How to use an ItemAdd Macro
› Developer › How to use an ItemAdd Macro
Last reviewed on July 19, 2020     13 Comments
An ItemAdd macro watches a specific folder and runs a macro on it as messages are dropped into it, using any method: using rules, dragging messages to the folder, using the move or copy to folder command, or even copy and paste in place.
You can watch any folder that is in your profile using ItemAdd, including share folders; you can watch more than one folder, but you need to identify each folder in the Application_Startup macro.
"Processing Incoming E-mails with Macros"
When you use an Application_Startup macro, you set a variable that Outlook remembers while it's open (one exception: if any macro fails, the variable will be forgotten).
If you need to watch more than one folder, you'll need to use declare another variable name (Private WithEvents... ) and set it in the Application_Startup macro. Each folder will have it's own variable.
Option Explicit
Private objNS As Outlook.NameSpace
Private WithEvents objItems As Outlook.Items
Dim objWatchFolder As Outlook.Folder
'Set the folder and items to watch:
Set objWatchFolder = objNS.GetDefaultFolder(olFolderInbox)
Set objItems = objWatchFolder.Items
Set objWatchFolder = Nothing
Along with telling Outlook which folder(s) to watch, you need the ItemAdd macro that tells Outlook what do when a new item is dropped in the folder. You'll do this with a macro that has the variable name in it's name: Private Sub objItems.ItemAdd(ByVal Item As Object). If you are watching more than one folder, each folder will have it's own macro.
When the ItemAdd macro fires, you'll refer to the items using the variable set in parenthesis. In this example, it's Item: (ByVal Item As Object).
Private Sub objItems_ItemAdd(ByVal Item As Object)
' Your code goes here
MsgBox "Message subject: " & Item.Subject & vbcrlf & "Message sender: " & Item.SenderName &" (" & Item.SenderEmailAddress & ")"
Set Item = Nothing
All of the code used in an ItemAdd macro goes in ThisOutlookSession.
To test your macro without restarting Outlook, place the cursor in the Application_Startup macro and click Run. To test the ItemAdd macro without sending yourself mail, you can select an item, copy and paste in place (Ctrl+C, V). Alternately, you can drag an item from another folder and drop it in the folder you're watching. Eitehr method will trigger the ItemAdd macro.
Watch other folders
You can watch any folder in your profile. The folders in your default data file will use GetDefaultFolder method, including folders you added. If you're watching a folder you added, use this format:
Set objWatchFolder = objNS.GetDefaultFolder(olFolderInbox).Folders("Folder name")
If the folder is in another data file, you'll need to use the GetFolderPath function on "this page" and reference it using the display name in the navigation pane: GetFolderPath("me@domain.com\My Stuff").
Shared Exchange mailboxes will use the GetSharedDefaultFolder method.
See "Working with VBA and non-default Outlook Folders" for help referencing other folders in a macro. There is a list of default folder references on that page, along with the GetFolderPath function and code that uses the GetSharedDefaultFolder method.
If you need to watch two (or more) folders and run the same macro on each, you'll need to set each folder name variable and create an ItemAdd macro. If the macro is short, duplicating the code isn't a big deal, but you can call another macro instead of repeating the same code multiple times.
In this example, I'm watching two folders (set in the Application Startup macro, not shown here) and when a new item arrives, it passes the Item object to another macro to do something.
Private Sub slipstickItems_ItemAdd(ByVal Item As Object)
SetCategories Item
Private Sub cdoliveInbox_ItemAdd(ByVal Item As Object)
SetCategories Item
Private Sub SetCategories(ByVal Item As Object)
' do something
End if
ItemAdd Macro Samples
  • Create Appointment From Email Automatically
  • How to Change the Font used for Outlook's RSS Feeds
  • How to Process Mail After Business Hours
  • Process messages received on a day of the week
  • Processing Incoming E-mails with Macros
  • Use VBA to move messages with attachments
How to use an ItemAdd Macro was last modified: July 19th, 2020 by Diane Poremsky
  • Clean up the Junk Email folder
  • Use a VBA macro to monitor a folder in a secondary mailbox for new mes
    Monitor secondary mailbox folder for new messages
  • Process Mail that was Auto Forwarded by a Rule
  1. Kevin says
    April 28, 2023 at 12:09 pm
    This is beautiful! Thanks!
  2. George says
    September 2, 2022 at 5:29 pm
    Thanks for the article. I modified it to use on Outlook 2016 Calendar. It worked well when I did ItemAdd (without ItemChange). :
    However when I added Sub objItems_ItemChange, the VBA would no longer run. Would you know why this is so please? and how to correct the code to have both ItemAdd and ItemChange working at the same time?
    My desired result is Msg whenever a new appointment is added or an existing appointment is modified.
    Kindly find below modifcations I made, based on your code:
    Option Explicit
    Set objWatchFolder = objNS.GetDefaultFolder(olFolderCalendar)
    ' MsgBox "Message subject: " & Item.Subject & vbCrLf & "Message sender: " & Item.SenderName & " (" & Item.SenderEmailAddress & ")"
    ' https://www.slipstick.com/developer/itemadd-macro
     MsgBox "*** PROPERTIES of olFolderCalendar ***" & vbNewLine & _
            "Subject: " & Item.Subject & vbNewLine & _
            "Start: " & Item.Start & vbNewLine & _
            "End: " & Item.End & vbNewLine & _
            "Duration: " & Item.Duration & vbNewLine & _
            "Location: " & Item.Location & vbNewLine & _
            "Body: " & Item.Body & vbNewLine & _
            "Global Appointment ID: " & Item.GlobalAppointmentID
    Set Item = Nothing
    Private Sub objItems_ItemChange(ByVal Item As Object)
    Set Item = Nothing
  3. George says
    September 2, 2022 at 4:08 pm
    Hi Diane, thank you for this article. It helped me greatly.
