Problem: Outlook won't open forwarded messages (*.MSG)
› Problems › Problem: Outlook won’t open forwarded messages (*.MSG)
Last reviewed on February 11, 2018     No Comments
If you receive an error when opening forwarded messages (sent as attachments), uninstall Google Desktop Search or revert to the previously installed version.
Reports indicate that opening Settings, Options and removing the check from the "Use Documents and Spreadsheets to open certain file types" box corrects the problem without uninstalling GDS. If it doesn't help, you'll need to uninstall GDS.
If you use Outlook 2003 SP3 and have a large number of attachments or a large number of recipients on the message, see You cannot open an .msg e-mail message file in Outlook 2003 after you install Office 2003 Service Pack 3
Problem: Outlook won't open forwarded messages (*.MSG) was last modified: February 11th, 2018 by Diane Poremsky
  • Opening XML files in Outlook
  • Open .eml Files in Outlook
  • Up-to-date antivirus definitions on each desktop will help prevent mos
    Should you use client side antivirus scanning in Outlook?
  • Messages are stuck in the Outbox
Subscribe
Notify of
0 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Latest EMO: Exchange Messaging Outlook 2026 Archives
wpDiscuz
Never see this message again.
Move Comment
