Paste clipboard contents using VBA
› Developer › Code Samples › Paste clipboard contents using VBA
Last reviewed on December 4, 2018     73 Comments
I need a macro that adds a specific text, plus the content of my clipboard, at the end of the subject of all messages I have selected. How do I get the content of the clipboard automatically, without first pasting it into an Input Box?
Although Outlook VBA doesn't include a paste from clipboard function directly, you can use the MSForms dataobject to transfer the clipboard contents to a string which is then called from VBA. You could also use use the Word object model to copy the message body to the clipboard.
You can also use Word's 'Keep Source Formatting' to paste formatted text into an Item Body. Code sample is at Paste formatted text using VBA
Add code similar to this to your macro:
 Dim DataObj As MSForms.DataObject
 Set DataObj = New MSForms.DataObject
 DataObj.GetFromClipboard
strPaste = DataObj.GetText(1)
The finished code will look something like the following. Note, you will need to have a reference to the Forms library in Tools, References.
Add the forms library as a reference
If you receive a "User-defined type not defined" you are missing the reference to Microsoft Forms 2.0 Object Library. If its not listed, add C:\Windows\System32\FM20.dll or C:\Windows\FM20.dll as a reference.
Sub AddtoSubject()
 Dim ex As Explorer
 Dim mail As MailItem
 Set ex = Application.ActiveExplorer
 Dim strPaste  As Variant
If strPaste = False Then Exit Sub
If strPaste = "" Then Exit Sub
 For Each mail In ex.Selection
    mail.Subject = mail.Subject & " my text " & strPaste
    mail.Save
 Next mail
Set DataObj  = Nothing
Copy to Clipboard
What about going in the other direction: copying text to the clipboard? Use PutInClipboard to capture the text.
Remember, if you receive a "User-defined type not defined" you are missing the reference to Microsoft Forms 2.0 Object Library. If its not listed, add C:\Windows\System32\FM20.dll or C:\Windows\FM20.dll as a reference.
Sub CapturetoClipbaord()
Dim oMail As MailItem
    Set oMail = ActiveExplorer().Selection.Item(1)
    DataObj.SetText oMail.Body
    DataObj.PutInClipboard
Use Word Object Model to Copy (and Paste)
Current versions of Outlook use Word as the email as the email editor and can use the Word object model library to do things not normally supported in Outlook.
This sample copies the body of the selected message to the clipboard. To paste, use
objSel.PasteAndFormat (wdFormatOriginalFormatting)
Don't forget to set a reference to Word's Object model in Tools, References.
Sub CopyMessage()
    Dim objInsp As Inspector
    Dim objDoc As Word.Document
    Dim objSel As Word.Selection
Set objMail = Application.ActiveExplorer.Selection.Item(1)
  If Not objMail Is Nothing Then
        If objMail.Class = olMail Then
            Set objInsp = objMail.GetInspector
        With objSel
            .WholeStory
            .Copy
    Set objMail = Nothing
This sample shows how to paste the copied content into a new message:
Set objMail = Application.CreateItem(olMailItem)
With objMail
  .To = "Alias@domain.com"
  .Subject = "This is the subject"
  .Display
Paste format types are below. For more information see WdRecoveryType Enumeration (Word).
NameDescription
wdChartPastes a Microsoft Office Excel chart as an embedded OLE object.
wdChartLinkedPastes an Excel chart and links it to the original Excel spreadsheet.
wdChartPicturePastes an Excel chart as a picture.
wdFormatOriginalFormattingPreserves original formatting of the pasted material.
wdFormatPlainTextPastes as plain, unformatted text.
wdFormatSurroundingFormattingWithEmphasisMatches the formatting of the pasted text to the formatting of surrounding text.
wdListCombineWithExistingListMerges a pasted list with neighboring lists.
wdListContinueNumberingContinues numbering of a pasted list from the list in the document.
wdListDontMergeNot supported.
wdListRestartNumberingRestarts numbering of a pasted list.
wdPasteDefaultNot supported.
wdSingleCellTablePastes a single cell table as a separate table.
wdSingleCellTextPastes a single cell as text.
wdTableAppendTableMerges pasted cells into an existing table by inserting the pasted rows between the selected rows.
wdTableInsertAsRowsInserts a pasted table as rows between two rows in the target table.
wdTableOriginalFormattingPastes an appended table without merging table styles.
wdTableOverwriteCellsPastes table cells and overwrites existing table cells.
wdUseDestinationStylesRecoveryUses the styles that are in use in the destination document.
