Process items in a shared mailbox
› Developer › Code Samples › Process items in a shared mailbox
Last reviewed on February 11, 2016     19 Comments
Client-side rules won't run if the mailbox is not open in Outlook and you can't run rules on a shared mailbox in your profile. However, if the shared mailbox is in your profile you can use an ItemAdd macro to watch the folder for new items and process them as they arrive.
This sample watches a shared mailbox for new items, adds a category to the item then forwards it to another address.
How to use VBA macros
To get the correct mailbox name to use, right-click on the shared Inbox and choose Properties. The mailbox name is in the Location field.
Use the name only, not the \\.
Get the mailbox name from properties
 Private WithEvents olInboxItems As Items
  Dim objNS As NameSpace
  Set objNS = Application.Session
' Get function fromhttp://slipstick.me/qf
  Set olInboxItems = GetFolderPath("Mailbox name in folder list\Inbox").Items
  Set objNS = Nothing
Private Sub olInboxItems_ItemAdd(ByVal Item As Object)
    Item.Categories = "My Category"
    Item.Save
  Set myForward = Item.Forward
  'this puts the name in the To field
  myForward.Recipients.Add "me@domain.com"
  myForward.Display ' use .Send to send it automatically
Don't forget to check your macro security settings; it needs to be set to Low for testing.
To test the macro without restarting Outlook, click in the Application_Startup macro and press Run.
How to use macros
Process items in a shared mailbox was last modified: February 11th, 2016 by Diane Poremsky
  • Use a VBA macro to monitor a folder in a secondary mailbox for new mes
    Monitor secondary mailbox folder for new messages
  • Process Mail that was Auto Forwarded by a Rule
  • Mark Sent Items as Read After Copying with a Rule
  • How to Process Mail After Business Hours
Subscribe
Notify of
19 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Shreyas
June 4, 2020 7:12 am
I have put the above codes by changing the shared mailbox name and forward too section however it gives an error stating "Only Valid in object Module" for  "Private WithEvents olInboxItems As Items" . Please help.
I also need a macro where in all attachments can be downloaded from shared mailbox.
0
0
Brian
March 9, 2018 12:22 pm
Hi Diane, My question is a bit more complex. I have a macro that uploads attachments from a shared mailbox into a master file on the network. Because there is no reliable method of determining which emails have the necessary attachments, the user sets a custom Category on the required emails. The macro loops through the mailbox, uploads attachments from the categorized emails, then switches the custom Category to "Upload Complete". All of this works perfectly... Unless... If another user happens to have one of the categorized emails open, the macro adds the "Upload Complete" category to the email, but cannot remove the "Ready For Upload". This causes the "Ready For Upload" Category count to hang at 1 and the macro loops forever. Note: I cannot simply count the "Ready For Upload" emails because the Email.Save process which is switching the category interrupts For Each loops so I have to use a Do Until loop. So, is there a way to close or deactivate an email from all users, or identify if another user has an email open, or lock an email by some means so others can't open it during this process? Any assistance you can provide is greatly… Read more »
0
0
Author
Reply to  Brian
March 16, 2018 11:51 pm
Well.. you can't close it remoting using vba.
I am assuming redemption won't close it either, but have not looked at it... but if it can be done, I'd expect redemption to do it. http://www.dimastr.com/redemption/rdo_introduction.htm
0
0
JMay
November 29, 2017 4:44 am
Hi , I need to build a macro to track the mails moved from one mail box to other in a shared mail box in excel ,Can anyone please help me on this ?
0
0
Rajneesh
May 19, 2017 11:10 am
Any idea how to automate the process to send the E-mails from Office 365.
Regards
Rajneesh
0
0
Author
Reply to  Rajneesh
May 19, 2017 10:58 pm
If its a shared mailbox, you need to have send as permission and use .sentonbehalfof - https://www.slipstick.com/developer/code-samples/send-email-address-vba/
0
0
Rajneesh
March 27, 2017 11:11 am
Hi, I am stuck in one of the urgent project delivery. Requirement is: when new mail arrives, mail detail(Subject,received time) should be export into excefl but main issue is that user have 6 different shared inbox and these inbox we have 2 or 3 folder in each.
