The macros in this article will insert a specific signature file into a message.
The first macro creates a new message with a specific signature file inserted. (You can use this method to insert any HTML file into a message.)
Public Sub CreateMessageSignature()
Dim objMsg As MailItem
Dim strBuffer As String
enviro = CStr(Environ("appdata"))
Debug.Print enviro
Set objFSO = CreateObject("Scripting.FileSystemObject")
' Edit the signature file name on the following line
strSigFilePath = enviro & "\Microsoft\Signatures\"
Debug.Print strSigFilePath
Set objSignatureFile = objFSO.OpenTextFile(strSigFilePath & "My Sig.htm")
strBuffer = objSignatureFile.ReadAll
objSignatureFile.Close
With objMsg
.Subject = "Subject goes here"
.HTMLBody = "Something here.
" & strBuffer
.Display
Change Signatures
If you need to change a signature in a reply, you will need to remove the signature that was added automatically and insert a new one. If you are creating a new message or not keeping the message body, you can insert an HTML signature directly into .HTMLBody.
This macro removes the default signature and adds a new one. After using this macro, the signature bookmark is removed and you will not be able to change the signature automatically. You will be able to insert another signature manually.
You will need to set a reference to the Microsoft Word Object Library in Tools, References.
Sub ReplywithChangeSig()
Dim Item As Outlook.MailItem
Set Item = Application.ActiveExplorer.Selection.Item(1)
Dim olInspector As Outlook.Inspector
Dim olDocument As Word.Document
Dim olSelection As Word.Selection
Set myreply = Item.Reply
myreply.Display
Set olInspector = myreply.GetInspector
Set olDocument = olInspector.WordEditor
Set olSelection = olDocument.Application.Selection
Set oBookmark = olDocument.Bookmarks("_MailAutoSig")
If Not oBookmark Is Nothing Then
oBookmark.Select
olDocument.Windows(1).Selection.Delete
With olSelection.Borders(wdBorderBottom)
.LineStyle = wdLineStyleSingle
.LineWidth = wdLineWidth025pt
.Color = wdColorGray10
myreply.HTMLBody = "
" & strBuffer & myreply.HTMLBody
olSelection.MoveStart
' uncomment to send
'myReply.Send
End SubSample macros that insert stationary files into new messages are at
How to use the Macro
To check your macro security in Outlook 2010 and newer, go to File, Options, Trust Center and open Trust Center Settings, and change the Macro Settings. In Outlook 2007 and older, it’s at Tools, Macro Security. If Outlook tells you it needs to be restarted, close and reopen Outlook. Note: after you test the macro and see that it works, you can either leave macro security set to low or sign the macro.
- Right click on Project1 and choose Insert > Module
- Copy and paste the macro into the new module.
- Set a reference to the Word Object Model in the VBA editor's Tools, References dialog.
Brett says
Hi Diane, I'm not super familiar with coding, but I wonder if you might be able to advise me on a similar code I found and pasted into a Excel doc I use:
Sub savesheet() Dim Name As String Application.ScreenUpdating = False Application.DisplayAlerts = False ActiveWorkbook.Save Name = "Grocery & Dairy 3rd Shift ABSENTEE BLANK (1ST SHIFT)" & ".xlsm" ActiveWorkbook.SaveAs Filename:=Name Application.DisplayAlerts = True Application.ScreenUpdating = True End Sub Sub EmailWBAttached() Dim OutApp As Object Dim OutMail As Object Set OutApp = CreateObject("Outlook.Application") Set OutMail = OutApp.CreateItem(0) On Error Resume Next With OutMail .To = "email@test.com" '<-- enter email addresses here. Multiple emails separate by comma .CC = "" .BCC = "" .Subject = "3rd Shift Attendance: " & Format(Now(), "mm.dd.yy") '<-- enter subject here .Body = "Attached is the attendance sheet or revision to 3rd Shift Grocery & Dairy." '<-- enter message body here .Attachments.Add Application.ActiveWorkbook.FullName '.Send 'or use .Display .Display End With On Error GoTo 0 Set OutMail = Nothing Set OutApp = Nothing End SubThis composes an email with the excel attachment to pre-filled recipients but it doesn't attach a signature in the email and I'd like it to. Do you know how I would alter this code to attach the signature of whoever uses this file? Bear in mind, their signature does have a picture of the company logo in it. As an example, the pathway to my signature is C:\Users\bhar05h\AppData\Roaming\Microsoft\Signatures
Juan Ruiz says
This is a great script. Best I've seen about adding the signature.
