Get Outlook's Internet Headers using VBA or PowerShell
› Developer › Code Samples › Get Outlook’s Internet Headers using VBA or PowerShell
Last reviewed on November 25, 2024     45 Comments
Use this code sample and function to display the Internet header of selected message in a new message form.
Read Internet Header
Tested in Outlook 2013, 2019, 2021, and Outlook 365, also works in Outlook 2010 and 2007.
The PowerShell version does not require you to change Outlook security settings. to use, select one or more messages then run the script.
clear
$PropName = "http://schemas.microsoft.com/mapi/proptag/0x007D001E"
$olFolder = ($olApp.ActiveExplorer())
$Selection = $olFolder.Selection
foreach ($olMsg in $Selection) {
$oPA = $olMsg.PropertyAccessor
$value = $oPA.GetProperty($PropName)
$Mail = $olApp.CreateItem(0)
$ndatetime = Get-Date -Format g
$Mail.Subject = $olMsg.subject + ' ' +$ndatetime
$Mail.Body = $value
$Mail.display()
Save it as a *.ps1 then right-click and choose Run with PowerShell.
Or create a shortcut and pin it to the taskbar or Start menu. The target will be
powershell.exe -file "C:\path\to\filename.ps1"
Note: Windows will add the full path to powershell.exe to the shortcut.
Create a shortcut to run the powershell script
VBA method to get message header
Sub ViewInternetHeader()
    Dim olItem As Outlook.MailItem, olMsg As Outlook.MailItem
    Dim strheader As String
    For Each olItem In Application.ActiveExplorer.Selection
        strheader = GetInetHeaders(olItem)
        Set olMsg = Application.CreateItem(olMailItem)
        With olMsg
            .BodyFormat = olFormatPlain
            .Body = strheader
            .Display
    Set olMsg = Nothing
Function GetInetHeaders(olkMsg As Outlook.MailItem) As String
    ' Purpose: Returns the internet headers of a message.'
    ' Written: 4/28/2009'
    ' Author:  BlueDevilFan'
    ' //techniclee.wordpress.com/
    ' Outlook: 2007'
    Const PR_TRANSPORT_MESSAGE_HEADERS = "http://schemas.microsoft.com/mapi/proptag/0x007D001E"
    Dim olkPA As Outlook.PropertyAccessor
    Set olkPA = olkMsg.PropertyAccessor
    GetInetHeaders = olkPA.GetProperty(PR_TRANSPORT_MESSAGE_HEADERS)
    Set olkPA = Nothing
End Function
Write the header to a text file
This version of the above macro writes the header to a text file and opens it in Notepad. (You'll need the Function GetInetHeaders from above).
If you want to open it in another Text application, replace "notepad " with the file path and name, making sure to leave the space after the filename.
' ### write to a text file
Dim FSO As Object
Dim strFile As String
Dim strFolderpath As String
Set FSO = CreateObject("Scripting.FileSystemObject")
' save to documents
strFolderpath = CreateObject("WScript.Shell").SpecialFolders(16)
    strFile = strFolderpath & "\header.txt"
Set objFile = FSO.CreateTextFile(strFile, True) ' True overwrites the file
Debug.Print strFile
    objFile.Write "" & strheader
    objFile.Close
 Call Shell("notepad.exe " & strFile, vbNormalFocus)
' ### end write to text file
    Set olMsg = Nothing
Get Specific Values from the header
But combining RegEx and the macro above we can get specific values out of the header. In this example, we're getting the address in the Return-Path.
If you need two or more values, you'll use a Case statement to loop through the header. See Get two (or more) values from a message for an example.
Sub GetValuesFromInternetHeader()
    Dim strHeader As String
    Dim strResult As String
    Dim strResults As String
    Dim Reg1 As Object
    Dim M1 As Object
    Dim M As Object
        strHeader = GetInetHeaders(olItem)
      Set Reg1 = CreateObject("VBScript.RegExp")
    With Reg1
        .Pattern = "(Return-Path:\s(.*))"
        .Global = True
    If Reg1.test(strHeader) Then
        Set M1 = Reg1.Execute(strHeader)
        For Each M In M1
' 0 = everything in the first set of ()
' 1 = everything in the second set of ()
        Debug.Print M.SubMatches(0)
        strResult = M.SubMatches(1)
' do something with the result
        strResults = strResult & vbCrLf & vbCrLf & strResults
        With olMsg
            .Body = strResults
            .Display
    Set olMsg = Nothing
    ' Outlook: 2007'
    Dim olkPA As Outlook.propertyAccessor
    Set olkPA = olkMsg.propertyAccessor
    Set olkPA = Nothing
End Function
Send a Spam Report
If you need to send a spam report to your ISP, you can use a macro to automate it. This macro will work on one message or a selection of messages.
