Use VBA to initiate a Send/Receive for a specific account
› Developer › Use VBA to initiate a Send/Receive for a specific account
Last reviewed on December 4, 2018     4 Comments
A visitor to our OutlookForums site wanted to know if he could create a button for an account:
Is it possible to create a toolbar button that would execute Send/Receive on one specific mail account only? I have send/receive groups, and the pull-down button for all accounts from the toolbar, but that involves some menu-wading.
While there are workable options for easier access that don't involve using VBA, you can use Outlook's SyncObjects property in a macro to trigger a send and receive for a specific Send/Receive Group or Account.
This sample does a send and receive on a specific send and receive group. To use, replace the 1 in mySyncObjects(1) with the desired group's position number.
Send and Receive Group numbers
Alternately, you could use the Group's name mySyncObjects("New Group")
Send and Receive Group macro
To use, open the VBA Editor using Alt+F11 and paste this code in either ThisOutlookSession or a Module. Assign it to a toolbar, ribbon, or QAT button to run it.
Public Sub SendReceiveGroup()
    Dim mySyncObjects As Outlook.SyncObjects
    Dim syc As Outlook.SyncObject
    Set mySyncObjects = Application.GetNamespace("MAPI").SyncObjects
        Set syc = mySyncObjects(1)
        syc.Start
OL2000: How to Programmatically Synchronize Folders (MSKB)
NameSpace.SyncObjects Property (TechNet)
Use VBA to initiate a Send/Receive for a specific account was last modified: December 4th, 2018 by Diane Poremsky
  • Macros to send messages using a specific account
  • Choose the account to send a reply from
  • Separate Outlook's Send and Receive functions
  • Configuring a Manual Send and Receive in Outlook
Subscribe
Notify of
4 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
fordraiders
May 3, 2016 3:44 pm
I still keep getting the "You have emails in your sent box....." exiting in 30 second countdown..
Because I have put a Application.quit in the vba code in outlook?
How do I keep this msgbox from popping up ?
0
0
Author
Reply to  fordraiders
May 3, 2016 10:30 pm
Do you have messages waiting to be sent? I'm not aware of anyway to avoid that error if there are messages in the outbox.
0
0
fordraiders
Reply to  Diane Poremsky
May 5, 2016 1:50 am
Yes, They are in outbox..
0
0
Author
May 5, 2016 9:08 am
If there are messages, you should always get that warning message. There are scripts available that will respond to dialogs (such as ClickYes) - you might be able to incorporate that into the macro.
0
0
Latest EMO: Vol. 30 Issue 38
wpDiscuz
Never see this message again.
Move Comment
