Printing Calendars with Color Categories
› Problems › Printing Calendars with Color Categories
Last reviewed on May 8, 2019     1 Comment
Some Outlook 2007 users are having problems printing calendars with the events colored with color categories. In most cases, the problem printer is an HP and its correctly configured to print in color.
HP support documents have this to say about the problem:
Some or all of my jobs print in monochrome (black) only. How do I change this?
If a software program, such as Microsoft Outlook, is restricted from printing in color, embedded documents in e-mail files will be printed in black (monochrome), even if the application would otherwise print in color.
If this were true, printing to electronic formats such as PDF (which has the correctly colored appointments) then printing the PDF would work as expected, with colored events. Printing the same PDF to a different printer results in colored appointments and printing other PDF's containing color works on the HP. Printing email that contains colors works, so it's not a restriction in Outlook.
You can try changing Outlook's option to print with gray shading, but note that it may not have an effect.
  1. Go to File, Print
  2. In the Print dialogue, choose Page setup...
  3. Uncheck Print using gray shading (near bottom of dialog)
If printing color categories is really important to you, check out the tools at Calendar Printing Tools for Outlook. If these don't meet your needs you'll need to use a different printer. I believe only HP printers are affected and a future driver update may fix it.
Colors in Calendar Printing Assistant
The Calendar Printing Assistant (CPA) uses the color of the calendar as seen in the left bar, not color categories. For example, if you add 3 calendars or task folders, the items will be colored to match the calendar color. Even so, my HP can't print any colors from the CPA - not the dates or the bullets that mark the calendar. There is a border around the all day events.
Will this ever be changed so that calendars are identified by the colored dots and events use their category colors? I have no idea. It depends on how many people use the CPA and request the feature.
See Calendar Printing Tools for Outlook for utilities that may print color categories correctly.
Calendar Printing Assistant for Outlook 2007
Printing Calendars with Color Categories was last modified: May 8th, 2019 by Diane Poremsky
  • Calendars aren’t printing in color
  • How to Email Calendar Printing Assistant Calendars
  • Calendar Printing Tools
  • Calendar Printing Assistant Shows Duplicate Entries
Subscribe
Notify of
1 Comment
newest
oldest most voted
Inline Feedbacks
View all comments
coin info
April 27, 2020 12:21 pm
If you want to know the main fact about the main reason to use the best URL shortner so, in this blog, I shall tell you something special fact about the best URL shortner. Basically, the best URL shortner trying to link more manageable because of search engine optimization reasons. Generally, the link describes what is the content behind the link but the lengthy link is not sharable with anyone. And the second reason is the best URL shortner provide the track and compile the data. Let me explain, short URL actually, gain more attention that why users paying more attention. After that, the third one is best url shortner transformed into social media services like, best url shortner can lead to some useful mashups and innovations in how people share and digest content. And the last reason is more important because best url shornter is for space purpose and you can easiily fit more link in the less space and anyone promotes the more information with the help of best url shortner. So, everyomne can use short url in facebook, twitter and websites for promotions.
0
0
Latest EMO: Vol. 30 Issue 38
wpDiscuz
Never see this message again.
Move Comment
