Forward Messages that were not Replied To
› Developer › Code Samples › Forward Messages that were not Replied To
Last reviewed on December 4, 2018     12 Comments
An Outlook user wanted to forward messages that were not replied to within a specific period of time. If the messages were still unreplied to later, he wanted to forward them to a different address.
To do this you need to check the last verb property (PR_LAST_VERB_EXECUTED) using propertyaccessor. If the last verb is not 102 (reply) or reply all (103) then check the received date. If it's older than 7 days then forward to address1; if older than 3 days, forward to address2. (By checking for older messages first, we avoid forwarding the same message to address2 a second time.)
More propertyaccessors for email can be found at Read MAPI properties not exposed in Outlook's Object Model
This macro runs only when you run it, but you could use the method described at Send an email when an Appointment reminder fires to trigger it using a reminder.
To change the folder the macro checks, see Working with VBA and non-default Outlook Folders. As written it checks the default Inbox but it can check in any folder, including a shared mailbox's Inbox.
Sub ForwardAgedMail()
    Dim objNamespace As Outlook.NameSpace
    Dim objSourceFolder As Outlook.MAPIFolder
    Dim objVariant As Variant
    Dim intCount As Integer
    Dim intDateDiff As Integer
    Dim propertyAccessor As Outlook.propertyAccessor
    Dim myForward As Outlook.MailItem
 'On Error Resume Next
    Set objOutlook = Application
    Set objNamespace = objOutlook.GetNamespace("MAPI")
    Set objSourceFolder = objNamespace.GetDefaultFolder(olFolderInbox)
    ' use a subfolder under Inbox
    For intCount = objSourceFolder.Items.Count To 1 Step -1
        Set objVariant = objSourceFolder.Items.Item(intCount)
        DoEvents
        If objVariant.Class = olMail Then
         Set propertyAccessor = objVariant.propertyAccessor
            If Not propertyAccessor.GetProperty("http://schemas.microsoft.com/mapi/proptag/0x10810003") = 102 _
            And Not propertyAccessor.GetProperty("http://schemas.microsoft.com/mapi/proptag/0x10810003") = 103 Then
              intDateDiff = DateDiff("d", objVariant.SentOn, Now)
            ' I'm using 7 days, adjust as needed.
            If intDateDiff > 7 Then
                'forward message
            Set myForward = objVariant.Forward
            myForward.To = "alias1@domain.com"
            myForward.Display
            ElseIf intDateDiff > 3 Then
            myForward.To = "alias2@domain.com"
            myForward.Display ' .send
Don't count weekends
Removing weekends (or holidays) from the count is more difficult. If the date span is 5 business days, this snippet should work. It checks the sent date and adds 2 to account for the weekend days.
Dim sentDate As Date
sentDate = objVariant.SentOn
Select Case Weekday(sentDate, vbUseSystemDayOfWeek)
  Case vbSunday
    sentDate = DateAdd("d", 1, sentDate)
  Case vbSaturday
    sentDate = DateAdd("d", 2, sentDate)
  Case vbFriday
  Case vbThursday
  Case vbWednesday
  Case vbTuesday
  Case vbMonday
  intDateDiff = DateDiff("d", sentDate, Now)
How to use macros
To view the last verb and last verb executed time in your email folders, see How to display the sender's email address in Outlook.
This macro is based off of the macro at Use a Macro to Move Aged Email in Outlook
DateDiff Function (Visual Basic) (MSDN)
Forward Messages that were not Replied To was last modified: December 4th, 2018 by Diane Poremsky
  • Macro to Move Aged Email Messages
  • Macro to file Outlook email by sender's display name
  • Set an expiration date on all messages you send
  1. Amir Hodzic says
    March 24, 2020 at 3:07 pm
    I'm using your example to collect all emails which I have sent to other recipients without them replying, into a separate folder. I manage to do that, however the emails in my new folder are only a handfull of the ones sent. I only see some mails which I've sent to myself or to my other email and other that were auto-generated from SharePoint on my behalf.
