Move Appointments to an Archive Calendar
› Developer › Move Appointments to an Archive Calendar
Last reviewed on September 19, 2018     17 Comments
This code removes the reminder and categories and moves the appointment to a calendar in an archive folder or a subfolder under the calendar.
I want to be able to do 3 things with just one click of a button:
With a Calendar event selected, I want to:
1) Erase any Reminder (set Reminder to: 'None'),
2) Clear All Categories,
3) Move the event to another calendar (in My Calendars) named "DONE" (where I keep finished-completed things).
Since this is something I do everyday, multiple times a day, I want to save time by having a macro do all those things with one click.
Removing the reminder and clearing categories is as simple as changing the field values. Moving the event is also a simple process , although it requires a function that gets the filepath if the calendar you are moving the event to is not in the default data file.
The code Set CalFolder = GetFolderPath("Archive\Done") moves the appointment to a calendar folder called "Done" in the Archive pst.
Use Set CalFolder = Session.GetDefaultFolder(olFolderCalendar).Folders("Done") to move the appointments to a subfolder of the calendar. Note: if you are moving the item to a subfolder of the data file, you don't need to use the GetFolderPath function.
For more information on folders and data files, see Working with VBA and non-default Outlook Folders.
The GetCurrentItem function detects whether the appointment is selected or opened. For more information, see Outlook VBA: work with open item or selected item.
Public Sub MoveCalendar()
Dim objAppt As Outlook.AppointmentItem
Set objAppt = GetCurrentItem()
' move to a calendar in an archive data file
' change field values here
With objAppt
    .ReminderSet = False
    .Categories = ""
    objAppt.Move CalFolder
Function GetFolderPath(ByVal FolderPath As String) As Outlook.Folder
    Dim oFolder As Outlook.Folder
    Dim FoldersArray As Variant
    Dim i As Integer
    On Error GoTo GetFolderPath_Error
    If Left(FolderPath, 2) = "\\" Then
        FolderPath = Right(FolderPath, Len(FolderPath) - 2)
    'Convert folderpath to array
    FoldersArray = Split(FolderPath, "\")
    Set oFolder = Application.Session.Folders.Item(FoldersArray(0))
    If Not oFolder Is Nothing Then
        For i = 1 To UBound(FoldersArray, 1)
            Dim SubFolders As Outlook.Folders
            Set SubFolders = oFolder.Folders
            Set oFolder = SubFolders.Item(FoldersArray(i))
            If oFolder Is Nothing Then
                Set GetFolderPath = Nothing
    'Return the oFolder
    Set GetFolderPath = oFolder
    Exit Function
GetFolderPath_Error:
    Exit Function
End Function
    Set objApp = Application
        Case "Explorer"
        Case "Inspector"
    Set objApp = Nothing
End Function
Move all appointments
This code sample moves all appointments with an End time before "Now", to the archive folder.
Public Sub MoveAllAppointments()
    Dim objAppt As Outlook.Items
    Dim objFolder As Outlook.MAPIFolder
    Set objOL = CreateObject("Outlook.Application")
    Set objNS = objOL.GetNamespace("MAPI")
    Set objFolder = objNS.GetDefaultFolder(olFolderCalendar)
    Set objAppt = objFolder.Items
For i = objAppt.Count To 1 Step -1
If objAppt(i).End < Now Then
With objAppt(i)
    .Categories = ""
objAppt(i).Move CalFolder
Next i
    Set objAppt = Nothing
    Set objFolder = Nothing
    Set objOL = Nothing
    Set objNS = Nothing
Move Appointments to an Archive Calendar was last modified: September 19th, 2018 by Diane Poremsky
  • Working with VBA and non-default Outlook Folders
  • This macro copies a meeting request to an appointment. Why would you w
    Copy meeting details to an Outlook appointment
  • VBA: Copy New Appointments to Another Calendar
  1. stephengazard says
    March 25, 2013 at 3:20 am
    perfect thanks
  2. stephengazard says
    March 20, 2013 at 5:04 am
    Sorry Diane I am sure I am being dum ... but I've done that but it appears to now run the process on the sub calendar "Call Log" rather than run the process on the default calendar and then move the appointment to the sub calendar on completion.
      March 20, 2013 at 5:14 am
      Oh, sorry about that. I misunderstood. You want to mark and move the appointments? You need to add this and the getfolderpath function. (It's in the first sample on this page too.)
      This can go before the For each..
      Set CalFolder = GetFolderPath("ArchiveDone")
      And this after the .save but before the End if and Next lines.
  3. stephengazard says
    March 19, 2013 at 2:01 pm
    Thanks Diane, .... how do I get the move to work to the sub calendar though? I can't get that to work.
      March 19, 2013 at 3:23 pm
      If the subcalendar is in the same data file as the calendar, you'd use
      Set objCalendar = Session.GetDefaultFolder(olFolderCalendar).Folders("SharedCal")
      instead of
      Set objCalendar = Application.Session.GetDefaultFolder(olFolderCalendar)
      Working with other folders
  4. stephengazard says
    March 18, 2013 at 1:26 am
    Really? That part seems to work for me it is the move that doesn't.
    If I wanted to replace the SQL then with an if stmt will tag help?
    All the relevant appointments start with "C."
      March 18, 2013 at 5:49 am
      The Keyword was the problem - with that gone the filter works and the macro completes.
