Delay Delivery of Messages Sent at Specific Times
› Developer › Code Samples › Delay Delivery of Messages Sent at Specific Times
Last reviewed on February 13, 2018     55 Comments
An Outlook user, KT, wanted to defer delivery of messages sent after 6PM, sending them at 7 AM the next day. This is possible to do using an ItemSend macro.
defer messages
If it's after 6PM or before 7AM, the message is held until 7AM, then sent. Because this is an Outlook script, it only works in Outlook. It will not affect messages sent using smartphones or other devices.
"Set a default 'Do not Deliver before' time" and "To delay sending a message in Outlook"
May 6 2017: Edited the macros to properly move early morning messages ahead a few hours, not 1 day and to account for messages sent Sat or Sun.
' If after 6PM
  If Now() > DateSerial(Year(Now), Month(Now), Day(Now)) + #5:59:00 PM# Then
    SendAt = DateSerial(Year(Now), Month(Now), Day(Now) + 1) + #7:00:00 AM#
' If before 7AM
  ElseIf Now() < DateSerial(Year(Now), Month(Now), Day(Now)) + #6:59:00 AM# Then
    SendAt = DateSerial(Year(Now), Month(Now), Day(Now)) + #7:00:00 AM#
 Item.DeferredDeliveryTime = SendAt
If you need to skip weekends (or other days of the week), check the name of the day and add additional time to the SendAt time.
Dim dayname As String
' If after 6PM
    sendat = DateSerial(Year(Now), Month(Now), Day(Now) + 1) + #7:00:00 AM#
' If before 7AM
    sendat = DateSerial(Year(Now), Month(Now), Day(Now)) + #7:00:00 AM#
' We'll test the date of all messages
 ElseIf WeekdayName(Weekday(Now())) = "Saturday" Or WeekdayName(Weekday(Now())) = "Sunday" Then
   ' this will be changed by the next part if a weekend
   sendat = DateSerial(Year(Now), Month(Now), Day(Now)) + #11:00:00 PM#
dayname = WeekdayName(Weekday(sendat))
Select Case dayname
Case "Saturday"
    sendat = DateSerial(Year(Now), Month(Now), Day(Now) + 2) + #7:00:00 AM#
Case "Sunday"
    Item.DeferredDeliveryTime = sendat
Debug.Print Now(), dayname, sendat
Only Delay message Sent to Specific Addresses
Sub Application_ItemSend(ByVal Item As Object, Cancel As Boolean)
Const PR_SMTP_ADDRESS As String = "http://schemas.microsoft.com/mapi/proptag/0x39FE001E"
Set recips = Item.Recipients
 For Each recip In recips
 Set pa = recip.PropertyAccessor
 Address = LCase(pa.GetProperty(PR_SMTP_ADDRESS))
 lLen = Len(Address) - InStrRev(Address, "@")
 Select Case Right(Address, lLen)
' add additional addresses as neeed, using quotes and comma separator
    Case "mcarnar@domain.com", "bburns@domain.com", "rchildars@domain.com", "curry@domain.com"
    Case Else ' remove case else line to be warned when sending to the addresses
     strMsg = strMsg & " " & Address & vbNewLine
' using <> delays these addresses only;
' use = to delay all but these addresses
If strMsg <> "" Then
' If after 6PM
' If before 7AM
How to use the macro
To check your macro security in Outlook 2010 or 2013, go to File, Options, Trust Center and open Trust Center Settings, and change the Macro Settings. In Outlook 2007 and older, it’s at Tools, Macro Security. If Outlook tells you it needs to be restarted, close and reopen Outlook. Note: after you test the macro and see that it works, you can either leave macro security set to low or sign the macro.
    macro in the VBA editor
Delay Delivery of Messages Sent at Specific Times was last modified: February 13th, 2018 by Diane Poremsky
  • Set a default 'Do not Deliver before' time
  • Add Attachments and Set Email Fields During a Mail Merge
  • Create Outlook appointments using multiple recurring patterns
  • Create a deferred Birthday message for an Outlook Contact
Subscribe
Notify of
55 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Victor Ivanidze
December 11, 2021 12:55 pm
There exists the add-in for Outlook named OffHours that ensures that emails you write after business hours and on weekends are delayed and will only be sent at the start of the next business day: https://www.ivasoft.com/offhoursaddin.shtml
0
0
Adam
January 8, 2021 11:20 am
This is super - thank you so much! All our student email addresses start with "ST0000". I would like to delay delivery to students only between 3pm-8:30am and at weekends for any emails sent to to addresses beginning with/containing "ST0000". Would this be possible? My knowledge of VBA is relatively basic.
