Process Mail that was Auto Forwarded by a Rule
› Developer › Code Samples › Process Mail that was Auto Forwarded by a Rule
Last reviewed on July 16, 2021     No Comments
A user wanted to know how to identify or "do something" with a message that was auto forwarded. While the info bar in the message identified it as auto forwarded, it' only visible when the message is selected.
message was autoforwarded
The first macro is an ItemAdd macro and runs as items are added to a folder. In this example, we add a category to the message, but you can save, move, or delete it instead.
The second macro on this page is used in a run a script rule.
Option Explicit
Private objNS As Outlook.NameSpace
Private WithEvents objItems As Outlook.Items
Dim objWatchFolder As Outlook.Folder
'Set the folder and items to watch:
Set objWatchFolder = objNS.GetDefaultFolder(olFolderInbox)
Set objItems = objWatchFolder.Items
Set objWatchFolder = Nothing
Private Sub objItems_ItemAdd(ByVal Item As Object)
Dim propertyAccessor As Outlook.propertyAccessor
Set propertyAccessor = Item.propertyAccessor
 'http://schemas.microsoft.com/mapi/proptag/0x0005000B
 ' PR_AUTO_FORWARDED
Dim prop
prop = propertyAccessor.GetProperty("http://schemas.microsoft.com/mapi/proptag/0x0005000B")
Debug.Print "PR_AUTO_FORWARDED", prop
If prop = True Then
Item.Categories = "AutoForwarded"
Item.Save
Set Item = Nothing
Run a script rule version.
You can use this is a run a script rule.
Private Sub AutoForwarded(ByVal Item As Object)
 ' PR_AUTO_FORWARDED
Dim prop
If prop = True Then
Item.Save
Set Item = Nothing
The macros on this page need to go into ThisOutlookSession.
For more Run-a-script code samples, see Run a Script Rule Index
Process Mail that was Auto Forwarded by a Rule was last modified: July 16th, 2021 by Diane Poremsky
  • How to Process Mail After Business Hours
  • Creating an AND rule in Outlook Rules
  • Remove prefix from Gmail meeting invitations
Latest EMO: Vol. 31 Issue 5
