VBA: No attachments to CC'd recipients
› Developer › Code Samples › VBA: No attachments to CC’d recipients
Last reviewed on November 5, 2012     6 Comments
Use this macro to send an attachment to email addresses in the To line and CC others with just the message.
Work in progress: the attachment script needs to be changed to save it to a file share.
Sub CCNoAttachments()
    Dim objMsg As Outlook.MailItem
    Dim oItem As Object
    Set objApp = Application
    Set oItem = objApp.ActiveInspector.CurrentItem
        CopyAttachments oItem, objMsg
        objMsg.CC = oItem.CC
        objMsg.Subject = oItem.Subject
        objMsg.Body = objMsg.Body & "Sent to: " & oItem.To & vbCrLf & vbCrLf & oItem.Body
' This results in a nicely formatted body but may not work well if you use RTF or plain text
       ' objMsg.HTMLBody = objMsg.Body & " Sent to: " & oItem.To & vbCrLf & vbCrLf & oItem.HTMLBody
       objMsg.Display
' Remove CC addresses
    oItem.CC = ""
    Set objMsg = Nothing
    Set oItem = Nothing
Sub CopyAttachments(objSourceItem, objTargetItem)
   Set fso = CreateObject("Scripting.FileSystemObject")
   Set fldTemp = fso.GetSpecialFolder(2) ' TemporaryFolder
   strPath = fldTemp.Path & "\"
   For Each objAtt In objSourceItem.Attachments
      strFile = strPath & objAtt.FileName
      objAtt.SaveAsFile strFile
' include the filename, although if you only want to use the filename, using
' oItem.Attachments.Item(i).FileName in the main macro would be better
   objTargetItem.Body = "Included file: " & objAtt.FileName
' include the full path to the file
'   objTargetItem.Body = "Included file: " & strFile
   Set fldTemp = Nothing
   Set fso = Nothing
Create the second message on Send
This macro looks at all messages you send and any message that contains an attachment is processed. The CC'd members receive a copy of the message with the attachment filename(s) and a list of people the message was sent to.
Note: This macro applies to all messages with attachments, which includes images in signatures.
    Dim i As Long
    Dim strFile As String
If Item.Attachments.Count > 0 Then
For i = 1 To Item.Attachments.Count
strFile = Item.Attachments.Item(i).FileName & "; " & strFile
Next i
        objMsg.CC = Item.CC
        objMsg.Subject = Item.Subject
        objMsg.HTMLBody = strFile & " Sent to: " & Item.To & vbCrLf & vbCrLf & Item.HTMLBody
        objMsg.Send
    Item.CC = ""
' End If
VBA: No attachments to CC'd recipients was last modified: November 5th, 2012 by Diane Poremsky
  • Delete attachments from messages
  • Save and Delete Attachments from Outlook messages
  • Add Attachment Names to Message Before Sending
  • Save Messages and Attachments to a New Folder
Subscribe
Notify of
6 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Linas
March 20, 2014 10:32 am
Thank you, Diane. By "Notify" I meant adding text "Attachments were removed" to the forwarded message body if it had attachments before.
Two questions:
1. Will your script leave the attachments in the original email box and remove only in forwarded message? I would like remove attachments only in forwarded message.
2. Should I add your suggested script right after "Sub AutoForwardAllSentItems(Item As Outlook.MailItem)" line?
0
0
Reply to  Linas
March 20, 2014 2:24 pm
You can either check for attachments.count > 0 and add text that says 'attachments were removed' or use a more complicated macro that checks the size of at least one attachment - you could add the name of the attachment too.
I'd probably check the size at least, because an image in a signature is an attachment.
Something like
if oItem.Attachments.count > 0 then
For Each oAtt In oItem.Attachments
If oAtt.Size > 5200 Then
strAtt = "attachments removed"
Goto NextStep 'to exit this part, since we know at least one attachment is larger
End if
Next oAtt
end if
NextStep:
'reset of macro
1. Yes, the macro will only remove attachments from the forward, it's possible to remove them from the original message though too.
2. No, you should kind of merge them - using just the pieces you need.
0
0
Linas
March 5, 2014 1:30 pm
How to modify forwarding script below that it would forward emails without attachments and notify if attachments were removed?
Dim strMsg As String
Dim myFwd As Outlook.MailItem
Set myFwd = Item.Forward
myFwd.Recipients.Add "my10digitPhone@tmomail.net"
myFwd.Send
Set myFwd = Nothing
0
Reply to  Linas
March 19, 2014 12:30 am
Define "Notify" :) I have a macro at https://www.slipstick.com/developer/code-samples/insert-attachment-names-replying/ which adds the attachment name to a reply.
To delete attachments, you need something like this:
Set myAttachments = myItem.Attachments
lngAttachmentCount = myAttachments.count
' Loop through attachments until attachment count = 0.
While lngAttachmentCount > 0
myAttachments(1).Delete
Wend
0
0
Nadia
February 20, 2013 7:36 am
Diane, I was trying to use your Code for "No attachments to CC'd Recipients), and when I created it in Outlook, and run it, it stops at Set oItem = objApp.ActiveInspector.CurrentItem with the message "Object variable or With block variable not set". How wouold I fix this?
0
0
Reply to  Nadia
February 24, 2013 6:19 am
That means there is a typo in the code. It's odd that it stops there. You are running this with the message open on screen?
0
0
Latest EMO: Vol. 31 Issue 3
  • Syncing Outlook with an Android smartphone
wpDiscuz
Never see this message again.
Move Comment
