Create a custom printout in Outlook
› Developer › Create a custom printout in Outlook
Last reviewed on April 29, 2014     No Comments
An Outlook user wanted to print only the custom fields in a Task:
Is there any way to hide the default Task fields on a print out? All of the fields appear when I print the task and I only need specific fields.
The default task printout
Although you can't edit the print templates, you can use a macro to create a draft message and print it.
The following code puts together a string containing some of the Task fields of a selected task, including two custom fields, and adds them to a message body. It prints the message then deletes the draft message.
Custom fields are referenced using .UserProperties("fieldname"). Format the date field as "May 3 2014" using Format(olTask.StartDate, "MMM d yyyy") .
To use, select one or more tasks, then run the macro. A message will be created and printed for each task in the selection.
This method is not limited only to tasks; you can use it with any Outlook item type with just a little tweaking of the code to change the fields and item type.
Sub PrintTasks()
    Dim olTask As Outlook.TaskItem, olMsg As Outlook.MailItem
    Dim strBody As String
    For Each olTask In Application.ActiveExplorer.Selection
'put your fields together here
     strBody = olTask.Subject & vbCrLf & olTask.Body & vbCrLf
     strBody = strBody & olTask.StartDate & vbCrLf & olTask.UserProperties("Contact Name") & vbCrLf & olTask.UserProperties("Email Address")
        Set olMsg = Application.CreateItem(olMailItem)
        With olMsg
            .BodyFormat = olFormatPlain
            .Body = strBody
           ' .Display
            .PrintOut ' print automatically
            .Close olDiscard
    Set olMsg = Nothing
How to use macros
Create a custom printout in Outlook was last modified: April 29th, 2014 by Diane Poremsky
  • Send a Task Status Report
  • Create Tasks from Email and move to different Task folders
  • Create a custom field for Outlook messages
  • Create a Custom Numbering Field for Outlook messages
Latest EMO: Vol. 31 Issue 3
