Create Outlook appointments for every nn workday
› Developer › Create Outlook appointments for every nn workday
Last reviewed on May 3, 2018     12 Comments
One big complaint about Outlook recurrence patterns is that there is not a pattern for Every xx weekday (Monday - Friday). You can create appointments for specific days of the week, but the every xx days pattern includes Saturday and Sunday.
The solution: a macro that copies the appointment details to a new appointment, using a function to check the day of the week for each date. When a date falls on Saturday or Sunday, it jumps ahead to Monday.
Updated March 31 2017. Now using Chip Pearson's Workday2 function to skip Workdays, so it is now a proper "every xx weekday" macro. (Yes, it's an Excel macro but since the Office programs use pretty much the same functions, it works in Outlook too.) It will also check your default calendar for all day events marked busy to use in the Holiday array. It does not check recurring events!
To use, you need to create the first appointment and save it, then run the macro. Enter the number of days between appointments and the number of appointments you need to create. The macro copies the fields from the first appointment and creates new appointments every xx days. Note: these are not recurring appointments, but individual appointments.
It will work with either opened appointments or selected appointments thanks to the GetCurrentItem function.
Create Every xx Weekday Series
To use, press Alt+F11 to open the VB Editor. Expand the folders on the left and right click to Insert a new module. Paste the following code into a module. Create a new appointment and save it, then run the macro.
As written, the macro skips Saturday and Sunday (65). If your workweek has other days off, add the values listed in Enum EDaysOfWeek and change the value in nextDate = Workday2(currentDate, NumOfDays + 1, 65) and in nextDate = Workday2(nextDate, NumOfDays + 1, 65).
   Dim strAllDayOOF As String
' From http://www.cpearson.com/excel/BetterWorkday.aspx
' EDaysOfWeek
' Days of the week to exclude. This is a bit-field
' enum, so that its values can be added or OR'd
' together to specify more than one day. E.g,.
' to exclude Tuesday and Saturday, use
' (Tuesday+Saturday), or (Tuesday OR Saturday)
Enum EDaysOfWeek
    Sunday = 1      ' 2 ^ (vbSunday - 1)
    Monday = 2      ' 2 ^ (vbMonday - 1)
    Tuesday = 4     ' 2 ^ (vbTuesday - 1)
    Wednesday = 8   ' 2 ^ (vbWednesday - 1)
    Thursday = 16   ' 2 ^ (vbThursday - 1)
    Friday = 32     ' 2 ^ (vbFriday - 1)
    Saturday = 64   ' 2 ^ (vbSaturday - 1)
End Enum
Public Sub CreateSeriesofAppt()
  Dim objAppt As Outlook.AppointmentItem
  Dim objAppt2 As Outlook.AppointmentItem
  Dim NumOfDays As Long
  Dim NumAppt As Long
  Dim nextDate As Date
  Dim nextAppt
  Dim currentDate As Date
' Get the Holdiay list
 GetHolidays
' Don't forget the GetCurrentItem function at
' http://slipstick.me/e8mio
 Set objAppt = GetCurrentItem()
 If TypeName(objAppt) <> "AppointmentItem" Then
 MsgBox "You need to select and appointmnet"
NumOfDays = InputBox("How many days between appointments?")
NumAppt = InputBox("How many appointments in the series?")
currentDate = Format(objAppt.Start, "mm/dd/yyyy")
ApptStartTime = Format(objAppt.Start, "hh:mm:ss AM/PM")
' Using Function from
' 65 = skip Sat/Sun
For x = 1 To NumAppt
Set objAppt2 = Session.GetDefaultFolder(olFolderCalendar).Items.Add(olAppointmentItem)
apptStartDateTime = nextDate & " " & ApptStartTime
      With objAppt
' I'm using a limited number of fields, you can
' add others.
        objAppt2.Subject = .Subject & " " & x
        objAppt2.Location = .Location
        objAppt2.Body = .Body
        objAppt2.Start = apptStartDateTime
        objAppt2.Duration = .Duration
        objAppt2.Categories = .Categories
      objAppt2.Save
      'objAppt2.Display
Debug.Print nextAppt
Next x
    Set objAppt = Nothing
    Set objAppt2 = Nothing
' Workday2
' This is a replacement for the ATP WORKDAY function. It
' expands on WORKDAY by allowing you to specify any number
' of days of the week to exclude.