      I ended up using this filter to speed things up as I have like 1500 appointments and it ran through each - I had added a msgbox location to see what the restriction was returning. :)
      strRestriction = "@SQL= (""urn:schemas:httpmail:subject"" LIKE '@Call%' OR ""urn:schemas:httpmail:subject"" LIKE 'C%' AND %last7days(""urn:schemas:calendar:dtstart"")%)"
      In this block:
      For Each aItem In objCalendar.Items
      If Mid(aItem.subject, 1, 2) = "C." Then
      you don't identify what an aItem is.
      I moved the subject editing code up into the If loop:
      objAppt.Categories = "S. CALL MADE."
      ' my tests had call as the first word
      strTemp = Right(objAppt.Subject, (Len(objAppt.Subject) - 5))
      objAppt.Subject = strTemp
      MsgBox strTemp
      iItemsUpdated = iItemsUpdated + 1
      objAppt.Save
      If the goal of this is to not process previously processed items, you could look for categories. (the location code allows for case variations on the case and spaces at the end.)
      If InStr(1, Item.Categories) "Call" Then
      If Left(LCase(objAppt.Location), 11) = "missed call" Then
      You could check categories in the sql filter code instead of in the loop.
      my version is at steve-macro.txt
  5. stephengazard says
    March 17, 2013 at 1:52 pm
    Yes works fine using SQL simply as I adapted from someone else code.
      March 17, 2013 at 4:51 pm
      It's failing here on the SQL (in the macro at least).
  6. dporemsky says
    March 17, 2013 at 9:05 am
    Does the SQL filter work as expected in custom views? Is there a reason you are using that filter instead of an If statement? If instr( item.subject, "call") then...
  7. stephengazard says
    March 14, 2013 at 10:56 am
    other code:
    If Item.subject = "Process Calls" Then
    ' Define variables
    Dim objCalendar As Outlook.folder
    Dim objItems As Outlook.Items
    Dim strRestriction As String
    Dim objFinalItems As Outlook.Items
    Dim myolApp As Outlook.Application
    ' Set strRestriction to be only calls
    strRestriction = "@SQL= (""urn:schemas:httpmail:subject"" LIKE '@Call.%' OR ""urn:schemas:httpmail:subject"" LIKE 'C.%' OR ""urn:schemas:httpmail:subject"" LIKE '@Call in%' OR ""urn:schemas:httpmail:subject"" LIKE '@Call%') AND ""urn:schemas-microsoft-com:office:office#Keywords"" 'Phone call'"
    ' Set the objCalendar and objItems items
    Set objItems = objCalendar.Items
    Set objFinalItems = objItems.Restrict(strRestriction)
    Set myolApp = CreateObject("Outlook.Application")
    For Each objAppt In objFinalItems
    ' Debugging
    ' Debug.Print objAppt.Start, objAppt.Subject, objAppt.Categories
    ' Assign the category to the appointments
    If objAppt.Location = "Missed Call " Then
    objAppt.Categories = "S. CALL MISSED."
    ElseIf objAppt.Location = "Incoming Call " Then
    objAppt.Categories = "S. CALL RECEIVED."
    objAppt.Save
    ' Rename Entry
    Dim iItemsUpdated As Integer
    Dim strTemp As String
    iItemsUpdated = 0
    strTemp = Mid(aItem.subject, 4, Len(aItem.subject) - 4)
    aItem.subject = strTemp
    aItem.Save
    Next aItem
    MsgBox iItemsUpdated & " of " & objCalendar.Items.Count & " Meetings Updated"
  8. stephengazard says
    March 12, 2013 at 3:20 am
    Thanks Diane, I think I am getting there but struggling a bit .... I have two processes (I am sure the could be shortened to one mind you but everytime I try I break it !) ...
    First process sets category of appointment based on Subject and location (all works ok).
    The second process "MoveCallLog" should (but doesn't) ... move only those appointments that carry the category of "Calls" to a sub calendar called "Call Log"
    I can't get it to work - it either doesn't fire or moves everything!
    Also is there a way to automate more regularly than daily via the task reminder?
    Your help would be MUCH appreciated.
    Code below:
    If Item.subject = "Move Calls" Then
    Public Sub MoveACallLog()
    Set CalFolder = GetFolderPath("\stephen@gazard.netCalendarCall Log")
    If objAppt(i).Categories = "Calls" Then
    Next i
    Set objOL = Nothing
    Set objNS = Nothing
    Function GetFolderPath(ByVal FolderPath As String) As Outlook.folder
    Dim oFolder As Outlook.folder
    Dim i As Integer
    If Left(FolderPath, 2) = "\" Then
    FoldersArray = Split(FolderPath, "")
    'Return the oFolder
    Exit Function
    Exit Function
    End Function
    Case "Explorer"
    Case "Inspector"
    End Function
      March 12, 2013 at 8:52 pm
      On the more regular part - you can set up more tasks with different reminder times. Add code to mark the task complete and save it, and recurring tasks will keep running. Otherwise, you need some way to trigger it since Outlook doesn't have a timer.
      I think the code is probably not running, if its waiting for the first code to set the category. What is the full code for the other macro?
  9. stephengazard says
    March 8, 2013 at 1:42 pm
    That's fantastic Diane many thanks .... without pushing my luck how would I get this to run on all items in the calendar rather than just current item? Ideally automatically even.
    Really appreciate your help.
      March 9, 2013 at 4:09 pm
      You need to tweak it a little to apply to the entire folder- I added a code sample that moves all appointments that ended before 'now'.
  10. stephengazard says
    March 7, 2013 at 1:47 pm
    Can someone tell me how I could amend this to move appointments of a particular category?
      March 7, 2013 at 2:06 pm
      Something like this should work -
      If objAppt.categories = "my category" then
      With objAppt
      .Categories = ""
      end if
Latest EMO: Vol. 31 Issue 5
