The problem: You're receiving email notifications for multiple Yammer groups but it's difficult to know which messages are from the groups that are more important to you. The only clue is the text at the end of the message: "You received this email because you're subscribed to the {group name} group." but you need to view each message to see it.
You could create rules to look for the group name, but you'd need to update the rules as you joined groups, plus rules are funky with Yammer messages. If you use Office 365's Clutter feature, the Yammer messages can be removed from the Inbox, reducing the need for rules, but it's still difficult to know which group a message belongs to prior to reading the last line.
The solution: An ItemAdd macro that watches the folder for new messages. If the message is from Yammer, it looks for the group name and assigns it as the category. Because the macro uses RegEx to find the group name, you won't need to update the macro if you join new groups. (You'll need to add the group to the Master Category list if you want the category to display a color.)
If the messages are in a secondary account, you'll need the GetFolderPath function.
This macro uses RegEx to get the group name. You'll need to select Microsoft VBScript Regular Expressions 5.5 in the VB Editor's Tools, References.
This macro can be converted use with a run a script rule or to work with messages from similar services. To use in a run a script rule change the macro name from
Private Sub InboxItems_ItemAdd(ByVal Item As Object) to
Sub ContactCategories(Item As MailItem)
Updated March 10 2015: the original macro wasn't running on all of the messages, especially when a large number came in at once. I split the macro into two macros, one watching the folder and the second doing the categorizing. It's no longer skipping messages. This also allowed me to watch a folder in another mailbox and reuse the categorizing code.
Option Explicit
Private WithEvents InboxItems As Items
Dim fClutter As Outlook.Folder
Public olApp As New Outlook.Application
Set oExpl = Application.ActiveExplorer
bDiscardEvents = False
Dim objNS As NameSpace
Set objNS = Application.Session
' instantiate objects declared WithEvents
'if the messages are in the default Inbox, use this line.
Set InboxItems = objNS.GetDefaultFolder(olFolderInbox).Items
' My messages are in a secondary account
' Set fClutter = GetFolderPath("display-name\Clutter")
' Set InboxItems = fClutter.Items
Set objNS = Nothing
If InStr(LCase(Item.SenderEmailAddress), "yammer") > 0 Then
YammerCategories Item
Private Sub YammerCategories(ByVal Item As Object)
Dim yamCats As String
Dim i 'As Variant
Dim Reg1 As RegExp
Dim M1 As MatchCollection
Dim M As Match
Set Reg1 = New RegExp
For i = 1 To 2
With Reg1
Select Case i
Case 1
.Pattern = "You received this email because you're subscribed to the (.*) group"
.Global = True
Case 2
.Pattern = "to (.*) group on the"
.Global = True
If Reg1.Test(Item.Body) Then
Set M1 = Reg1.Execute(Item.Body)
For Each M In M1
yamCats = M.SubMatches(0)
Debug.Print yamCats
Next i
If yamCats = "" Then yamCats = "Yammer"
Item.Categories = yamCats
Item.Save
End SubRun the macro on existing messages
The macro above runs on messages as they are added to a folder. If you have messages from Yammer in that folder you can use this macro to run each message through the ItemAdd macro.
Paste it at the end of ThisOutlookSession, select the folder where the Yammer messages are and run it. You should only need to use this macro once.
' Run the ItemAdd macro manually on messages already in the selected folder.
Public Sub ContactCategoriesManual()
Dim objOutlookItem As Object
Dim objItems As Outlook.Items
Dim objFolder As Outlook.MAPIFolder
Dim obj As Object
Set objOL = Outlook.Application
Set objFolder = objOL.ActiveExplorer.CurrentFolder
Set objItems = objFolder.Items
For Each obj In objItems
If TypeOf obj Is Outlook.MailItem Then
InboxItems_ItemAdd obj
Set obj = Nothing
Set objOutlookItem = Nothing
Set objItems = Nothing
Set objFolder = Nothing
Set objOL = Nothing
How to use this macro
- Expand Project1 and double click on ThisOutlookSession.
- Copy then paste the macro into ThisOutlookSession. (Click within the code, Select All using Ctrl+A, Ctrl+C to copy, Ctrl+V to paste.)
- To trigger the macro without restarting Outlook, click in Application_Startup then click Run.
Leave a Reply
