Shortcuts and the Missing Outlook:// Protocol
› Problems › Shortcuts and the Missing Outlook:// Protocol
Last reviewed on November 15, 2021     49 Comments
As many users have discovered, the Outlook:// protocol no longer works outside of Outlook 2007 (and up). This protocol allows users to create shortcuts to Outlook items and open the items outside of Outlook. You can use this protocol on a folder home page, on the Web toolbar, or in the body of an Outlook item but not in a web page that does not open in a folder homepage.
See Using Outlook Links to learn how to use the Outlook:// protocol
This is because the Office installer no longer registers Outlook to a URL protocol. This is due to Microsoft not officially supporting the Outlook URL protocol as explained in KB 929590 Fortunately, Outlook still supports it, but to use it, you will need to add it as a URL protocol in the Windows Registry.
The Fix
Note: It is recommended that your make a backup copy of your registry before editing the registry.
You'll need to use the path to your Outlook - for the 64-bit click to run version of Outlook 2016, 2019, 2021 and 365, Outlook.exe is at C:\Program Files\Microsoft Office\root\Office16\outlook.exe
In 32-bit Outlook 2016, 2019, 2021 and 365, Outlook.exe is at C:\Program Files (x86)\Microsoft Office\root\Office16\outlook.exe using Click-to-run (most people will have click to run).
In Outlook 2007, the path is "C:\Program Files\Microsoft Office\Office12\OUTLOOK.EXE"; in Outlook 2010, "C:\Program Files\Microsoft Office\Office14\OUTLOOK.EXE"
  1. Open the registry editor and select root key HKEY_CLASS_ROOT
  2. Add a new Key named “outlook”
  3. Edit the (Default) string value and add URL:Outlook Folders
  4. Add the new string value “URL Protocol”, no string value is required
  5. Add subkeys \shell\open\command
  6. Select the Default Icon key and enter:
  7. C:\Program Files\Microsoft Office\root\Office16\outlook.exe
    Note: If you are using a 64-bit Windows operating system with 32-bit Outlook, then instead of “Program Files” use “Program Files (x86)”. Don't forget to use the correct version of Office!
  8. Select the command key value under shell\open, edit the (Default) string value and add the following string: (Note this assumes you installed Office in the default location/) You need to include the double quotes in the string.
    "C:\Program Files\Microsoft Office\root\Office16\outlook.exe" /select "%1"
Outlook Protocol key
You can test it by clicking here. If Outlook opens to your Inbox, the keys were created correctly.
Do It for Me
To use, download the correct file for your system then double click to add the key to your registry.
If you are using the same "bitness" of Windows and Outlook (both are 32-bit or both are 64-bit):
Outlook 2016/2019/365 Outlook 2013
Outlook 2010 Outlook 2007
If you are using 32-bit Outlook on 64-bit Windows:
Outlook 2016/2019/365 (32-bit/Wx64) Outlook 2013 (32-bit/Wx64)
Outlook 2010 (32-bit/Wx64) Outlook 2007 (32-bit/Wx64)
Note: Outlook does not automatically recognize the Outlook protocol when you type a url containing it into the body of any item. However, the protocol works if you set it as a hyperlink.
Known issues when you develop custom solutions for Office Outlook 2007
For general information on registering an application to a URL protocol, see Registering an Application to a URI Scheme
Shortcuts and the Missing Outlook:// Protocol was last modified: November 15th, 2021 by Diane Poremsky
  • Classic Outlook Missing from Computers
  • Using Scanpst in Outlook Click to Run
  • .XNK Extension Error: "Cannot Open File"
  • Opening .exe Attachments and Outlook E-mail Security
  1. Gerard says
    May 31, 2024 at 4:46 am
    does this work for W11?
      May 31, 2024 at 4:46 pm
      Yes, it works in Windows 11.
  2. JanosV says
    August 17, 2022 at 5:14 pm
    I can't thank enough for this solution!
    I have ca. 1,500 PST subfolders in Outlook (2007). To access them easily I created an Excel (2007) sheet with all folder paths exported, search box and a macro added to call the hyperlink protocol for the selected path.
    It worked like charm for months and my life was happy. However, after the recent W10 patch (KB5015807) Outlook started refusing the hyperlink calls saying 'Cannot display the selected folder or item'. It also says it may be due to spaces allegedly included in the path names and I should replace them with %20, which the system by the way automatically did.
    After rolling back the update already twice, the protocol works again.
    Can anyone give me a clue why it is happening?