  4. gvg says
    February 4, 2022 at 7:11 am
    Great macro! Is there a way to deal with exception situation: "(one exception: if any macro fails, the variable will be forgotten)."
  5. gvg says
    December 17, 2021 at 4:58 am
    I am getting compile error on the following line. It says "Invalid attribute in Sub or Function".
    This is in Outlook in Microsoft 365 Apps for enterprise.
  6. Fernando Vigue says
    October 23, 2017 at 6:32 pm
    Hello Diane. Great article!
    I'm trying to run a version of your code. When an e-mail arrives at my defined folder, Outlook search for some specific phrases in the body. If one of them are there, then i run another code to do other stuff. If not, then the macro does nothing.
    I can't create a rule and use the "execute a script" option because it is not available. Is my work pc and the IT is very annoying with alterating the reg so i don't consider this a possibility. Could you help me out? I've changed the code back to your model and language because my native language is not English so it would be very hard to you read.
    Option Explicit
    'Aqui você define qual a pasta que vai rodar esta macro.
    Set objWatchFolder = objNS.Folders("xxxxxxx@xxxxxx.com").Folders("xxxx1").Folders("xxxx2")
    'Eu escolhi ficar de olho em todos os items que chegam na pasta, sem exceção.
    Set objItems = objWatchFolder.Items '("Resultado do processamento das ORDENS (Upload)")
    'Inserir o código que você quer rodar
    'MsgBox "Teste"
    Set Item = Nothing
  7. Peter Braun says
    January 14, 2017 at 3:23 pm
    Thank you very much for posting. I thought I had left this comment yesterday but it seems to have disappeared now. Did I do something wrong? Maybe I just didn’t post it correctly…
    I’m trying to run a version of your code to watch a particular folder for new items.
    The problem is that when I try to set my WithEvents variable, it seems to disappear after the Application_Startup sub finishes: it’s empty in in my watch window when I run other subs and the ItemAdd sub I built on it doesn’t fire when an item is added.
    I know I’ve assigned my variable to the right folder because the correct subject prints from the Debug.Print clntFldrItms.item(1).Subject line.
    I also know that the Application_Startup sub runs on startup because every time I open Outlook, the VBA editor opens and code has stopped at the Stop command.
    I’m using Outlook 2016 with an IMAP email address (gmail).
    All code is in ThisOutlookSession. Code below.
    Any help you can provide would be really appreciated. Thank you!
    Peter
    Option Explicit
    Public WithEvents clntFldrItms As Outlook.Items
    Dim clntFldr As MAPIFolder
    Set clntFldr = Application.Session.GetDefaultFolder(olFolderSentMail).Folders("Client Emails")
    Set clntFldrItms = clntFldr.Items
    Stop
    Private Sub clntFldrItms_ItemAdd(ByVal item As Object)
    Dim bChar As String
    bChar = "/:*?™""® <>|.&@#_+©~;-+=^$!,'" & Chr(34)
    Dim saveName As String
    If item.Class = olMail Then
    saveName = item.Subject
    For x = 1 To Len(bChar)
    saveName = Replace(saveName, Mid(bChar, x, 1), "-")
    Next x
    item.SaveAs "C:UsersUserGoogle Drive8 - VBA workPreparation for Assisted ResponderSent Messages Folder" & _
    saveName & ".msg", olMSG
      January 16, 2017 at 12:17 am
      the previous comment was here - comments are held in moderation queue until I have time to answer them, otherwise they get lost in the mass of comments. (I currently have over 400 comments needing answers - most came in over the Christmas holidays when I took some time off.)
      It works here (after fixing the parts wordpress broke & using a valid file path). On the file path, does it end with a slash? If not, it will save in the wrong folder. Rather than debug.print in the startup (or in addition to), add a debug.print before the save to print the full file path.
      Debug.Print "C:\Users\Diane\Documents\Test\" & saveName & ".msg"
      I would remove the stop -this can cause the app startup to stop working, and will if you don't finish running the code. Use a msgbox to pop up a message if you want to know if it is working.
  8. Russell says
    January 5, 2017 at 2:56 pm
    Great article - I used your code almost unmodified to check when someone changed a shared contact so I could update another system and keep them in-sych. I have one issue though.....
    How can I tell if the 'call-back' gets broken? The code seems to work just fine, but the application runs unattended and updates to contacts do not happen so often. After days/weeks, someone will say 'it's not working'. I go in and there are no errors on the screen. Exit Outlook and restart. Everything works again. I am assuming that the call-back is somehow broken, but I'm not sure. How can I test for that?
    Russell
      January 16, 2017 at 12:26 am
      I'm not aware of a way to alert you if it's not working - other than something popping up a message box when it runs - but if its unattended, no one will see it. If it hits an error, the macro can quit working but if you use an error handler it should keep on working.
  9. Barrett says
    May 10, 2016 at 3:12 pm
    For anyone getting a "Compiler Error: Expected end of statement" error when trying the code above, change the line that says
    to
    which has an underscore instead of a period. It started working fine for me after that. Great post!
      May 10, 2016 at 3:59 pm
      What version of Outlook are you using? It should work with the underscore and not with the dot.
  10. 356688 says
    February 12, 2016 at 9:28 pm
    It's not bad
Latest EMO: Vol. 31 Issue 5