Paste clipboard contents using VBA was last modified: December 4th, 2018 by Diane Poremsky
  • Paste Formatted Text Using VBA
  • Change Short Date to Long Date Format in a Message
  • Copy a Contact's Mailing Address
  • Create Task or Appointment and Insert Selected Text
Subscribe
Notify of
73 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Pierre-Henry Delecourt
May 25, 2020 3:26 am
Hi. Thanks a lot for this useful tip. I however can't fidn the reference to Microsoft Form, nor the FM20.dll library.
I bought the Microsoft Office in September 2019. Is there a new name for this library ?
Many thanks in advance
0
0
Author
Reply to  Pierre-Henry Delecourt
December 23, 2020 12:02 am
You need to click Browse and paste the path in. C:\Windows\System32\FM20.dll
1
0
Said
May 22, 2020 3:19 pm
Is there a way to paste a picture from clipboard directly using VBA?
0
Author
Reply to  Said
June 5, 2020 12:43 am
No, not in Outlook. You need to use the word object. (Could probably use Excel's object model too.)
0
0
Victor
April 1, 2020 7:09 pm
How can you save clipboard content to a folder in Word without using userform even if it is using the windows api
0
0
Author
Reply to  Victor
April 1, 2020 11:00 pm
As far as I know, you need to use the msforms data object -
0
0
dfa
October 27, 2017 8:42 am
Thank you for the info
0
0
Rudy
October 21, 2017 3:33 am
This is so helpful. Thanks Admin and all the member of this page.
0
0
Lu(ky
August 23, 2017 11:56 am
How can "Sub CopyMessage" be modified to copy text up to the first "From" in an email (copy text from the most recent email reply)?
0
0
Author
Reply to  Lu(ky
August 23, 2017 12:21 pm
You'd need to find it the select everything above it -
With objSel
.Find.ClearFormatting
With objSel.Find
.Text = "From: "
.Replacement.Text = ""
.Forward = True
.MatchCase = False
.MatchWholeWord = False
.MatchWildcards = False
.Execute
.MoveUp Unit:=wdLine, Count:=1
.HomeKey Unit:=wdLine, Extend:=wdExtend
.MoveUp Unit:=wdScreen, Count:=1, Extend:=wdExtend
' .WholeStory
.Copy
0
Lu(ky
Reply to  Diane Poremsky
August 23, 2017 12:36 pm
I'm sorry, I'm having trouble implementing this new code into the older code. I appreciate the fast reply and help!
0
0
Author
Reply to  Lu(ky
October 8, 2017 11:05 pm
I would need to see the code to help.
0
0
Lu(ky
August 24, 2017 10:14 am
Unfortunately the above code does not locate the text "From"... the Sub still copies the entire email body. Any suggestion?
0
0
Author
Reply to  Lu(ky
October 8, 2017 11:04 pm
correct, it only copies the body. you need to use oMail.sendername or oMail.senderaddress to get the frm information.
0
0
Lu(ky
August 24, 2017 11:57 am
I got it to work! Thank you for your help!!
0
0
Adam
April 6, 2017 1:08 pm
Hello Diane, I'm have a need to pass the value of a highlighted text within an email body directly to a URL. so basically, I would double-click (select) on a specfic key word, click some button on my ribbon and have that run a macro to take the selected key word and insert it into a pre-defined URL. I already have the URL code working. I'm stuck trying to get the selected keyword (in the email message body) copied and passed in my code. I'm not trying to copy the entire message body. Any ideas? Thank you!
0
0
Author
Reply to  Adam
May 26, 2017 9:50 am
Try using just .copy, removing .wholestory.
With objSel
.Copy
0
Jason Johnson
March 13, 2017 11:16 am
I'm trying to paste a collection of Excel cells I've copied into the clipboard into an Outlook email's .body. I'm trying to paste using destination styles so as to preserve the table grid of the cells I'm copying from my spreadsheet. While I can dump the contents unformatted easily from the clipboard, I can't seem to get anything to work using the Word references for using destination styles. I've tried playing around with the code in this post but no joy. Any help would be greatly appreciated.
0
0
Author
Reply to  Jason Johnson
March 16, 2017 1:32 pm
You definitely need to use the word code https://www.slipstick.com/developer/code-samples/paste-clipboard-contents-vba/#word
do you get any error messages?
This should work to paste -
objSel.PasteAndFormat (wdUseDestinationStylesRecovery)
Valid Format types are here: https://msdn.microsoft.com/en-us/library/office/ff844915.aspx
0
0
Latest EMO: Vol. 31 Issue 3
wpDiscuz
Never see this message again.
Move Comment