'   StartDate       The date on which the period starts.
'   DaysRequired    The number of workdays to include
'                   in the period.
'   ExcludeDOW      The sum of the values in EDaysOfWeek
'                   to exclude. E..g, to exclude Tuesday
'                   and Saturday, pass Tuesday+Saturday in
'                   this parameter.
'   Holidays        an array or range of dates to exclude
'                   from the period.
' RESULT:           A date that is DaysRequired past
'                   StartDate, excluding holidays and
'                   excluded days of the week.
' Because it is possible that combinations of holidays and
' excluded days of the week could make an end date impossible
' to determine (e.g., exclude all days of the week), the latest
' date that will be calculated is StartDate + (10 * DaysRequired).
' This limit is controlled by the RunawayLoopControl variable.
' If DaysRequired is less than zero, the result is #VALUE. If
' the RunawayLoopControl value is exceeded, the result is #VALUE.
Function Workday2(StartDate As Date, DaysRequired As Long, _
    ExcludeDOW As EDaysOfWeek, Optional Holidays As Variant) As Variant
Dim N As Long ' generic counter
Dim C As Long ' days actually worked
Dim TestDate As Date ' incrementing date
Dim HNdx As Long ' holidays index
Dim CurDOW As EDaysOfWeek ' day of week of TestDate
Dim IsHoliday As Boolean ' is TestDate a holiday?
Dim RunawayLoopControl As Long ' prevent infinite looping
Dim V As Variant    ' For Each loop variable for Holidays.
Holidays = Split(strAllDayOOF, ",")
If DaysRequired < 0 Then
    ' day required must be greater than or equal
    ' to zero.
    Workday2 = CVErr(xlErrValue)
    Exit Function
ElseIf DaysRequired = 0 Then
    Workday2 = StartDate
    Exit Function
If ExcludeDOW >= (Sunday + Monday + Tuesday + Wednesday + _
            Thursday + Friday + Saturday) Then
    ' all days of week excluded. get out with error.
    Exit Function
' this prevents an infinite loop which is possible
' under certain circumstances.
RunawayLoopControl = DaysRequired * 10000
N = 0
C = 0
' loop until the number of actual days worked (C)
' is equal to the specified DaysRequired.
Do Until C = DaysRequired
    N = N + 1
    TestDate = StartDate + N
    CurDOW = 2 ^ (Weekday(TestDate) - 1)
    If (CurDOW And ExcludeDOW) = 0 Then
        ' not excluded day of week. continue.
        IsHoliday = False
        ' test for holidays
        If IsMissing(Holidays) = False Then
            For Each V In Holidays
                If V = TestDate Then
                    IsHoliday = True
                    ' TestDate is a holiday. get out and
                    ' don't count it.
                    Exit For
            Next V
        If IsHoliday = False Then
            ' TestDate is not a holiday. Include the date.
            C = C + 1
    If N > RunawayLoopControl Then
        ' out of control loop. get out with #VALUE
        Exit Function
Loop
' return the result
Workday2 = StartDate + N
End Function
Sub GetHolidays()
' Check for all day events on calendar
'  marked busy/off/tentative
'  skips recurring events
' To be included, holidays need to be marked with a busy state, not Free
   Dim CalItems As Outlook.Items
   Dim ResItems As Outlook.Items
   Dim sFilter As String
   Dim iNumRestricted As Integer
   Dim itm As Object
   ' Use the selected calendar folder
   Set CalFolder = Session.GetDefaultFolder(olFolderCalendar)
   Set CalItems = CalFolder.Items
   ' Sort all of the appointments based on the start time
   CalItems.Sort "[Start]"
   CalItems.IncludeRecurrences = False
   ' Set dates
   sFilter = "[Start] >= '" & Date & "' And [AllDayEvent] = 'True' And [BusyStatus] <> '0' AND [IsRecurring] = 'False'"
   Set ResItems = CalItems.Restrict(sFilter)
   iNumRestricted = 0
   'Loop through the items in the collection.