If the macro is not creating a body that can be processed by the reporting service, try changing the 0x007D001E value to 0x007D001F. This returns PR_TRANSPORT_MESSAGE_HEADERS_W instead of PR_TRANSPORT_MESSAGE_HEADERS. See Geldner's thread and answer here: Problem submitting SPAM using Outlook VBA Form
Sub ForwardSpam()
    Dim strFWHeader As String
    Dim strNote As String
    strNote = "boilerplate note, if needed"
      Set olMsg = olItem.Forward
       With olMsg
        .To = "report@address.com"
        .Body = strNote & vbCrLf & vbCrLf & strHeader & vbCrLf & vbCrLf & olItem.Body
        .Display ' change to .send when satisfied
    olItem.Delete
    Set olMsg = Nothing
    ' Outlook: 2007'
    Set olkPA = Nothing
End Function
Using PowerShell Scripts
bulk change contact fields
PowerShell ise
Saving PowerShell Scripts
How to use macros
Retrieving Internet Headers Using VBA in Outlook 2007/2010 Includes a code sample to use with Run a Script rule.
For Outlook 2003 and older, see Get Internet header VBA code sample for Outlook 2003.
Get Outlook's Internet Headers using VBA or PowerShell was last modified: November 25th, 2024 by Diane Poremsky
  • View the CC or BCC Addresses in a Sent Message
  • Use VBA code sample to view Outlook's Internet Header.
    Get the Internet Header VBA Code Sample for Outlook
  • Use an Outlook Macro to Send Files by Email
  • Change the email account on received email
Subscribe
Notify of
45 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Frederic
September 22, 2024 1:09 pm
It would be nice to be able to get a specific part of the Internet Headers, for instance the Reply-To adress, and to display it in a new column (custom view). Very useful against spoofing ! I have tried to design a custom form for this purpose... but to no avail...
0
0
Author
Reply to  Frederic
September 23, 2024 12:30 am
That is possible, using propertyaccessor or regex to find a value in the header.
https://www.slipstick.com/developer/read-mapi-properties-exposed-outlooks-object-model/
https://www.slipstick.com/developer/code-samples/outlooks-internet-headers/#values
use .Pattern = "(Reply-To:\s(.*))"
0
0
Tom Geldner
September 9, 2022 4:07 pm
Is there an easy way to mod the Spam Report macro so that it strips any blank lines from the header when creating the email report? Outlook, for some reason, often creates blank lines in headers and it causes SPAMCOP.NET to choke.
0
0
steve
April 22, 2022 11:24 am
this is excellent.
How do I create a text file with the exact same information as the email that the 1st macro made?
0
0
Author
Reply to  steve
April 22, 2022 12:11 pm
Use this in place of the code that creates a message in the first macro
Dim FSO As Object
' save to documents
Set objFile = FSO.CreateTextFile(strFile, True) ' use False if you don't want to overwrite
Debug.Print strFile
    objFile.Close
1
0
Steven
Reply to  Diane Poremsky
April 22, 2022 12:32 pm
wow, thanks.
very helpful.
0
0
Steven
April 22, 2022 12:41 pm
So much information! Wow.
Is there any way to filter the header and only write the date/time received to the text file? Is there a way to break out each piece of information, like recipient?, sender?
Are all of these 'Objects'?
0
0
Author
Reply to  Steven
April 22, 2022 1:12 pm
You can get anything out of the header using regex, but the common fields are in vba - receivedtime, subject, sendername and senderemailaddress, recipient all are stored in fields accessible by VBA.
Get the fields, then write the strings to the text file.
With olItem
strName = .SenderName
strSender = .SenderEmailAddress
strTime = .ReceivedTime
0
SteveB
October 29, 2019 4:26 pm
I just figured out that it'll work..... just not with a user form.
Would you be willing to modify it to work with a user form, or to put an output into a user form/label on a form?
0
0
Steve Buckley
October 29, 2019 4:18 pm
Hi.
In trying the code for the first one above, I get a run time error on the
.display under the With operation.
It tells me that it cannot perform that operation because a dialogue box is open, and needs to be closed. I have two dialogues open.
1- the program itself.
2- the user form I've created. I close the user form, and it still throws the error.
With olMsg
            .Body = strheader
            .Display
I'm using office 365.
0
Rainer
September 6, 2018 4:38 am
Supercallifragilisticexpialidocious
Well done. Thank's a lot!
0
0
Rajan
July 16, 2018 9:38 am
Thanks for your code . would you please me , i want to add some condition to code after extraction of few details. such as ; Reply To; From; To; and etc.
please help me to add some condition on it.
Thanks in advance.
0
0
Rajan
July 2, 2018 4:11 am
Thanks for your code . it was really helpful to me . in the email headers i was trying to remove particular line from every header.
"h=sender:from:reply-to:to:subject:mime-version:content-type:list-unsubscribe:x-report-abuse:form-sub;"
please help me to find solution on this .
0
0
Author
Reply to  Rajan
July 3, 2018 11:22 pm
you'll change the pattern to find it...
.Pattern = "(h=(.*)-sub)"
Do you actually need to remove it from the header or need to copy it out of the header? VBA can't edit the internet header - you may be able to use Redemption (outlookspy.com) to edit it but i don't have code samples. If the line nver changes, you can use the replace function to remove it.
0
0
Rajan
July 11, 2018 5:38 am
Thanks for response,
From the header i am extracting few details , such as;
.Pattern = "(To:\s(.*))"
but in result i am getting this , as both Contains To: ,
can u help to get exact match of string what i am searching . as code is not understanding that i am looking only for "To" not
"Reply-to."
Reply-To: Jon Luchette
To: Ernie Bourassa
0
0
Latest EMO: Vol. 31 Issue 3
  • Syncing Outlook with an Android smartphone
wpDiscuz
Never see this message again.
Move Comment
