Create a Custom Numbering Field for Outlook messages
› Developer › Code Samples › Create a Custom Numbering Field for Outlook messages
Last reviewed on August 31, 2016     2 Comments
An Outlook user wanted to know if she could assign a number or code to messages. She was tasked with copying messages from several mailboxes into one folder and wanted to number each message and code the messages so she could quickly see which mailbox the message came from.
Creat a custom field
This macro adds the "received by name" to a custom field; in most cases, this will be the mailbox name that received the message. The numbering starts at zero and remembers the last number used while Outlook is open. If you need to remember the last number used between Outlook sessions, you need to write the number to a file or registry (see second macro).
To use, add the macro to a module in the VB Editor, select some messages and run it. It works on selected messages in any folder.
Add an Index code to selected messages
This macro creates a custom field on each selected messages and adds a code to it, in the format of "mailboxname number". The field is sortable, although the numbers will sort as text, not numbers.
Dim i As Long
Public Sub CreateIndexCode()
    Dim Selection As Selection
    Dim obj As Object
    Dim strDomain As String, strAcct As String
    Dim propertyAccessor As Outlook.propertyAccessor
    For Each obj In Selection
' Add mailbox name
        Set propertyAccessor = obj.propertyAccessor
        strAcct = propertyAccessor.GetProperty("http://schemas.microsoft.com/mapi/proptag/0x0040001E")
         strDomain = strAcct & " " &  i
         Set objProp = obj.UserProperties.Add("Index", olText, True)
         objProp.Value = strDomain
        obj.Save
    i = i + 1
        Err.Clear
    Set currentExplorer = Nothing
    Set obj = Nothing
    Set Selection = Nothing
Write the last used value to the registry sample
This version of the macro writes the index number to the registry. This allows you to close and restart Outlook and pickup the numbering where you left off.
The field in this version is a number field. If you sort on it, it will sort in numerical order.
Public Sub SetIndex()
    Dim obj As Object
    Dim strIndex As String
    Dim sAppName As String
    Dim sSection As String
    Dim sKey As String
    Dim lRegValue As Long
    Dim lFormValue As Long
    Dim iDefault As Integer
 ' HKEY_CURRENT_USER\Software\VB and VBA Program Settings\Outlook\Index
    sAppName = "Outlook"
    sSection = "Index"
    sKey = "Last Index Number"
 ' The default starting number.
     iDefault = 101 ' adjust as needed
 ' Get stored registry value, if any.
     lRegValue = GetSetting(sAppName, sSection, sKey, iDefault)
 ' If the result is 0, set to default value.
     If lRegValue = 0 Then lRegValue = iDefault
         strIndex = lRegValue
' I'm using a number field - the field will sort correctly
         Set objProp = obj.UserProperties.Add("Index", olInteger, True)
         objProp.Value = strIndex
        obj.Save
    lRegValue = lRegValue + 1
        Err.Clear
   ' Increment and update invoice number at the end
     SaveSetting sAppName, sSection, sKey, lRegValue
    Set obj = Nothing
How to use macros
Create a Custom Numbering Field for Outlook messages was last modified: August 31st, 2016 by Diane Poremsky
  • Sort messages by Sender domain
  • Create a custom field for Outlook messages
  • Display the Recipient Email Address in the Sent Items Folder
  • Print Outlook Business Card Images
Subscribe
Notify of
2 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Ramesh Babu
September 3, 2014 6:04 am
Thank you so much for your support to the world!
I need your support in backing up emails.
Based on your posts, i had already wrote the macro to backup an email with date, time, from, To and subject. It works well! Instead of recording time i need to add serial number from 1 to x for the emails with same subject and same sender and receiver. This method is easy to sort the emails in the explorer folder based on sender and receiver. Can you please help ?
0
0
Reply to  Ramesh Babu
September 30, 2014 11:31 pm
Adding a serial number is easy, doing it by message is harder unless are doing it by conversations, one at a time. Otherwise you need to check each subject and track the last used serial, which can be difficult if you have a lot of different conversations.
0
0
Latest EMO: Vol. 31 Issue 3
wpDiscuz
Never see this message again.
Move Comment