I tried the add signature (in Excel) and works with the exception of three missing images that are present when email is manually created in Outlook. Any suggestions?
Branislav Krljanac says
Hi there,
can anyone tell me how to enter any text (e.g. Greetings.....plus signature)
into an existing mail that has no body text yet, but it has already recipient
selected.
So the macro should not create an email.
Instead the text should be added into the existing message.
Name of the recipient should be added into the body, like Dear & Recipient...
Thanks a lot in advance.
Branislav
Carl Stephens says
strSignature = .HTMLBody 'the signature is there, so get it before overwriting the body
.HTMLBody = "Hello " & Sheets("OT").Range("L2").Value & "," & strSignature '< concatenate the signature to the end
This basically uses a greeting ("Hello") and looks up the persons name on a spreadsheet and adds the signature afterwards.
Reuben Geoffrey Dayal says
Can you guide me on how can I use the text before the current email's auto signature bookmark? I am trying to search for a keyword "follow up" in my current reply, to trigger a macro for setting a reminder. It is important to only search the text in the current reply (before the auto signature) to verify whether the keyword exists, and only then trigger the macro else, do nothing.
Thank you in advance.
rino19ny says
was looking for something like this and found a VB script instead that creates new signatures and makes it the default. pretty basic but you can insert company logo. is it permitted to post here the code? the original author is still there mentioned in the code.
Diane Poremsky says
Yes, you can post it here.
Oliv says
Please take a look at my code that uses ribbon and UIAUTOMATION
https://www.developpez.net/forums/blogs/191381-oliv/b4076/inserer-signature-lemail-actif-outlook-2016/
Diane Poremsky says
I wouldn't say its any better than reading the signature file and inserting - it's basically sendkeys. (If Outlook supported 'screenupdating = false' it would be better - i wouldn't have to watch the signature selector expand and the mouse move.)
As a demo for UIAUTOMATION, its good - and could be very useful to do other things in Outlook.
Oliv says
The behavior is different if we run the macro from Excel, in this case we can just use DoDefaultAction, but not when we run it from OUTLOOK !
it is useful if the signature contains images.
Public Sub CreateMessageSignatureWithImage()Dim objMsg As MailItem
Dim enviro, objFSO, strSigFilePath, objSignatureFile
Dim strAtt, SplitAtt, EmbAtt As Attachment
Debug.Print enviro
Set objSignatureFile = objFSO.OpenTextFile(strSigFilePath & "Oliv.htm")
SplitAtt = Split(strBuffer, "src=""", , vbTextCompare)
If UBound(SplitAtt) > 0 Then
strAtt = Split(SplitAtt(1), """")(0)
With objMsg
.HTMLBody = "<p>Something here.</p><p> </p>" & strBuffer
If strAtt <> "" Then
Set EmbAtt = .Attachments.Add(strSigFilePath & Replace(strAtt, "/", "\"))
If InStr(1, objMsg.HTMLBody, strAtt, vbTextCompare) > 0 Then
objMsg.HTMLBody = Replace(objMsg.HTMLBody, strAtt, "cid:" & EmbAtt.DisplayName)
.Display
blake says
I tried running this macro in Outlook 2016 and it will not run "Compile error: User-defined type not defined."
Does this only work for certain Outlook versions? Was hoping to get this to work on 2016
Diane Poremsky says
It works in all the current versions. In the VBEditor's Tools, References, is the Microsoft Word object library checked? (It looks li8ke i forgot to mention that in the instructions.)
Diane Poremsky says
You can edit the code to use late binding (which will avoid the need to set the word object model), but not all word features will be available if you do this - in the macro no this page, specifically the few lines that set a border will error.
To use late binding instead - add these to up at the top with the other dim statements:
Dim Word As Object
Set Word = CreateObject("Word.Application")
then change these two to use object -
Dim olDocument As object 'Word.Document
Dim olSelection As object ' Word.Selection
