press Alt+F11 to open the VBA editor and expand Microsoft Outlook Objects then double click on ThisOutlookSession to open it in the editing pane and Ctrl+P to paste the code.
For more detailed instructions and screenshots, see How to use Outlook's VBA Editor
Add addresses automatically to Microsoft Outlook Contacts - create contacts for people you send messages to.
Automatically Create Contacts From Messages was last modified: April 1st, 2026 by Diane Poremsky
  • Macro to Create an Outlook Contact from an Email Message
  • Change the Business Card layout using BusinessCardLayoutXml
  • Change the image on a Business Card based on the Category
  1. Adam says
    February 25, 2016 at 3:55 pm
    How can I get it to Update or Merge a contact if it already exists? Yes I do have a need for this before anyone tells me I don't need this or shouldn't ;)
      February 26, 2016 at 4:52 pm
      Outlook has an option to look for duplicates when a new contact is added - this won't merge the contacts there. There are utilities that will merge duplicate contacts - you could do it with a macro, but really need to display the data and choose which to keep - that is better as a com addin rather than a simple macro. I have a list of addins at https://www.slipstick.com/addins/duplicates-addins/remove-duplicate-contacts-from-outlook/ - Contacts Scrubber lets you pick the fields to keep. Others on the list may as well.
  2. Shaun says
    February 20, 2016 at 12:19 pm
    Great article. Is there any way of modifying the code so it transfers email addresses from the To, rather than Sent From items? I have many draft emails I would like to put into contacts without having to send an email.
      February 20, 2016 at 11:10 pm
      Try .Email1Address = oMail.To Is there more than one address in the to field? if so, you need to use the recipient collection.
  3. WWWV says
    September 15, 2015 at 4:24 am
    How is it possible to add the adresses written in Sent to, CC & BCC too? So not just the sender, but basicly all the mailadresses.
    Thx.
      September 15, 2015 at 7:05 am
      You could - you'd need to go through the recipient collection. Between the two end if's at the end, add this code. After the sender is added, it'll work on the recipients. (BTW, it won't work on the BCC field as you don't see who it was sent to. )
      For Each Recipient In oMail.Recipients
      sSenderName = Recipient.Name
      ' add recipients
      bContinue = False
      If bContinue Then
      With oContact
      .Email1Address = Recipient.Address
      .FullName = sSenderName
      .Save
      Next Recipient
      • Ivo says
        March 23, 2016 at 7:57 am
        thanks for this, but i get a error: "next without for"
        Here is my code:
        Dim obj As Object
        Set folContacts = oNS.GetDefaultFolder(olFolderContacts)
        Set colItems = folContacts.Items
        bContinue = True
        sSenderName = ""
        Set oMail = obj
        bContinue = False
        If bContinue Then
        With oContact
        .Save
        ' add recipients
        bContinue = False
        If bContinue Then
        With oContact
        .Save
        Next Recipient
        Set oMail = Nothing
        Set obj = Nothing
        Set oNS = Nothing
        March 23, 2016 at 10:50 am
        that means there are too many end if, for's, next etc - it highlights on Next Recipient you either need a matching for or delete that line.
      • Ivo says
        March 23, 2016 at 9:43 am
        Fix the problem, i was missing the first line.. :-o
        What i needed was only the recipients email adress so i changed
        to:
        Set oContact = colItems.Find("[Email1Address] = '" & sSenderName & "'")
        works like a charm, Thanks a lot!
  4. Alexandre says
    August 12, 2015 at 4:24 am
    Hello everyone,
    thank for this macro, it is very useful! I was wondering if instead of creating a new contacts in the address book, it was possible to export these informations directly into an excel file.
    Many thanks!
      August 12, 2015 at 8:18 am
      Sure. See https://www.slipstick.com/developer/vba-copy-outlook-email-excel-workbook/ for sample code. It's just a matter of changing which fields you grab. The sample is for a run a script rule.
  5. Colin says
    April 1, 2015 at 9:29 am
    Many thanks for posting this code. I would like to change from the default contacts folder to a specific sub folder called Test. How would I change the code for this to work.
    Many thanks
    Colin
      April 1, 2015 at 1:06 pm
      This line sets the folder:
      to use a subfolder of contacts, use
      Set folContacts= oNS.GetDefaultFolder(olFolderContacts).folders("folder name")
      More on using non-default folders: https://www.slipstick.com/developer/working-vba-nondefault-outlook-folders/
  6. Paik says
    January 12, 2013 at 5:54 am
    @ Ilana Fridlin: Find this section in the code:
    And replace it with:
    bContinue = False
  7. Ilana Fridlin says
    December 10, 2012 at 6:36 am
    Is there a way to add a comand so that when it says the contact already exists and asks if I want to still add, it it automatically "clicks" on NO and keeps on going? Cause it's really unproductive to have to keep clicking NO until it ends... Please...? Or somehow that it only copies those that don't already exist...
      December 10, 2012 at 7:33 am
      The dialog is not exposed to the object model, sorry. You would need to use a windows utility that responses to dialogs. ClickYes and others can do this.
    • Justin Goldberg says
      August 12, 2014 at 9:32 am
      You can also use a weight or a pencil to hold down the 'N' key while you run the script. I've done this before, it works well most of the time.
  8. Peter Zuffa says
    August 23, 2012 at 5:10 am
    Hi, there's a typo on line:
    response = MsgBox("This appears to be an existing contact: " & sSenderName" &
    The double quotes after sSenderName" must be removed.
    Peter
      August 23, 2012 at 6:34 am
      Thanks for finding that error.
