Using Custom Business Cards
› Outlook › Using Custom Business Cards
Last reviewed on December 1, 2017     3 Comments
While you can't the business card layout used by existing contacts, other than by editing each contact, you can change the default which is used for new contacts by creating a custom contact form with the desired business card layout and publish it. Set it as the default Contacts form for new Contacts.
Create a custom form
  1. Open a new Contact form and edit it as desired.
  2. Do not add names, addresses or phone numbers in this form. Change only the business card or other features you want applied to all future contacts.
  3. Go to the File tab, Options, Customize Ribbon and enable the Developer tab
  4. From the Developer tab, choose Publish form as...
  5. Publish the form to Outlook Folders
Using the Custom Form
You can select the custom form as needed, by selecting it from the New Item menu while viewing the folder it is published to. You can also set it as the default for the Contacts folder so every new contact uses it.
New item menu
Use the Custom Form as Default for New Contacts
To set the new form as the default contacts form, right click on the Contact folder, choose Properties and set the newly created custom form as the default form for the folder.
When you click New Contact, you'll use this form and all newly created contacts will use the new layout.
Set default new item form
Changing existing contacts to use the new layout
You can change the form used by existing contacts but the new business card layout won't be changed. Use a tool listed below to change the message class to the new form.
Changing the form used by a contact will not change the business card on the contact. You'll need to edit the business card layout of existing contacts individually or use VBA.
To apply the layout of the new business card to existing contacts, see Code Sample 3: Change the business card layout to match the selected contact.
DocMessageClass
Used to change the message class of Outlook items,so that existing items will use newly created forms.Free.
Using Custom Business Cards was last modified: December 1st, 2017 by Diane Poremsky
  • Changing Outlook's Business Card layout
  • How to Set a Custom Form as the Default for a Folder
  • Using VBA to Change Business Card Image & Layout
  1. Merryn Orchard says
    January 8, 2025 at 8:14 pm
    Thanks for this - I have now created a new contact folder with a default Business Card layout for all of our internal team members - will be very handy for future new starters.
  2. Chuck Devlin says
    September 4, 2012 at 9:26 am
    Is it possible to add even more things to the "business cards". My mother uses outlook to track personal information. I would like to create a business card that shows Birthday, Anniversary, Children, Spouse, and one or two other things. I have used all of the USER options but need more choice.
      September 4, 2012 at 9:29 am
      The business card layouts are based off an XML file, so its possible but i don't know if the fields are accessible. I'll look into it.