    Is it even possible to use the NOTEIVERB_REPLYTOSENDER or NOTEIVERB_REPLYTOALL property to accomplish this?
  2. marius says
    September 29, 2015 at 3:45 am
    Hi, i have your code for copy older emails and i added 2 if statements to check for sender address and subject but it doesn't work. Any help is welcomed. Thank you.
    DoEvents
    If objVariant.SenderAddress = "Alin@yahoo.com" Then
    If objVariant.Subject = "Client update" Then
    If Not propertyAccessor.GetProperty("https://schemas.microsoft.com/mapi/proptag/0x10810003") = 102 _
    And Not propertyAccessor.GetProperty("https://schemas.microsoft.com/mapi/proptag/0x10810003") = 103 Then
    Set objDestFolder = objNamespace.Folders("Mailbox - Marius").Folders("Inbox").Folders("zile arhivare").Folders("Ieri")
    If intDateDiff > -1 Then
    Set Copy = objVariant.Copy
    Copy.MOVE objDestFolder
  3. Robert says
    September 3, 2015 at 6:00 pm
    This works almost exactly the way I need, however, is there a way to forward messages from a specific sender that were not replied to. For example, anytime I receive a message from A@A.com and i do not reply within 3 days it forwards the message, but if I receive a message from B@A.com it does nothing?
    Thank you so much for your help.
      September 3, 2015 at 8:05 pm
      You can use an if statement after checking for the olmail type -
      If objvariant.senderaddress <> "a@a.com" then
      exit sub
      end if
  4. marius says
    September 3, 2015 at 9:26 am
    hi, it worked until now and now it gives me an error at : For intCount = objSourceFolder.Items.Count To 1 Step -1 .eny help is wolcomed. thank you.
  5. marius says
    September 3, 2015 at 7:59 am
    Hi, i made it :D ( thank you verry much ) . But if you will allow, i want to ask you if there is an way to search in a shared folder an email with the subject from an excel. the ideea is that i have some 200 names in an excel and i must manually search in an shared folder for email with the client name in the subject. Is there a way to make the search automatic and warn me if i have emails for a client name. Thank you.
  6. marius says
    September 3, 2015 at 3:23 am
    Hi how can i make this code to search in a shared inbox for those email that were not replied to? Now it searches in the personal inbox and i want to search in an office shared inbox. any help is welcomed. Thank you.
      September 3, 2015 at 7:48 am
      This tells it to look in the default inbox:
      replace it with this:
      Set objSourceFolder = GetFolderPath("Shared mailbox name\Inbox")
      and get the GetFolderpath function at https://www.slipstick.com/developer/code-samples/use-macro-assign-messages-shared-mailbox/#getfolderpath
  7. Dan says
    April 26, 2015 at 11:35 pm
    Dear Diana,
    Thanks for the response. How about being use of combination of ConversationIndex and ConversationID?
      April 27, 2015 at 12:28 am
      It could work, but not all mail clients/servers leave the conversation id in place. Adding a guid to the message body and searching on it would also work - when messages arrive, a macro looks for the guid and clears the matching flag or deletes the task. You could remove the guid from the body when a match is found so the macro won't keep searching for a match as this can slow outlook down if you are sending 200 messages a day.
  8. Dan says
    April 25, 2015 at 6:29 am
    Dear Diana,
    I have another question – sent on average about 100 to 200 messages / emails on daily basis. What I need is that an email / message sent from my account, if un-replied by recipient after two days after being sent, will be re-sent again with addition of a sentence such as reminder. How is that possible to be achieved?
      April 25, 2015 at 11:59 pm
      Checking for replies to messages you sent is more difficult and I don't have any code samples that can do it. It think Sperry software has a utility that monitors for replies and notifies you - i don't know if it can send a reminder to the recipient.
Latest EMO: Vol. 31 Issue 5
