This macro sample watches the Inbox for new messages and checks for a contact for the sender. If there is a contact and it has one or more categories assigned to it, the Contact's categories are added to the message.
This macro, as written, is an ItemAdd macro and checks all messages that are added to the Inbox but it can be converted to run in a run a script rule instead. To use it to categorize messages already in your inbox or test it without sending messages, select a message and run the ContactCategoriesManual macro.
Private WithEvents olInboxItems As Items
Dim objNS As NameSpace
Set objNS = Application.Session
' instantiate objects declared WithEvents
Set olInboxItems = objNS.GetDefaultFolder(olFolderInbox).Items
Set objNS = Nothing
'Use this to run the macro on a message already in the Inbox
Public Sub ContactCategoriesManual()
Dim objMail As Object
Set objMail = Application.ActiveExplorer.Selection.Item(1)
olInboxItems_ItemAdd objMail
Set objMail = Nothing
Private Sub olInboxItems_ItemAdd(ByVal Item As Object)
'To use in a run a script rule
'Sub ContactCategories(Item As MailItem)
Dim oContact As Outlook.ContactItem
Dim oSender
Set oSender = Item.Sender
If Not oSender Is Nothing Then
Set oContact = oSender.GetContact
Set oSender = Nothing
If Not oContact Is Nothing Then
Item.Categories = oContact.Categories
Set oContact = Nothing
Item.Save
Set Item = Nothing
Move Messages to Folder Based on Contact Category
This version of the macro moves messages to a folder based on the category assigned to the sender's contact. This version of the macro works with multiple categories assigned to a contact but if the sender's contact has more than one category match, the message is not moved. You'll need to move the message to the correct folder yourself.
You can use partial category names in arrCategoryName, but you need to use enough characters to be unique. Use lower case!
Dim olInbox As Outlook.Folder
' update with correct inbox
Set olInbox = objNS.GetDefaultFolder(olFolderInbox)
Set olInboxItems = olInbox.Items
Set objNS = Nothing
Dim oSender
Dim strFolderName As String
Dim strCategoryName As String
Dim arrCategoryName As Variant
Dim arrFolder As Variant
Dim arr As Variant
j = 0
Debug.Print oContact.FullName
Debug.Print oContact.Categories
strContactCats = oContact.Categories
' Set up the array, use lower case
arrCategoryName = Array("sales", "service", "accounting", "client")
' folder names subfolders of Inbox
arrFolder = Array("Sales", "Service Requests", "Accounting & Invoices", "Call Back")
' Go through the array and look for a match, then do something
For i = LBound(arrCategoryName) To UBound(arrCategoryName)
If InStr(LCase(strContactCats), arrCategoryName(i)) > 0 Then
j = j + 1
strFolderName = arrFolder(i)
Debug.Print j, strFolderName
Next i
' We count matches and don't move if there is more than one match
If j > 1 Then Exit Sub
If strFolderName = "" Then Exit Sub
' set the move to folder
Set MoveFolder = olInbox.Folders(strFolderName)
Item.Move MoveFolder
Set Item = Nothing
How to use this macro
- Expand Project1 and double click on ThisOutlookSession.
- Copy then paste the macro into ThisOutlookSession. (Click within the code, Select All using Ctrl+A, Ctrl+C to copy, Ctrl+V to paste.)
Can this be used on sent emails as well?
Not as written, but with a little tweaking, it could work on sent mail.
Is it possible to auto assign categories as emails come in with utilizing some sort of loop? For example, if 4 people utilize an inbox, I'd like to have the first incoming email be assigned to AA, the second incoming email assigned to BB, the third to CC, the fourth to DD, the 5th to AA, the 6th to BB, and so on.
Thank you for your help.
Now I've gotten two run-time errors:
The line Debug.Print oContact.FullName is triggering Run-time error 91 (Object variable or With block variable not set). When I hover over yellow section it reads: oContact.Fullname =
The line Set oSender = Item.Sender is triggering run-time error 438 (Object doesn't support this property or method). When I hover over the yellow line it reads: oSender = Empty
The good news is that the script actually did work for a minute and automatically sorted my incoming test email into the correct folder! That was a very happy moment for me!
Thank you so much! I think the mail sorter will work for me; one question has come up though. The line [Debug.Print oContact.Fullname] is highlighted in red. Previously Outlook threw me into debug mode and highlighted this line in yellow. I don't know what the issue is or how to proceed. Any ideas? Thank you.
I am getting a Compile Error: "Invalide attribute in Sub or Function" at "WithEvents olInboxItems As Items"
Can you direct me! Thanks, Cris
Did you put the maco in ThisOutlookSession?
Is that line at the top of the page, above the Private Sub Application_Startup() line?