   For Each itm In ResItems
      iNumRestricted = iNumRestricted + 1
 ' Create list of dates
  strAllDayOOF = strAllDayOOF & Format(itm.Start, "mm/dd/yyyy") & ","
   Debug.Print strAllDayOOF
 ' clean the string for the array
strAllDayOOF = Left(strAllDayOOF, Len(strAllDayOOF) - 1)
   Set ResItems = Nothing
   Set CalItems = Nothing
   Set CalFolder = Nothing
Create Outlook appointments for every nn workday was last modified: May 3rd, 2018 by Diane Poremsky
  • Create Outlook appointments using multiple recurring patterns
  • Flag for Follow up the Next Business Day
  • Create a Series of Tasks Leading up to an Appointment
  • Change Appointments Macro
Subscribe
Notify of
12 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Joel
February 5, 2020 1:41 pm
I get the same error as this person at the same place.
I get "User type not defined" at
I created an appointment the same day name Monthly_Data_Match and then ran the macro and it failed. I checked that I copied the entire code. I have a lot of references checked for outlook already. I can provide a copy of that list, but was not able to attach. Any help is appreciated.
0
0
Sarah R.
January 9, 2019 4:55 pm
0
0
Author
Reply to  Sarah R.
January 10, 2019 1:40 am
Did you copy the entire macro on the page? That error usually means you don't have references set. Does it stop on any specific line?
0
0
Marty
May 18, 2017 1:50 pm
Code fails at line'
Compiler says sub or function not define.
0
0
Author
Reply to  Marty
May 18, 2017 2:35 pm
oh, you need the GetCurrentItem function from https://www.slipstick.com/developer/outlook-vba-work-with-open-item-or-select-item/#getcurrentitem - will update the article to mention that.
0
0
Elain
November 24, 2016 7:17 am
Hello! Thank you for the macro. I am having trouble to make the appointment in every 20th day. I need to create appontment in every 20th day regardless of whether it is saturday, sunday or holiday.
I tried edit the macro but I didnt get it work. Can someone help?
0
0
uday
March 10, 2016 9:03 am
how can create the same for multiple tasks and for a group
0
0
Steven
August 13, 2013 7:51 am
Nice! Thanks!
Just what I was looking for, allthough I had a slightly different repeat... but you inspired me!
0
0
Jonathan Weinberg
October 26, 2012 9:10 am
Any chance we can see that done to also exclude a list of holidays?
0
0
Reply to  Jonathan Weinberg
October 26, 2012 9:13 am
Holidays are a bit harder to work around since you need a list of dates. It's not impossible, it's just not as easy.
0
0
Reply to  Diane Poremsky
October 26, 2012 10:00 am
You can add something like this to it (before or after the Select case block ) - but there are two problems. 1) if the nextdate is another date in the array, the macro doesn't go back and check it. If the holiday is Monday, the Sat & Sun routine doesn't skip it.
When its after the Sat/Sun routine, it properly skips Monday holidays but if the recurrence pattern pushes it into the next weekend, that won't be checked.
It can get unwieldy with a lot of dates. You also need to update the dates on a regular basis. Better, but more complicated, would be to get the dates of all Holiday categories within the expected span - sounds like a fun project when i have some free time. If more holidays are static, you could check just the month and day.
Dim arrCat As Variant
arrCat = Array("11/1/2012", "11/3/2012", "11/5/2012", "11/7/2012", "11/9/2012", "12/1/2012", "12/3/2012", "12/5/2012", "12/7/2012", "12/11/2012", "12/18/2012", "12/24/2012", "12/25/2012")
' Go through the array and look for a match, then do something
For i = LBound(arrCat) To UBound(arrCat)
If InStr(nextDate, arrCat(i)) Then nextDate = DateAdd("d", 1, nextDate)
Next i
0
0
October 26, 2012 10:47 am
Actually, in thinking about this, I wasn't thinking it through completely.
The array code after the Sat/Sun check code should work - if a holiday is Fri, you can add sat & sun to the array as it loops to the next date in the array. (I forgot about the i, next i loop checking the next date in the array).
arrCat = Array("11/1/2012", "11/2/2012", "11/3/2012", "11/7/2012", "11/29/2012", "11/30/2012", "12/3/2012", "12/9/2012", "12/11/2012", "12/18/2012", "12/24/2012", "12/25/2012", "12/26/2012", "12/31/2012", "1/1/2013")
0
0
Latest EMO: Vol. 31 Issue 3
  • Duplicate Remover Tools
wpDiscuz
Never see this message again.
Move Comment