  3. Nicholas Davidowicz says
    November 11, 2021 at 1:34 pm
    On my system (Windows 10) I have an extra subdirectory and I had to adjust the paths to
    "C:\Program Files\Microsoft Office\root\Office16\OUTLOOK.EXE"
    • Chris says
      April 28, 2023 at 6:53 pm
      Thanks so much. This note saved me.
  4. anonymous user says
    September 11, 2020 at 4:34 am
    How do i launch outlook with existing eml file using url scheme.
    From html anchor tag..?
    it opens from commandline
    "C:\Program Files (x86)\Microsoft Office\Office15\OUTLOOK.EXE" /eml "C:User\Desktop\20200708091507_7297827F823C258E179F59FD347.eml"
    I want it in <a href ="outlook ://> format
      September 11, 2020 at 11:59 pm
      The outlook protocol is used for items in the mailbox, bot saved to the hard drive. Files on the hard drive use the computer's file association.
    • Balaji says
      April 15, 2021 at 8:07 am
      Try webcal://
        April 15, 2021 at 8:48 am
        That will only work for calendars items.
      • Balaji says
        April 15, 2021 at 11:52 am
        It launches the client outlook not just the calender, i am using this feature which is working so far good.
      • Balaji says
        April 15, 2021 at 1:16 pm
        This launches the Outlook client, I used this protocol and it worked..
  5. Marcin says
    January 2, 2019 at 9:00 am
    Instruction in this article are not enough for Outlook 2016. I got it to work by also adding an empty string value named "URL Protocol" in key "Computer\HKEY_CLASSES_ROOT\Outlook"
  6. Peter says
    November 2, 2018 at 3:23 am
    Hi! Thank you, this worked perfectly for me in Win7 & Outlook13. Moving to Win10 & Outlook16 now, the Windows Shell asks for admin rights. This is not the case with every .vbs, but with this one. Any idea maybe?
      November 3, 2018 at 12:56 am
      which vbs are you use?
  7. Gerard says
    October 1, 2018 at 12:25 pm
    Hi, any alternative if we are not allowed do modify the registry?
      October 25, 2018 at 6:49 pm
      Unfortunately not. Sorry for missing this earlier. :(
    • Gerard Goddard says
      September 8, 2022 at 5:08 am
      Hi, I had the same issue, i dont have admin rights in my machine. However, if you can run regedit, you should have access to modify the [HKEY_CURRENT_USER] tree.
      I replaced all the [HKEY_CLASSES_ROOT] with [HKEY_CURRENT_USER] as follows:
      [HKEY_CURRENT_USER\SOFTWARE\Classes\outlook]
      @="URL:Outlook Folders"
      "URL Protocol"=""
      [HKEY_CURRENT_USER\SOFTWARE\Classes\outlook\DefaultIcon]
      @="\"C:\\Program Files\\Microsoft Office\\root\\Office16\\OUTLOOK.EXE\""
      [HKEY_CURRENT_USER\SOFTWARE\Classes\outlook\shell]
      @="open"
      [HKEY_CURRENT_USER\SOFTWARE\Classes\outlook\shell\open]
      [HKEY_CURRENT_USER\SOFTWARE\Classes\outlook\shell\open\command]
      @="\"C:\\Program Files\\Microsoft Office\\root\\Office16\\OUTLOOK.EXE\" /select \"%1\""
      and IT WORKED!! I run W10 64bits + Outlook 365 64 bits
  8. David says
    June 7, 2018 at 10:09 pm
    Once again thank you Diane. Your help has enabled me to complete my vision for the way I use OneNote !
  9. Cort says
    June 28, 2017 at 12:35 pm
    Do you know of any "security" concerns on why I wouldn't want to change the registry? I have several paralegals who need this functionality but other folks here are worried that changing the registry in Windows 10 to make this work will affect security. Thoughts?
      June 28, 2017 at 3:54 pm
      No, not to my recollection, but at this point, it's security by obscurity as only a small % of users would have the key set. :) It was removed as part of the deprecated feature that allowed you to use outlook as a file explorer.
  10. Tom says
    June 2, 2017 at 8:20 pm
    Hi, is there any way to do it for Outlook for Mac?
      June 2, 2017 at 8:51 pm
      No, not to my knowledge. sorry.
  11. Ofer says
    March 20, 2017 at 6:33 pm
    I tried the "Outlook 2016 (32-bit/Wx64)" its in the registry
    Now I added in an index.html a line
    <a > Outlook
    clicking on it does nothing.
    How do I use the Outlook:// protocol in html?