0
0
Ahmad Banki
December 7, 2020 2:10 am
Hi Diane & thanks a lot. Two questions:
  1. I tried the code for deferring the weekends, but it doesn't seem to work. I don't get an error message, but when I send something between 8AM-6PM on a weekend, it still gets sent.
  2. About the recipient not seeing the exact time when I wrote the message, you referred to https://www.slipstick.com/developer/send-email-outlook-reminders-fires/#draft, but is this something to do for every message separately? Or is there a universal formula which would apply to all message? Basically I want the time which appears on the message (to the recipient) to be the 7 AM as opposed to the evening/midnight!
Thanks again.
0
0
Author
Reply to  Ahmad Banki
December 7, 2020 10:14 am
On the sent time macro - the one in your links sends all drafts when the reminder fires. I have similar macro that would sends drafts at different times. You put the time you want to send them messages in the subject and the macro runs on s schedule - anything with a date older than that will be sent when the macro runs.
This gives me an idea - instead of looking at the subject, add a defer until time and look at that in the draft. Off to find the macro and tweak it. :)
0
0
Jean-Marc
September 20, 2020 4:11 am
Thank you so much Diane. Your post did exactly what I needed.
It was a while since Dom asked two years ago about SendAt not being defined. The trick is to define SendAt like this:
Dim SendAt As Date
The problem is caused by Option Explicit at the top (which is a good idea and should not be removed according to me)
1
0
Evaristo
July 26, 2020 9:33 am
Would this be a good way to address the issues of sending e-mails on Friday and Saturday from 6PM to 11:59PM?
' If Friday after 6PM
If WeekdayName(Weekday(Now())) = "Friday" And Now() > DateSerial(Year(Now), Month(Now), Day(Now)) + #5:59:00 PM# Then
sendat = DateSerial(Year(Now), Month(Now), Day(Now) + 3) + #8:00:00 AM#
' If Saturday
ElseIf WeekdayName(Weekday(Now())) = "Saturday" Then
sendat = DateSerial(Year(Now), Month(Now), Day(Now) + 2) + #8:00:00 AM#
' If Sunday
ElseIf WeekdayName(Weekday(Now())) = "Sunday" Then
sendat = DateSerial(Year(Now), Month(Now), Day(Now) + 1) + #8:00:00 AM#
' If other week days after 6PM
 ElseIf Now() > DateSerial(Year(Now), Month(Now), Day(Now)) + #5:59:00 PM# Then
' If other week days before 8AM
 ElseIf Now() < DateSerial(Year(Now), Month(Now), Day(Now)) + #7:59:00 AM# Then
   sendat = DateSerial(Year(Now), Month(Now), Day(Now)) + #8:00:00 AM#
0
Author
Reply to  Evaristo
December 7, 2020 8:56 am
That should work. (I didn't test it though - but it looks good.)
1
0
Jaime Uribe
May 24, 2020 9:16 pm
Hi. It helped me a lot. Thank you
0
0
Jamie
May 23, 2020 9:11 am
Hi Diane, I am just starting out with Macros -- have never had to do this before. This is exactly what I am looking for. I'm using Outlook 2016. Even though I copy/paste this macro into ThisOutlookSession, when I hit play, it brings up the Macros dialog box (with run, cancel, step intro) and there is nothing to select there. I am missing a step somehow. What am I doing wrong?
0
0
Jamie
Reply to  Jamie
May 24, 2020 9:27 am
THis is my comment- Please reject it because it is awaiting moderation -- it seems to be working now -- I have a different question that I am going to post in your forums, which I just saw now.
0
0
Andi
January 12, 2020 2:42 am
Thanks a lot for the great article. It is a bit older, but I still have a question. I tried your macro and it works perfectly, but the time the email is sent is still the time when I hit send. Meaning the receipient sees the time when I actually sent the message. Is there a way to set the time displayed in the message header to match the time it actually leaves my outbox or at least when the timer expires?
Thanks a lot,
Best Regards
Andreas
0
0
Author
Reply to  Andi
January 13, 2020 12:47 am
No, not using this method. If you use an appointment reminder to trigger the send, it will have the current time. The reminder will trigger a macro that sends a draft.
0
0
Latest EMO: Vol. 31 Issue 3
wpDiscuz
Never see this message again.
Move Comment
