Move Outlook Folders using VBA
› Developer › Code Samples › Move Outlook Folders using VBA
Last reviewed on February 8, 2018     4 Comments
A client creates folders for each project he works on. When he's finished with the project, he moves it to an 'Old Projects' folder by selecting the folder and using the Move folder command to open the Folder picker to select the old projects folder. It's usually easier to drag the folder to its new parent folder, but his folder tree is large, making dragging unwieldy.
move folders to a new location
He wondered if a macro could handle the move. Yes! The macro can pick up the current folder and move it to a specified folder in the current data file, or in another data file. Note: This macro may not work with folders in IMAP account, especially if the folder contains email. It will move the folder, but the IMAP server rejects the move and the folder reappears in its original position.
In this example, the 'Old Projects' folder is at the same level as the Inbox and other default folders.
move to a new parent folder
Sub Movefolders()
    Dim OutApp As Outlook.Application
    Dim oNS As Outlook.NameSpace
    Dim objInboxFolder As Outlook.MAPIFolder
    Dim objDestFolder As Outlook.MAPIFolder
    Dim curFolder As Outlook.MAPIFolder
Set OutApp = Application
Set oNS = OutApp.GetNamespace("MAPI")
'use the selected folder
Set curFolder = OutApp.ActiveExplorer.CurrentFolder
Set objInboxFolder = oNS.GetDefaultFolder(olFolderInbox)
Set objDestFolder = objInboxFolder.Parent.Folders("Old Projects")
' move folder
curFolder.MoveTo objDestFolder
' copy folder
'curFolder.CopyTo objDestFolder
Delete Folders
With just a small edit, you can use the macro to delete folders. The selected folder will be moved into the Deleted Items folder; by repeating the Delete line, it will be permanently deleted.
Note: Outlook's default folders cannot be deleted.
Sub DeleteFolders()
    Dim oOutlook As Outlook.Application
    Dim objNamespace As Outlook.NameSpace
Set oOutlook = Application
Set objNamespace = oOutlook.GetNamespace("MAPI")
Set curFolder = oOutlook.ActiveExplorer.CurrentFolder
' move to Deleted Items folder
curFolder.Delete
' delete it from deleted items
curFolder.Delete
"Working with VBA and non-default Outlook Folders"
Move Outlook Folders using VBA was last modified: February 8th, 2018 by Diane Poremsky
  • Macro to Move or Copy an Outlook message to another folder
  • Moving Deleted Items
  • Macro to automate the Move to Folder command
  • Macro to Move Aged Email Messages
  1. Chris Burnham says
    July 11, 2020 at 5:38 pm
    Hello Diane! It's been many years since we last spoke! I hope you are doing well.
    I happened to find your macro after pulling the same bone-headed mistake as many of us and accidentally deleting a large number of folders and I'd like restore the folders as well as the original contents from the Deleted Items to a mail folder of my choosing. Will this macro, as written do that? Or will it require a bit of modification? It's been so long since I've done VBA especially since PowerShell has come along, so I am rusty to say the least. However, if I can confirm this will do what I'm seeking out of the box, then this is my solution.
    Of course I'll test it before running it on everything in the entire folder once again, but I'm a bit gun-shy to run another macro, especially on Deleted Items and lose everything entirely. Thank you!
  2. Alfred says
    June 19, 2020 at 10:44 am
    Hello Diane.
    I hope that all is well with you in these trying times. First of I must say that I enjoy this site very much. I am constantly on here learning to script/code.
    I would like some help in creating a VB Script for Outlook similar to what you have above. Basically, I would like to have a script that will move folders from my outlook mailbox into my personal archive folder (Online Archive) within my Outlook to free up space in my mailbox. Any help will greatly be appreciated
  3. Bob says
    February 1, 2018 at 2:15 am
    is there an example of moving the currently selected folder to a PST?
      February 9, 2018 at 10:39 pm
      I have a sample here:
      https://www.slipstick.com/developer/code-samples/move-outlook-folders-vba/
Latest EMO: Vol. 31 Issue 5