      March 20, 2017 at 11:19 pm
      how did you format the link? https://www.slipstick.com/outlook/using-outlook-links/ has examples. This would open the sent folder in a users exchange mailbox: Outlook://Mailbox - Mary Conrad/Sent Items
      • Ofer says
        March 29, 2017 at 7:04 pm
        For may own mailbox it is working fine with: Conversation historyOfer or any other folder
        For the added mailbox I have access to (test22@Novuslaw.com)
        I tried most combinations and I get "Cannot display the selected folder or item"
        //Mailbox - test 22inbox'
        //Mailbox - test22@Novuslaw.cominbox
        Any suggestions?
        thanks
        April 2, 2017 at 7:43 am
        Did the mailbox sync? If not, do you have full access permissions?
        Assuming the mailbox actually synced - did you try resetting the view on the folder?
    • John says
      March 24, 2017 at 12:42 pm
      I was having trouble with the 2016 reg file also. It turns out the path to outlook on my machine did not have the root folder. The corrected path is this:
      "C:\Program Files (x86)\Microsoft Office\Office16\Outlook.exe"
      When I made that change in the registry it worked. I also added "/recycle" before "/select" as suggested by okDude so that it would reuse the current Outlook window when opening folders. Works great...thank you okDude!
      And thanks so much Diane for this tip. I used it in Outlook 2013 also. I find it really handy for referencing my Evernote notes back to emails.
        April 2, 2017 at 7:45 am
        Yeah, if you have 3 bit outlook, you need 32bit key.
  12. Tomaka says
    February 14, 2017 at 12:22 pm
    This works great, even with Outlook 2016 64 bits!
    But using it from another office program, I still have to deal with security check. How do you add the " Outlook://*" protocol to trusted websites ? It doesn't pass the coherence test, I think we should add it directly to the registry but don't know how.
      March 20, 2017 at 11:26 pm
      Try this - https://www.slipstick.com/how-to-outlook/disable-unsafe-hyperlink-warning-opening-attachments/
  13. Sharon Phelps says
    September 29, 2016 at 3:13 pm
    I've made the changes to the registry for my version of Outlook (2010, and in Program Files folder). I added the link Outlook:Inbox in an Excel worksheet cell as a hyperlink. When I click on the cell, I get a hyperlink warning message. When I click "yes" to continue, a window flashes open then immediately closes. Any thoughts on what is causing this? TIA
      September 29, 2016 at 3:53 pm
      first guess would be the link you are trying to open is not valid.
      Second guess is that the registry key has an error - this should only apply if you edited it yourself.
      • Sharon Phelps says
        September 30, 2016 at 1:17 pm
        Your second guess was right, and though I looked again and again for my error and never found it, when I just deleted my additions and ran your routine, it worked like a charm. Thank you!
  14. OkDude says
    May 9, 2016 at 3:00 pm
    I recommend adding /recycle parameter to the command line so you wouldn't wind up with a new instance of outlook every time you click the URL
    [HKEY_CLASSES_ROOT\outlook]
    "URL Protocol"=""
    [HKEY_CLASSES_ROOT\outlook\DefaultIcon]
    @="C:\\PROGRA~2\\MICROS~1\\Office14\\OUTLOOK.EXE,-9403"
    [HKEY_CLASSES_ROOT\outlook\shell]
    @="open"
    [HKEY_CLASSES_ROOT\outlook\shell\open]
    [HKEY_CLASSES_ROOT\outlook\shell\open\command]
    @="\"C:\\Program Files (x86)\\Microsoft Office\\Office14\\OUTLOOK.EXE\" /recycle /select \"%1\""
  15. Kiran says
    January 6, 2016 at 12:59 pm
    Thank you for this tip Diane. Now the linker program works like charm (https://teamscope.com/support/releases.asp) .
  16. gardoglee says
    July 19, 2015 at 4:52 am
    I had a slight issue when I used the downloadable regedit file. The file created the correct sequence of keys/subkeys as outlook->shell->open, but then placed a subkey under Open of "Command", and inserted the program name ""C:\Program Files\Microsoft Office\Office14\OUTLOOK.EXE" /select "%1"" as the Default string for key "Command". This did not work for me. However, after looking at the instructions above I tried copying the Default string vale from "Command" to the Default string value of the key above "Open". that worked. I am not enough of a windows person to know exaclty why the difference, but I thought it might help some others if they ran into the same issue.
    This posting is awesome! Thank you, as it solves my problem, which was that all the various formats for Outlook reference hyperlinks were not working for me. My sortable ToDo lists in Access and Excel that reference emails to which I must respond and meetings for which I must prepare is much enhanced. I prefer a list I can format, sort, export, link and enhance as I like to the native Outlook task list.
