Problem: Do you want to save changes?
› Problems › Problem: Do you want to save changes?
Last reviewed on March 1, 2013     2 Comments
When you open or view a message that contains graphics or open an attachment and a message similar to this:
"The properties of the message "subject" have been changed. Do you want to save changes to this message?"
when you haven't changed anything other than read the message.
When the message is HTML format with external images, you'll get this question because the message changed when you downloaded the images.
The problem is also caused by a Word add-in making changes to the Word template, usually by adding toolbar buttons. The usual cause is Adobe Acrobat but other Word templates or add-ins may also be to blame. You may get this error when you read the message or an attachment.
Solution
To fix this problem, you need to identify the Word add-in or template that is causing the message and remove or uninstall it.
Save Normal.dot?
Removing the Acrobat Toolbar from Outlook
Problem: Do you want to save changes? was last modified: March 1st, 2013 by Diane Poremsky
  • Outlook's Toolbars Don't Stay Where You Put Them
  • Create a Template With the Account Selected
  • Edit and Save Outlook's Read-Only Attachments
  • Removing the Acrobat addin and toolbar from Outlook
Subscribe
Notify of
2 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
xob
September 2, 2020 9:48 am
but what if we need to use that addin, but still want to get rid of this message?
0
0
Author
Reply to  xob
September 2, 2020 10:36 am
You can't change it when the cause is external content, but if the problem is an addin updating the template, you have an option to not prompt to save changes to template.
In Word: File > Options > Advanced > Prompt before saving Normal template - untick it. This should take care of it in both word and outlook, if the cause is an addin updating the template.
0
0
Latest EMO: Vol. 30 Issue 38
wpDiscuz
Never see this message again.
Move Comment
