View Read Receipt Request Indicator
› Outlook › Rules, Filters & Views › View Read Receipt Request Indicator
Last reviewed on September 23, 2019     No Comments
Applies to: Outlook (classic), Outlook 2010, Outlook 365 (Win)
All current versions of Outlook include a Read Receipt field, including Outlook 2010, 2013, 2016/2019/365.
To see the Read Receipt indicator, you need to customize the view by adding the Receipt Requested field. For best results, you will need to use the Single Line view to see the read request field.
To add the field to the view:
  1. Switch to the View menu. If you use the "old" ribbon, click View Settings. If you are using the Simplified ribbon, it's under then Current View > View Settings.
    edit view settings
  2. Click Columns.
  3. Select All Mail fields from the Select available columns from: menu.
  4. Find and select Receipt Requested and Add it to the columns to show.
    read receipt requested field
  5. Click OK and close the dialogs.
After you add the field to the view, slide the reading pane to the right to show the Receipt Requested field, where you'll see Yes (a receipt is requested) or No (not requested).
read receipts field shows Yes if receipts are requested
To show it in the Compact view, you need to move the Receipt Requested field to the top of the Columns list.
move the receipt requested field to the top
You may also want to change the Formatting to Icon in View Settings > Format columns. (You can do this for the Single line view too.)
change the format to icon
It will look like this in the Compact view:
compact view
View Read Receipt Request Indicator was last modified: September 23rd, 2019 by Diane Poremsky
  • How to Customize or Reset the Current View
  • Hide Read Receipts in Conversation View
  • Change the Subject of an Incoming Message
  • Change the name of the field in your view
    How to Change the Name of a Field in the View
Subscribe
Notify of
0 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Latest EMO: Vol. 30 Issue 38
wpDiscuz
Never see this message again.
Move Comment