    And for a simple macro to make the pasteable link for an Outllok item (probably already somewhere else on this site, but I did not find it here):
    'Adds a link to the currently selected message to the clipboard
    Sub AddLinkToMessageInClipboard()
    Dim objMail As Object
    Dim doClipboard As New DataObject
    Dim message As String
    'One and ONLY one message muse be selected
    If Application.ActiveExplorer.Selection.Count 1 Then
    MsgBox ("Select one and ONLY one message.")
    Set objMail = Application.ActiveExplorer.Selection.Item(1)
    doClipboard.SetText ""
    doClipboard.PutInClipboard
    Note: You must add the "MS Forms" library reference to support the "doClipboard" object, in order to paste the link to the clipboard, if it is not already default in your configuration.
    The original macro is from https://answers.microsoft.com/en-us/office/forum/office_2010-outlook/vba-create-a-link-to-a-specific-email-and-copy-it/686ec402-8151-4e32-8948-edd33fc801a2. I found that their form with [[...]] bracketing and the subsequent bracketing did not work for me, so this is a simplfied version.The macro is useful in that you can create a hyperlink from whatever the selected item is in your outlook session, and then paste it into something like an Excel spreadsheet, a shortcut, or Word document.
    BTW, the resulting link will open the Outlook item from your local Outlook file without requiring that you log into Outlook or present your Outlook password when the link is invoked on your machine. That implies some nasty things about Outlook security, or lack thereof. Be warned!
  17. Omri Alon says
    November 17, 2014 at 4:45 am
    Hi diane,
    That was a great article.
    Do you know which file works on windows server 2003 with outlook 2007?
    brgds
    Omri Alon
      November 19, 2014 at 1:10 am
      Assuming it's 32-bit Windows, https://www.slipstick.com/doit/OutlookProtocol2007.reg - if you have 63bit windows, it's the other outlook 2007 file.
  18. Andy Mercer says
    October 27, 2014 at 3:21 pm
    I've been working on integrating Outlook direct folder links into an Office 2013 web app, and so I tried this out. I have gotten it mostly working, except that it keeps opening a brand new instance of Outlook. Is there any way to have it just open the current running instance and move the view to the new folder? Thanks!
  19. hathija says
    January 14, 2014 at 4:42 am
    Hello !
    Thanks a lot for the post. For my project i would like to do a link to access Outlook Adress book via a protocol like Outlook:AddressBook but it doesn't work for me ? Do you know the right shortcut ?
      January 15, 2014 at 8:27 am
      You can link to the contacts folder or a specific contact using a url and the outlook:// protocol, but not to the address book specifically.
  20. Jitendra Kumar says
    February 19, 2013 at 4:02 am
    hay thanks a ton for this valuable information
  21. Fabrizio says
    July 31, 2012 at 2:42 am
    I also want to clarify that my href is in a html page,not in a outlook mail.
      July 31, 2012 at 5:34 am
      It should work outside of outlook. I tried to repro it last night but couldn't get it to work on a system with outlook 2013 installed, even though 2010 was open. I'll try today with a different system then see if it will work 2013.
  22. Fabrizio says
    July 30, 2012 at 11:57 am
    I followed all the steps above but I encountred a big issue. When I click the HREF (outlook:+GUID of the email record) I just can only open the outlook application but the selected email.
    Do you have any tip?
    best regards,
    FP
  23. Duran says
    June 21, 2012 at 8:15 am
    This is all great info Diane. I finally got my hyperlinks to open outlook, though I now have a new problem. When I already have outlook open and I click on a link pointing to a folder in outlook, a new outlook window is opened. So at that case I would have two instances of outlook open. How can I make it so that the link opens my folder in my already open outlook? I'm using Outlook 2007 on Windows XP. Thank you in advance!
      June 21, 2012 at 10:15 am
      I'll look into it - if you used the reg file I supplied, try the one from TeamScope. They should be identical, but maybe I missed something he did not.
      BTW, you have two windows open, not two instances. While it seems like splitting hairs, it's not a "full blown Outlook, the resource hog" - it's just another window. It's no different than using right click, open in new window on any Outlook folder.
  24. R.D. Kripner says
    January 27, 2012 at 12:46 am
    We are having more than our share of problems with Outlook 2007. Outlook works just fine on my side, however when I log off my side and my wife logs in on her side, Outlook will not function for her. We have tried deleting and reloading office 2007 to no avail. Has anyone have a solution to this issue ????
      January 27, 2012 at 12:51 am
      What exactly happens when she tries to use it?
Latest EMO: Vol. 31 Issue 3
