Use VBA to read fields in attached messages
› Developer › Use VBA to read fields in attached messages
Last reviewed on February 8, 2018     No Comments
A user came to me with a problem:
I need help. Is it possible to write macro to read the sender email address in the email attached to another message?
Yes, it is possible. You can save the attachment to the hard drive to get the message properties or you can use Redemption to read attachment properties, including addresses and other MAPI fields. I have a sample that uses Redemption at GetAttachmentInfo
email attachment
This sample prints the attached message properties to the Immediate Window. (Look for the Immediate Window command on the View menu or use Ctrl+G to display it.)
get attached message information macro
' Install Redemption
' http://www.dimastr.com/redemption/download.htm
Sub GetAttachmentInfo()
Set olApp = CreateObject("Outlook.Application")
Dim olNS As Outlook.NameSpace
Set olNS = olApp.GetNamespace("MAPI")
Dim oRDOSession As Redemption.RDOSession
Set oRDOSession = CreateObject("Redemption.RDOSession")
oRDOSession.MAPIOBJECT = olNS.Application.Session.MAPIOBJECT
Set Mail = olApp.ActiveExplorer.Selection.Item(1)
Debug.Print "EntryID: " & Mail.EntryID
Set Mail = oRDOSession.GetMessageFromID(Mail.EntryID)
For Each att In Mail.Attachments
  Debug.Print "Filename: " & att.FileName
  Debug.Print "Embedded Msg Subject: " & att.EmbeddedMsg
  Debug.Print "Sent To: " & att.EmbeddedMsg.To
  Debug.Print "Sender: " & att.EmbeddedMsg.SenderEmailAddress
  Debug.Print "SentOn: " & att.EmbeddedMsg.SentOn
If you receive a "User-defined type not defined" error, you need to set a reference to another object library, Redemption Outlook and MAPI COM Library for the macro above. Go to Tools, References menu. Locate the object library in the list and add a checkmark to it.
For more information and links to download Redemption, see RDOAttachment object
Use VBA to read fields in attached messages was last modified: February 8th, 2018 by Diane Poremsky
  • How to change the From field on incoming messages
  • Use an Outlook Macro to Send Files by Email
  • Macro to Add or Remove a Category
  • Filter mail when you are not the only recipient
Latest EMO: Vol. 31 Issue 3
