Macro to Add or Remove a Category
› Developer › Code Samples › Macro to Add or Remove a Category
Last reviewed on December 1, 2022     1 Comment
Add or remove categories
A visitor to Slipstick's Outlook Forums needed a macro to toggle a category on and off. If the category is already on the selected message, the macro removes it, otherwise it adds the category.
In order to remove one category when several are applied to a message, you need to split the categories into an array before deleting the category. After the category is deleted from the array, you'll recreate the category string.
This macro sample sets (or removes) four different categories.
Dim StrCat As String
Sub MyBlue()
StrCat = "Outlook Users"
SetCategory
Sub MyBlue2()
StrCat = "Macros"
SetCategory
Sub myGreen()
StrCat = "Business"
SetCategory
Sub myOrange()
StrCat = "BB"
SetCategory
Private Sub SetCategory()
  Dim Mail As Object
  Set Mail = Application.ActiveExplorer.Selection.Item(1)
Debug.Print Mail.Categories
 arr = Split(Mail.Categories, ",")
    If UBound(arr) >= 0 Then
' Check for Category
    For i = 0 To UBound(arr)
      If Trim(arr(i)) = StrCat Then
        ' remove it
            arr(i) = ""
            Mail.Categories = Join(arr, ",")
        ' Category Removed, exit
' Category not found, add it
    Mail.Categories = StrCat & "," & Mail.Categories
If you want to add or remove the categories from a selection of messages, replace the SetCategory sub above with the following.
  Dim Selection As Selection
  Dim Mail As Object
  Set objOL = Outlook.Application
  Set currentExplorer = objOL.ActiveExplorer
For Each Mail In Selection
  ' remove it
    arr(i) = ""
  ' Category Removed, next message
    Mail.Save
GoTo nextmessage
  Mail.Save
' No Categories, add it
 Mail.Save
nextmessage:
Next 'next message
Macro to Add or Remove a Category was last modified: December 1st, 2022 by Diane Poremsky
  • Remove Email Signature from Message using VBA
  • Using Arrays in Outlook macros
  • Use VBA to get an Appointment's Time Zone
  • Macro to Move or Copy an Outlook message to another folder
  1. Vlad Sabau says
    October 12, 2018 at 2:17 am
    thank you for the solution! please be so kind to help me extend this from individual email messages to selections of more email messages i.e. to be able to switch on/off categories of all selected messages. thank you!
