Send from Other Addresses using POP3 or IMAP Accounts
› Outlook › Send from Other Addresses using POP3 or IMAP Accounts
Last reviewed on June 24, 2015     3 Comments
A person is looking to return to the Outlook fold but has one problem:
Thunderbird allows me to have multiple identities on a single account. I know I can do different profiles in Outlook but at that point I might as well setup multiple accounts. Can it be done with an Exchange server account?
When you use POP3 or IMAP accounts, and you email host allows it, you can send mail from another email address by typing the address in the From field. Not all email hosts allow you to change the From address but if your email provider allows it, the message will be sent from that address.
Note that many mail providers will add your account name or email address in the header so spam or abusive messages can be traced. Others require you to add the addresses to your account and confirm you control the address before you can send from it.
If you don't see the From field on the message form enable it on the Options tab of an open message.
click Options, From to show the From field
When you want to send from another address, expand the From menu and select Other Email Address and type the address in the field. The next time you want to send from that address you can select it from the list.
choose other email address
You can use this method the redirect email to another address and have them appear to be from the original sender. To do so, open the message and click Actions, Resend This Message then click Send.
Note: this will not work with Exchange or Outlook.com accounts. You need special Send As permissions to send from other addresses when you use Exchange Server mailboxes.
While there are ways to send from other addresses when you use Exchange, it's not much easier. You'll need to have a mail contact or distribution group in the AD and have send as permission on it.
While I'm on this topic, I'll mention again that the new Outlook.com supports sending from Outlook.com aliases from Outlook. While it's always been possible to select an alias in the web interface, Outlook always used the account address. In the new Outlook.com, type the alias address in the From field and send. The recipient will see the alias.
Send from Other Addresses using POP3 or IMAP Accounts was last modified: June 24th, 2015 by Diane Poremsky
  • How to create a send-only POP3 account
  • Exchange Server and SMTP Servers
  • When you have an Exchange Server account in Small Business Server 2003
    Exchange Account Gets Set as the Default Account
Subscribe
Notify of
3 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
C. Yusuf Mumtaz
July 31, 2018 11:54 am
Outlook.com no longer shows the alias when you send from it. The header message reads "Sent on behalf of."
0
0
Author
Reply to  C. Yusuf Mumtaz
August 2, 2018 1:22 am
As long as its an outlook.com alias, it should show the address. (It does here.)
BTW, If you have outlook 2016, you dont need to use an imap or pop account for outlook.com aliases - you can select them in the From menu.
0
0
C. Yusuf Mumtaz
Reply to  Diane Poremsky
August 2, 2018 5:34 am
So, we should add it as an alias and not as a POP3 send-only account? Won't that still result in a "on behalf of" header?
Also, when I set up a send-only POP3 account in Outlook.com, the "on behalf of header" still comes up.
I'm trying to implement Inbox Zero and this is the only obstacle remaining for me. I would like my recipients to only see my work emails instead of the "Send on Behalf Of" header.
0
0
Latest EMO: Vol. 30 Issue 38
wpDiscuz
Never see this message again.
Move Comment
