Import Messages from File System into Outlook Folders
› Developer › Code Samples › Import Messages from File System into Outlook Folders
Last reviewed on December 4, 2018     19 Comments
This macro copies messages, appointments, or contacts stored in the Windows File System back into Outlook.
The macro uses the .OpenSharedItem Method to select the messages and also can be used to import appointments (.msg or .ics) or Contacts (.msg or .vcf) into the Calendar or Contacts folder.
bulk import vcards into outlook
This macro gets the messages in the current folder and copies them into the Outlook folder identified as the Savefolder. It can either be hard-coded or use the current Outlook folder. Messages that cause an error are skipped.
Keep in mind that if you run it on email messages and save to Contacts folder, you'll create contacts, replicating the action of moving a message to contacts.
This macro works in Outlook 2007 and newer.
You need to set a reference to the Microsoft Scripting Runtime in Tools, References. If the reference is not set, you'll receive a Compile error: User-defined type not defined.
Sub ImportMessagesInFolder()
    Dim fso As Scripting.FileSystemObject
    Dim SourceFolder As Scripting.Folder
    Dim SourceFolderName As String
    Dim FileItem As Scripting.File
    Dim strFile, strFileType As String
    Dim oMsg As Object
    Dim copiedMsg As MailItem
    Dim Savefolder As Outlook.Folder
    Set fso = New Scripting.FileSystemObject
'Source folder
    SourceFolderName = "C:\Users\drcp\Documents\Email\"
    Set SourceFolder = fso.GetFolder(SourceFolderName)
'Set the Outlook folder name
   ' Set Savefolder = Session.GetDefaultFolder(olFolderInbox).Folders("My Subfolder")
   Set Savefolder = Application.ActiveExplorer.CurrentFolder
    For Each FileItem In SourceFolder.Files
    Set oMsg = Session.OpenSharedItem(FileItem.Path)
    Set copiedMsg = oMsg.Copy
        copiedMsg.Move Savefolder
    Set copiedMsg = Nothing
     oMsg.Delete
    Set oMsg = Nothing
    Next FileItem
    Set FileItem = Nothing
    Set SourceFolder = Nothing
    Set fso = Nothing
You can use an If statement to limit the macro to email, calendar, or contact items as necessary.
If oMsg.Class = olContact Then
End if
How to use macros
More Information
.OpenSharedItem Method (MSDN)
Import Messages from File System into Outlook Folders was last modified: December 4th, 2018 by Diane Poremsky
  • Use VBA to open Outlook messages stored in the file system
  • Macro to Bulk Import Contacts and vCards into Outlook
  • Remove Attachments From Messages
  • Use a Macro to Attach Files to New Messages
  1. Brett says
    May 23, 2017 at 12:27 am
    Dian I notice you have many different version of inserting and making folders etc, but no one total piece of code. Can you point me to how I could import messages from a windows file system with multiple depth folders back into Outlook?
    Does a book exist that can help with this?
      May 23, 2017 at 1:00 am
      The last Outlook programming book is several versions old - they just don't sell well. But this uses general filesystem object (it's not unique to outlook) - you should be able to find code samples on the net, either for Excel or VB/VBA in general. https://www.bing.com/search?q=vba+list+all+files+in+subdirectories
  2. Marc says
    January 20, 2017 at 4:59 pm
    I can't seem to get this to work with Outlook 2003 because Session.OpenSharedItem(FileItem.Path) didnt come out until 2007.
  3. Ed2 says
    November 3, 2016 at 12:57 pm
    Can this work with .eml files?
      November 6, 2016 at 11:22 am
      I haven't tried, but it might since you can open eml using outlook.
      • Ed2 says
        November 7, 2016 at 3:31 pm
        Thought I would follow up on this. It doesn't work, OpenSharedItem doesn't support .eml files.
  4. hchia says
    September 14, 2016 at 2:46 pm
    I have the same issue as Chris. I get a copy of the imported messages in the selected folder, and a copy in the default PST's "Inbox" folder. Does the macro have to be tweaked to avoid saving to the default PST's "Inbox" folder?
    Thanks much.
      September 14, 2016 at 11:20 pm
      Try changing
      oMsg.Close olDiscard
      to
      oMsg.Delete
  5. chris says
    April 18, 2016 at 11:51 am
    Works great except I get two of each msg contacts. Any ideas?
  6. Thierry says
    January 27, 2016 at 10:03 am
    This code dont work with outllok 2013.
    Thierry
      January 27, 2016 at 1:18 pm
      What happens when you try? (Before publishing it was tested in 2013 and 2016 and worked.)
      • Thierry says
        February 5, 2016 at 4:03 am
        Hello, I have one error on this line "Dim fso As Scripting.FileSystemObject" Thanks Thierry
        February 5, 2016 at 9:36 am
        Did you set a reference to the filescripting object in Tools, References? Look for Microsoft Scripting Runtime in the list and add a check in the box.
      • Andrzej says
        February 15, 2016 at 5:34 am
        Dear,
        I have a problem:
        When I change SourceFolder to F:\ (CD-ROM)
        I receive an error :
        run-time error '-2147024809 (80070057)'
        If I change SourceFolder to hard drive (“c:\temp\”) it’s OK.
        Can you help ?
        I need from time change SourceFolder from HDD to CD_ROM (btw SourceFolder become key reg value…)
        Andrzej
        April 28, 2016 at 1:20 pm
        You're referring to it as "F:\" ? it's possible that scripting needs read/write access, which it won't typically have with a cd.
      • Tim Haight says
        July 25, 2017 at 5:55 pm
        I also got the run-time error '-2147024809 (80070057)'.
        I moved the files to SourceFolderName = "C:OutlookFiles"
        I still get the error
      • Thierry says
        August 24, 2016 at 7:36 am
        Thanks for your replay. I have set the filescripting object in Tool and all is OK.
        I Have 2 questions :
        -It s possible to select Save Folder and Source Folder, in the same way that the project "Saving All Messages..." ?
        -it s possible to give tips for you, all your code are perfect ?
        September 15, 2016 at 12:53 am
        You could select the folders, i should have some code samples on the web site that shows how to do it, both in outlook and in windows.
        Browse for folder function: https://www.slipstick.com/developer/code-samples/windows-filepaths-macro/
        Outlook folder pciker: https://www.slipstick.com/developer/pick-contacts-using-vba/
      January 27, 2016 at 1:28 pm
      BTW, You need to set a reference to the Microsoft Scripting Runtime in Tools, References. If the reference is not set, you’ll receive a Compile error: User-defined type not defined.
Latest EMO: Vol. 31 Issue 5