Outlook event for new mail is not working for these inbox , it is notifying new mails only for main inbox.
Please help!!!
0
0
Author
Reply to  Rajneesh
March 29, 2017 3:35 pm
you'll need to add each folder you need to watch to the automatic startup macro and create an items add macro for each one, giving each a different name. It's going to get real messy, real fast watching 12 - 18 folders - start with one folder, test, then add more. Make sure you are using unique object names for each folder too.
if the macro to save to excel is identical for each, the itemadd macros can call the same macro, which will reduce a lot of the mess.
You can set the parent folder once (so you only need 6 of these) - and share that with the subfolders:
Set Aliasfolder = Session.GetDefaultFolder(olFolderInbox)
set aliaisitems = aliasfolder.items
set aliassubfolder1items = aliasfolder.Folders("Sub1").Items
set aliassubfolder2items = aliasfolder.Folders("Sub2").Items
Private Sub aliaisitems_ItemAdd(ByVal Item As Object)
'do whatever
call savetoexel
end sub
Private Sub aliassubfolder1items_ItemAdd(ByVal Item As Object)
'do whatever
call savetoexel
end sub
Private Sub aliassubfolder2items_ItemAdd(ByVal Item As Object)
'do whatever
call savetoexel
end sub
etc
1
0
Rajneesh
Reply to  Diane Poremsky
April 11, 2017 12:39 pm
Hi Diana, Thanks for the response. I used "GetFolderPath" function for each folder that i got from your above code and it's working good and very helpful. My project is in progress now and it is in testing phase. Can you please suggest how can we assign the outlook code to button for whole team rather than import and export the module and assign the button one by one for each team memeber system.
Thanks for your support:):)
0
0
Author
Reply to  Rajneesh
April 14, 2017 8:27 pm
i swear i answered this the other day... guess i forgot to hit send. :) the only way to share code is either by import/export or copy/paste it or compiling it into an addin.
0
0
Marara
March 14, 2017 3:39 pm
Hi, Im pretty new to VBA and Outlook, Here is the issue I'm having. We have public folder that each team member has access to and we have our own personal one. I used the following code to move email from Inbox to subfolder in public folder. It works perfectly on my machine but for everyone else the email stays in the Inbox. I cant see the email even if I restart outlook. It is also in the subfolder
Set ns = Application.GetNamespace("MAPI")
Set objOwner = ns.CreateRecipient("general@u.ca")
objOwner.Resolve
If objOwner.Resolved Then
Set newCalFolder = ns.GetSharedDefaultFolder(objOwner, olFolderInbox)
Set objDestFolder = newCalFolder.Folders("Myfolder")
Set objItem = GetCurrentItem()
With objItem
.FlagStatus = olFlagComplete
.Move objDestFolder
Any help is greatly appreciated
0
0
Author
Reply to  Marara
March 14, 2017 4:34 pm
Did the other users add the shared mailbox in their profile the same way you did? Do they get any error messages?
0
0
Drew G
February 7, 2017 4:57 pm
I am using a shared inbox and I am trying to create a rule that will move mail to a specific folder based on certain words that appear in the body. In outlook when I try and create the rule it does not let me select the folder of the shared inbox. I can do it using OWA but the issue there is I want to be able to save the rules in case they are deleted in error. Any ideas?
0
0
Author
Reply to  Drew G
March 14, 2017 4:15 pm
if its a server side rule, you can create a profile for the shared account to create the rules, then go back to your own profile, otherwise you need to use a macro that watches the shared inbox, which is on this page. .
0
0
Rajneesh
March 27, 2017 11:01 am
hi Diane,
Cud u plz share the code for watch the new mail arrival on shared inbox.
0
0
Author
Reply to  Rajneesh
March 29, 2017 3:25 pm
You'll use the method at https://www.slipstick.com/developer/working-vba-nondefault-outlook-folders/#shared to identify the folder to watch.
it replaces this line -
just make sure you are using the correct object references!
0
0
Louis
September 3, 2016 9:50 am
I am getting the sub or function error under
GetFolderPath you please help?
0
0
Latest EMO: Vol. 31 Issue 3
wpDiscuz
Never see this message again.
Move Comment
