Change the Business Card layout using BusinessCardLayoutXml
› Developer › Code Samples › Change the Business Card layout using BusinessCardLayoutXml
Last reviewed on December 22, 2020     6 Comments
Change the business card imageUse these code samples when you want to change the background color, move the business card image from the left side or change or rearrange the fields.
The first sample applies to all contacts in the folder, while the second sample works on just the selected contacts.
Code Sample 3: Change the business card layout to match the selected contact
To use, first edit a business card so it is exactly as you want then run the macro.
To use this code, select the contact whose card you edited then run the macro to apply it to all contacts in the folder. As with Sample 2, you can use If... Then statements to apply it to specific contacts.
Public Sub CustomizeBusinessCards()
Dim obj As Object
Dim oFolder As Outlook.MAPIFolder
Dim oContact As Outlook.ContactItem
Dim oModel As Outlook.ContactItem
Dim colItems As Outlook.Items
Dim i As Long
Dim lCount As Long
Dim sXML As String
Set oFolder = Application.Session.GetDefaultFolder(olFolderContacts)
Set colItems = oFolder.Items
Set oModel = Application.ActiveExplorer.Selection.Item(1)
sXML = oModel.BusinessCardLayoutXml
lCount = colItems.Count
For i = 1 To lCount
Set obj = colItems.Item(i)
If (obj.Class = olContact) Then
Set oContact = obj
  oContact.BusinessCardLayoutXml = sXML
 ' oContact.AddBusinessCardLogoPicture ("C:\image\logo.gif")
  oContact.Save
Code Sample 4: Change the business card layout of selected contacts
To use this code sample, after changing one contact's business card, select the contact then select the contacts you want to match the first contact's business card layout to the remaining selected contacts. For example, if you select Billy, Bob, and Mary's contacts, the layout on Billy's card is applied to Bob and Mary's contacts. Use this when you want to change the background color, move the business card image from the left side or change or rearrange the fields.
Public Sub ChangeBusinessCardXML_SelectedContacts()
    Dim Selection As Selection
    Dim currentItem As Object
    Dim folder As Outlook.folder
    Dim sXML As String
    Dim obj As Object
'uses the xml of first item selected to set the other cards that are selected
    For Each obj In Selection
    Set folder = currentItem.Parent
        If obj.Class = olContact Then
            Set objContact = obj
      With objContact
        obj.BusinessCardLayoutXml = sXML
        'obj.AddBusinessCardLogoPicture ("C:\image\logo.gif")
        .Save
        Err.Clear
    Set Session = Nothing
    Set currentExplorer = Nothing
    Set obj = Nothing
    Set Selection = Nothing
    Set currentItem = Nothing
    Set folder = Nothing
If you have your own code, below are the (important) parts of the code that will allow you to get the business card layout of the selected contact item then apply it to the remaining contacts.
'dim the variables
   Dim sXML As String
'use the xml of first selected item to set the other cards
'apply the changes
      With objContact
        .save
Using VBA to Change Business Card Image & Layout
Change the image on a Business Card based on the Category
Changing Outlook’s Business Card layout
Using Custom Business Cards
Change the Business Card layout using BusinessCardLayoutXml was last modified: December 22nd, 2020 by Diane Poremsky
  • Using VBA to Change Business Card Image & Layout
  • Change the image on a Business Card based on the Category
  • Changing Outlook's Business Card layout
  • While you can't the business card layout used by existing contacts
Subscribe
Notify of
6 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
fogharty
July 23, 2019 4:07 pm
I know this is an old post, but I've used the Code Sample 4 in the past and it always worked. But now I'm getting a "Variable not defined" error message and can't get it to work:
Any help?
0
0
Jason Jones
January 15, 2015 9:55 am
I figured it out I changed the Line to
Set oFolder = Application.ActiveExplorer.CurrentFolder
0
0
Jason Jones
January 15, 2015 8:29 am
I know this is an old post, and thanks so much for your help. I have a question/problem. Although the code works for updating the default folder, it does not seems to make the changes to the Business Contacts folder. How do I choose this folder as opposed to the default? I suspect the GetDefaultFolder would be replaced with something else.
0
0
Claudio A Heckler
Reply to  Jason Jones
November 6, 2017 12:12 pm
This is an old post, but alas, I needed this info today and it made me happy :)
To effect the change in the currently selected folder, instead of the default outlook contact's folder, make this small change to the macro:
Where it reads:
Replace that line with the following:
Then make sure when you invoke the macro (ALT+F8) that you are in the correct folder and have the contact with the desired layout selected in that window.
0
0
Filip Ignatiou
March 23, 2013 11:12 am
Thank you sooo much. I was looking for Days for a solution. It worked perfectly!!
0
0
Rahul Aggarwal
March 14, 2013 10:40 am
Thanks for the guidance.....now i have all my outlook contacts in my format...:-)
0
0
Latest EMO: Vol. 31 Issue 3
wpDiscuz
Never see this message again.
Move Comment
