Prevent Users From Choosing Stationery
› Outlook › Email › Prevent Users From Choosing Stationery
Last reviewed on April 27, 2015     No Comments
We often get asked if its possible to restrict the usage of stationery in Outlook. Or the administrators want to setup a default stationery for use by all users on the local network and prevent users from changing the stationery on their desktops.
Yes, this is possible. You need to use this registry key to enforce stationery usage:
HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\12.0\Common\MailSettings
Value name: NewStationery
Value type: REG_EXPAND_SZ
Value: Name of the HTML file, without the .htm tag
For example, if the name of the stationery file is “Company Letterhead.htm” the value for NewStationery would be “Company Letterhead”
The value called NewTheme in the same key controls the default theme if you're using a theme and not stationery.
You can create a new .adm file if you want to add either key to the group policy editor.
Prevent Users From Choosing Stationery was last modified: April 27th, 2015 by Diane Poremsky
  • Disable Stationery and Fonts using Group Policy
  • Apply Outlook Stationery to Replies and Forwards
  • The Signature or Stationery and Fonts button doesn't work
  • Accessibility and Signatures: Add an Alt Tag
Subscribe
Notify of
0 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Latest EMO: Vol. 30 Issue 38
wpDiscuz
Never see this message again.
Move Comment
