Running Outlook Macros on a Schedule
› Developer › Code Samples › Running Outlook Macros on a Schedule
Last reviewed on August 25, 2016     23 Comments
How do I run a macro 5 minutes after Outlook starts?
Outlook doesn't have a timer function but you can use Appointment or Task Reminders to trigger macros. Set up an Application_Reminder macro that will do something when a reminder fires. To limit it to running when specific reminders fire, use an If statement to look for words in the subject or a specific category.
If you want the macro to fire a specified time after you restart Outlook, use an Application_Startup macro to create the appointment.
Create an appointment reminder to trigger a macro
If you need to rerun the process kicked off by the reminder, run CreateAppointment macro from the VBA editor at any time.
Other "reminder macros" are at "Open a Webpage when a Task Reminder Fires" and "Send an Email When a Reminder Fires"
' The Private subs go in ThisOutlookSession
Private WithEvents olRemind As Outlook.Reminders
  CreateAppointment
Set olRemind = Outlook.Reminders
If Item.MessageClass <> "IPM.Appointment" Then
If Item.Categories <> "Run in 5" Then
' Call your macro here
MsgBox "It works!"
'Delete Appt from calendar when finished
Item.Delete
' Create another appt to repeat the process
CreateAppointment
' dismiss reminder
Private Sub olRemind_BeforeReminderShow(Cancel As Boolean)
    For Each objRem In olRemind
            If objRem.Caption = "This Appointment reminder fires in 5" Then
                If objRem.IsVisible Then
                    objRem.Dismiss
                    Cancel = True
                Exit For
        Next objRem
' Put this macro in a Module
Public Sub CreateAppointment()
Dim objAppointment As Outlook.AppointmentItem
Dim tDate As Date
' Using a 1 min reminder so 6  = reminder fires at 5 min.
tDate = Now() + 6 / 1440
Set objAppointment = Application.CreateItem(olAppointmentItem)
      With objAppointment
        .Categories = "Run in 5"
        .Body = "This Appointment reminder fires in 5"
        .Start = tDate
        .End = tDate
        .Subject = "This Appointment reminder fires in 5"
        .ReminderSet = True
        .ReminderMinutesBeforeStart = 1
        .Save
How to use the macro
To check your macro security in Outlook 2010 or 2013, go to File, Options, Trust Center and open Trust Center Settings, and change the Macro Settings. In Outlook 2007 and older, it’s at Tools, Macro Security. If Outlook tells you it needs to be restarted, close and reopen Outlook. Note: after you test the macro and see that it works, you can either leave macro security set to low or sign the macro.
Application_Startup macros run when Outlook starts. If you are using an Application_Startup macro you can test the macro without restarting Outlook by clicking in the first line of the Application_Startup macro then clicking the Run button on the toolbar or pressing F8.
Running Outlook Macros on a Schedule was last modified: August 25th, 2016 by Diane Poremsky
  • Reset reminders closer to Meeting time
  • Use a macro to create a rule to move messages
  • Scheduling Drafts in Outlook
Subscribe
Notify of
23 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Adauto Araujo
March 21, 2024 10:23 am
Wonderfull! Thanks. The only addition I'll do, is to change from this: tDate = Now() + 6 / 1440 to this: tDate = Now() + TimeValue("00:05:00"). I think it's more readable and easier to edit.
0
0
J.A. Clark
May 24, 2022 3:50 pm
After copy/paste all code as instructed in tutorial and then closing both VBA Editor and Outlook to restart, an error is displayed, 'Compile error: Invalid attribute in Sub or Function'. The first line of cod is highlighted in 'This OutlookSession'.
Running Outlook Office 365 v2202.
Any assistance would be appreciated.
0
0
Author
Reply to  J.A. Clark
June 9, 2022 4:41 pm
This line is highlighted?
If it's ' The Private subs go in ThisOutlookSession - go ahead and delete it.
0
0
Krishna
January 5, 2021 1:55 pm
Just adding a little comparison info -
I'm looking to run the code like how automatic replies are working. We will receive automatic replies, though the outlook-off. Like this, can VB Macros can work, if Outlook-Off/Close ?
Krishna
0
0
Krishna
January 5, 2021 1:49 pm
Hope all good and HNY ..
We have done some coding in VBA on outlook, our requirement is to run the code over night - But we are not sure, outlook will opened or system is on .. Is there any possibility to make the macros execute at Outlook -Off time.
Any suggestions will be great help.
Many Thanks,
Krishna
0
0
Prabhat Dewali
March 4, 2020 7:21 pm
Hello Mam,
Thanks for sharing this blog with us I am a beginner in VBA coding. Can you help me with how can I replicate the same appoint or "Create another appt to repeat the process" for the next day or till a certain day in the above code?
"' Create another "Run in 5" appt to repeat the process
"CreateAppointment "
0
0
Prabhat Dewali
Reply to  Prabhat Dewali
March 5, 2020 6:59 pm
Thanks, I found the solution and now my question is solved it can be done from front end by using the recurrence option.
0
0
Author
March 5, 2020 8:59 pm
Yeah, using a recurrence is generally better than recreating a new one every day using a macro.
0
0
Harrison Griffiths
February 12, 2020 7:07 pm
I'm looking to create either a reminder or send an email to the creator of an appointment when the appointment is done or even maybe 5 min after its done. The purpose is for employees who might be working out in the field alone we want them to have a reminder governed by their Outlook calendars to email a colleague or coordinator that they have left work and are safe. Like a Check-In reminder to let the team know they're good and heading home.
0
Author
Reply to  Harrison Griffiths
March 5, 2020 9:05 pm
I don't think you'd want that automated - based on the appointment as it would generate the message, whether they were safe or not, just based on the meeting end time. They could use a macro to quickly generate a message and set it - no typing required.
https://www.slipstick.com/developer/create-a-new-message-using-vba/
0
0
Ranjan
April 8, 2019 10:34 am
I am looking for a code to create new outlook meeting invite.
I have data in my excel like this.
A-Name
B-ID
C-Recipient 1
D-Recipient 2
E-Subject
F-Body
I am aiming to achieve below. Could you please assist me here.
1. Create a new meeting invite
2. Add the above in right place
3.check for the availability in calendar and set the meeting start and end date(duration is 1hour)
4.Attach required files
5. display/send
0
0
Author
Reply to  Ranjan
April 8, 2019 11:56 pm
I have a macro that should meet your needs at
https://www.slipstick.com/developer/create-appointments-spreadsheet-data/#meeting
0
0
Edwin
May 24, 2018 11:19 am
thanks so much for sharing this excellent information with the world. It has been extremely helpful to me and I am grateful.
0
0
Latest EMO: Vol. 30 Issue 36
wpDiscuz
Never see this message again.
Move Comment
