Bulk Move Phone Numbers to a Different Phone Field
› Outlook › People › Bulk Move Phone Numbers to a Different Phone Field
Last reviewed on August 29, 2018     25 Comments
Willy shared this with us:
"I found your very interesting page on how to bulk edit "FileAS" info for Outlook contacts. I have a Palm Pre 2 and Microsoft Exchange sync. Due to a bug, phone numbers entered in "Other Phone" field in Outlook won't sync with the smartphone. I was seeking a way to mass edit my contacts to move "other phone" to "mobile phone" (when empty). I used your script and put the following lines in the part used for "FileAs":
If .OtherTelephoneNumber <> "" Then
If .MobileTelephoneNumber = "" Then
 .MobileTelephoneNumber = .OtherTelephoneNumber
 .OtherTelephoneNumber = ""
 .Save
It worked like a charm. From 160+ contacts with "OtherPhone", I ended up with less than 10 where Mobile phone was not empty and I needed to store the phone number in another category (home or business or Notes as text). Your code saved my day. Thanks"
VBA Sample
Press Alt+F11 to open the VBA editor then copy and paste into ThisOutlookSession then run. Note that it works on the contacts in the default contacts folder.
I tested this code in Outlook 2010. It should work just fine in Outlook 2003 and Outlook 2007. (May trigger the Email security prompts in Outlook 2003.)
Public Sub MovePhoneNumber()
    Dim objContact As Outlook.ContactItem
    Dim objItems As Outlook.Items
    Dim objContactsFolder As Outlook.MAPIFolder
    Dim obj As Object
    Set objOL = CreateObject("Outlook.Application")
    Set objNS = objOL.GetNamespace("MAPI")
    Set objContactsFolder = objNS.GetDefaultFolder(olFolderContacts)
    Set objItems = objContactsFolder.Items
    For Each obj In objItems
        If obj.Class = olContact Then
            Set objContact = obj
     With objContact
            .Save
     Err.Clear
    Set objOL = Nothing
    Set objNS = Nothing
    Set obj = Nothing
    Set objContact = Nothing
    Set objItems = Nothing
    Set objContactsFolder = Nothing
How to use the macro on this page
The original code is at Bulk Change Outlook Contact's Email Display Name format
To change the File as format on existing contacts, see Bulk Change File As Format for Contacts.
More Bulk Change Contact articles at Slipstick.com:
  • Bulk Change Contact's FileAs Format to Match Outlook's Default Setting
  • Bulk Change File As Format for Contacts
  • Macro to Swap First and Last Name Fields
  • Update Contact Area Codes
  • Update Contacts with a New Company Name and Email Address
Bulk Move Phone Numbers to a Different Phone Field was last modified: August 29th, 2018 by Diane Poremsky
  • Bulk Change Email Display Name Format
  • Format Contact phone numbers to use with Skype
  • Remove Prefix and Reformat Phone Numbers
Subscribe
Notify of
25 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Amit Kaushik
November 13, 2016 7:36 am
I'm not a very technical user, but would really be grateful if you could please help me move all numbers from the Other field into the Radio field, since the former does not sync with my smartphone. Would I be correct in assuming that .MobileTelephoneNumber in the above script would need to be replaced with .RadioTelephoneNumber for this? And if so, how might the revised script look?
Regards,
AK
0
0
Author
Reply to  Amit Kaushik
November 13, 2016 10:11 am
yes, provided that is the correct field name (i'm on the road and didn't double check it)
If .RadioTelephoneNumber = "" Then
.radioTelephoneNumber = .OtherTelephoneNumber
'this line clears the other field - you could leave it in and have the number duplicated
'.OtherTelephoneNumber = ""
.Save
0
A Kaushik
Reply to  Diane Poremsky
November 14, 2016 2:33 am
Thank you for that quick response. Last question - how would I go about confirming that .radioTelephoneNumber is actually the correct field name? And if it's not, how would I find the correct one? As I mentioned in the original post, I'm not very tech savvy in this regard, so grateful for the help.
0
0
Author
Reply to  A Kaushik
November 14, 2016 11:29 am
three ways:
type in lower case. if the field is valid in outlook, the case changes.
after typing the object name and dot, a list of valid fields will come up. as you type letters, it will filter the list.
search the object model help. its on the view menu and in msdn (use google to find it - something like 'outlook vba contact fields'
0
0
A Kaushik
November 15, 2016 12:11 am
Absolutely brilliant, worked like a charm - thank you so much!! :-)
Slipstick is my first point of reference when I need to do something like this - some months ago, needed to bulk change the Save As field for email, and you saved my life then too. Awesome, and thank you for the work you do for the MS community.
Cheers!
0
0
makinmyway
January 25, 2016 2:56 pm
I want to use the script above to move information between the following two fields but do not seem to have the correct syntax for the field names as nothing moves (though I can get phone numbers in Other to move to Mobile when I try running it as shown above): User Field 2 (.UserField2) to Personal Home Page (.PersonalHomePage). I believe I have not used the correct field labels in the macro but am stumped as to what I should be using. Note: I want to do the same with User Field 3 moving to IM Address so let me know please what the correct syntax is for the IM Address field too. Thanks!
0
0
Kithsiri ArunaShanta
May 30, 2015 3:20 am
Thanks it worked on outlook 2013
0
0
Khalil
March 12, 2015 5:11 pm
Dear Diane , that's so technical for a user like me ... Can you give me a simple way to change all the fields in my contacts from the "other" field to for example "home" field ... I use Microsoft exchange of my company & it's not reading the "other" field on my smart phones
0
0
Author
Reply to  Khalil
March 14, 2015 1:37 am
You'll either need to use a macro or edit each contact yourself.
0
0
Sunil Avhad
June 17, 2014 4:55 am
Thanks Slipstick and ThanksWilly.
I could cut/paste your script and update my 800+ contacts in virtually one minute.
Thanks a Ton. It saved my great headache and my hours of work.
0
0
Michael A
May 6, 2014 2:30 pm
Fantastic! It worked like a charm.
0
0
Kumar S R
February 10, 2014 11:29 am
Thanks a ton Diane. That was genius. Having no idea about VB coding, I transferred my contacts! Kudos ...
0
0
thepasbox
January 4, 2014 10:21 am
Thanks you, Diane!
0
0
Latest EMO: Vol. 30 Issue 32
  • New Outlook: Show To, CC, BCC in Replies
  • Insert Word Document into Email using VBA
  • Delete Empty Folders using PowerShell
  • Warn Before Deleting a Contact
wpDiscuz
Never see this message again.
Move Comment
