While this reason for this article no longer exists now that Exchange ActiveSync connectivity to Outlook.com has been shut down, this macro remains a useful example demonstrating how to read a message header using a macro.
You can view the Internet Header in the File, Properties dialog, in a really tiny text box. (You can save a step by adding the Message Properties command the ribbon. It's under All Commands when you customize the ribbon.)
To make it easier to see the just the recipients, use a macro to display the CC or BCC addresses in a message box. Create a button on the ribbon to run the macro, then select a message and click the button to display a message box containing the BCC addresses.
If you need a copy of the recipients, click on the message box and press Ctrl+C to copy.
Sub ViewBCCAddresses()
Const PR_TRANSPORT_MESSAGE_HEADERS = "http://schemas.microsoft.com/mapi/proptag/0x007D001E"
Dim Reg1 As Object
Dim M1 As Object
Dim M As Object
Dim strHeader As String
Dim strBCC As String
Dim olkPA As Outlook.PropertyAccessor
Set olMail = Application.ActiveExplorer.Selection.Item(1)
Set olkPA = olMail.PropertyAccessor
strHeader = olkPA.GetProperty(PR_TRANSPORT_MESSAGE_HEADERS)
Debug.Print strHeader
Set Reg1 = CreateObject("VBScript.RegExp")
With Reg1
.Pattern = "(CC[:]\s(.*)\n)"
.Global = False
If Reg1.test(strHeader) Then
Set M1 = Reg1.Execute(strHeader)
For Each M In M1
strBCC = M.SubMatches(1)
MsgBox strBCC
Set M = Nothing
Set M1 = Nothing
Set Reg1 = Nothing
Set olMail = Nothing
How to use the macro
To check your macro security in Outlook 2013, go to File, Options, Trust Center and open Trust Center Settings, and change the Macro Settings.
- Right click on Project1 and choose Insert > Module
- Copy and paste the macro into the new module.
- Go to File, Options, Customize Ribbon
- On the right, select Home then click New Group
- Select Macros from the Choose Commands From dropdown
- Select the ViewBCCAddresses and click Add to add it to the group.
- Click Rename to give the button a friendly name and select and icon.
Leave a Reply
