How to change the From field on incoming messages
› Developer › Code Samples › How to change the From field on incoming messages
Last reviewed on October 13, 2020     No Comments
I receive messages from a group address. The name in the From field is the team name and address. In the message header there are some specific words I can search for that identify the actual sender, for example From: Mike <team@mycompany.com>. Is it possible to set up a rule to see "Mike on behalf of Team" in the From field of these messages?
You can use a 'words in the header' rule to find a phrase as it appears in the header but you can't change what you see in the From field using straight VBA. It's not impossible to change, but you'll need to use Redemption (What is Redemption) to make changes to the display name (and any other field not writable by VBA.)
Sample code using redemption is below. You can look at the values using MFCMAPI to see what Outlook has for the sender name and representing name and see if both need changed or if you can use one value in the other field.
name changed in the header
After installing Redemption and selecting it in Tools, References, run this code to change the Sender's name to whatever you want. You'll need additional code to grab the name from the header.
The code sample at Get Outlook's Internet Headers using VBA can get the value from the header and the sample at Read MAPI properties not exposed in Outlook's Object Model shows how to get Outlook property values. To change the display name to match the name on the sender's contact, the code at Assign Categories to Messages using Contact Category shows how to do a Contact lookup.
Sub ChangeName()
Dim rSession As Redemption.RDOSession
Dim rMail As Redemption.RDOMail
Dim ID As String
Const PR_SENDER_NAME = &HC1A001E
Const PR_SENT_REPRESENTING_NAME = &H42001E
Set rSession = CreateObject("Redemption.RDOSession")
rSession.Logon
ID = Application.ActiveExplorer.Selection.Item(1).EntryID
Set rMail = rSession.GetMessageFromID(ID, Application.Session.DefaultStore.StoreID)
rMail.Fields(PR_SENDER_NAME) = "New Name"
rMail.Fields(PR_SENT_REPRESENTING_NAME) = "New Name"
rMail.Save
rSession.Logoff
Change the display name to match the Contact's Full Name
This example shows how to use the code to lookup a contact and get the full name to use as the sender name.
Public Sub ChangeSenderName()
Dim objMail As Object
Dim oContact As Outlook.ContactItem
Dim oSender
Dim strName As String
Set objMail = Application.ActiveExplorer.Selection.Item(1)
Set oSender = objMail.Sender
If Not oSender Is Nothing Then
  Set oContact = oSender.GetContact
     Set oSender = Nothing
       If Not oContact Is Nothing Then
        strName = oContact.FullName
        Set oContact = Nothing
Dim ID As String
rSession.Logon
rMail.Fields(PR_SENDER_NAME) = strName
rMail.Fields(PR_SENT_REPRESENTING_NAME) = strName
rMail.Save
rSession.Logoff
Change the display names on selected messages
If you want to run the macro on a group of selected messages, use the code below.
Public Sub ChangeSenderNameSelection()
Dim oSender
Dim Selection As Selection
Set objOL = Outlook.Application
Set currentExplorer = objOL.ActiveExplorer
For Each objMail In Selection
        strName = oSender
Dim ID As String
rSession.Logon
ID = objMail.EntryID
rMail.Save
strName = ""
rSession.Logoff
To use this macro, you need to set a reference to the Redemption object. If you receive a "User-defined type not defined" error, you did not the set reference.
  2. Locate the Redemption object library in the list and add a check mark to it.
Code samples to get the value from the header or other fields:
How to change the From field on incoming messages was last modified: October 13th, 2020 by Diane Poremsky
  • Assign Categories to Messages using Contact Category
  • Sort messages by Sender domain
  • Use VBA to read fields in attached messages
  • Print Outlook Business Card Images
Subscribe
Notify of
0 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Latest EMO: Vol. 30 Issue 36
wpDiscuz
Never see this message again.
Move Comment
