Get the Internet Header VBA Code Sample for Outlook
› Developer › Code Samples › Get the Internet Header VBA Code Sample for Outlook
Last reviewed on October 25, 2015     2 Comments
Applies to: Outlook 2007
The following is the Get Internet Header code sample from Teach Yourself Outlook in 24 Hours. This code requires CDO and will not work with Outlook 2010 or Outlook 2013. CDO can be downloaded from Microsoft for use with Outlook 2007.
For an Outlook 2010/2013 version, see Get Outlook's Internet Headers using VBA
If you prefer installing a ready-to-use add-in, try PocketKnife Peek.
Copy and paste the code from this page into your ThisOutlookSession project.
To do this, click in the text box, Select All using Ctrl+A, Ctrl+C to copy.
In Outlook, press Alt+F11 to open the VBA editor and expand Microsoft Outlook Objects then double click on ThisOutlookSession to open it in the editing pane and Ctrl+V to paste the code.
The form this code uses is here.
Public Sub GetInternetHeaders()
' Initalize error handling
' Declare constants
Const CdoPR_TRANSPORT_MESSAGE_HEADERS = &H7D001E
Dim objSession As New MAPI.Session
Dim objExplorer As Outlook.Explorer
Dim objSelection As Outlook.Selection
Dim objItem As Outlook.MailItem 'Object
Dim objMessage As MAPI.Message
Dim objFields As MAPI.Fields
Dim strheader As String
Dim InetHeader As New MSForms.DataObject
    ' MAPI property tag used
    objSession.Logon , , False, False, 0 ' Use the existing Outlook session
    Set objExplorer = ThisOutlookSession.ActiveExplorer
    Set objSelection = objExplorer.Selection
    ' Get selected Message ID
    Set objItem = objSelection.Item(1)
    Set objMessage = objSession.GetMessage(objItem.EntryID, objItem.Parent.StoreID)
    ' Get message fields
    Set objFields = objMessage.Fields
    ' Get SMTP header
    Err.Clear
    strheader = objFields.Item(CdoPR_TRANSPORT_MESSAGE_HEADERS).Value
    If Err.Number = 0 Then
    'MsgBox strheader
    ' Get the message body, prefer the raw HTML if it exists
    If objItem.HTMLBody = "" Then
    msgHeader = strheader & objItem.Body
    msgHeader = strheader & objItem.HTMLBody
    ' Note that you must have a form in the project for this reference to work
    InetHeader.SetText (msgHeader)
    InetHeader.PutInClipboard
    frmHeader.txtHeader.Text = msgHeader
    frmHeader.Show
    MsgBox "No SMTP message header information on this message", vbInformation
    ' Logoff from CDO 1.21 sesison
    objSession.Logoff
    ' Tidy up
    Set objExplorer = Nothing
    Set objSelection = Nothing
    Set objItem = Nothing
    Set objSession = Nothing
    Set objMessage = Nothing
    Set objFields = Nothing
    Set objField = Nothing
Get the Internet Header VBA Code Sample for Outlook was last modified: October 25th, 2015 by Diane Poremsky
  • Get Outlook's Internet Headers using VBA or PowerShell
  • View the CC or BCC Addresses in a Sent Message
  • How to View Internet Headers
  • Disable Outlook's No Subject Warning using VBA
  1. Austin says
    January 30, 2013 at 4:35 pm
    I would like to be able to do this in Outlook 2010 and Outlook 2013, and am disappointed the above code will not work.
      January 30, 2013 at 4:46 pm
      Use this one -Get internet headers. You won't be disappointed.
