Check messages you send for number of recipients
› Developer › Check messages you send for number of recipients
Last reviewed on December 30, 2013     No Comments
These macros check the number of recipients on an outgoing message and if there are more than a specific number of recipients, asks what you want to do with it. The first macro lets you cancel the send, the second macro sends the message, moving the addresses to the BCC field if you click Yes, and sends as is when you click No.
To look for messages containing attachments then confirm you really want to send the attachment to everyone, see Do you want to send an attachment?
Cancel the send if more than 1 recipient
Change the recipient count (Item.Recipients.Count > 1) to the desired number.
  Dim intRes As Integer
  Dim strMsg As String
  If Item.Recipients.Count > 1 Then
    strMsg = "Your message " & Chr(34) & Item.Subject & Chr(34) & _
             " contains " & Item.Recipients.Count & " recipients. " & vbCrLf & vbCrLf & _
             "Do you want to send this message?"
    intRes = MsgBox(strMsg, vbYesNo + vbExclamation, "Confirm Message Send")
    If intRes = vbNo Then
      ' cancel send
      Cancel = True
Move the addresses to the BCC field
Use this code to move addresses in the To and CC fields to the BCC field.
  Dim i As Integer
             "Do you want to move them to the BCC field?"
    If intRes = vbYes Then
    For i = 1 To Item.Recipients.Count
    Item.Recipients(i).Type = 3
  Next i
Check messages you send for number of recipients was last modified: December 30th, 2013 by Diane Poremsky
  • Use VBA to check Outlook's outgoing messages for attachments and cance
  • Sometimes we get some interesting questions and the solution, while no
    Remove the To field from an Outlook message form
  • Add a keyword to the subject of all messages sent
  • Automatically create a task when sending a message
Latest EMO: Vol. 31 Issue 5
