Accept or decline a meeting request then forward or copy it
› Developer › Accept or decline a meeting request then forward or copy it
Last reviewed on November 16, 2014     48 Comments
I had two questions this week that were similar. In one, the user wanted to decline a meeting but keep a copy of the appointment, the other user wanted to forward accepted meeting to another mailbox.
While these requests don't sound all that similar, the same basic VBA code can be used for both. With one request, we need to copy the fields to a new appointment then decline the meeting, the other one is forwarded then accepted. You can use the basics of these macros to do other things with incoming meeting requests.
Both macros need the GetCurrentItem function listed at the end of this page. This allows you to either select a meeting request in the message list in your inbox or open it to accept or decline.
Rather than using the Accept or Decline buttons, you need to use the macro to accept or decline the meeting then "do whatever". You can add the macro to a button on your QAT, ribbon, or toolbar.
Add a button to the riubbon to run a macro
Accept and Forward a Meeting
Don't forget to also add the GetCurrentItem (at the end of this page) to Outlook's VBA editor.
Sub AcceptandForward()
Dim oAppt As MeetingItem
Dim cAppt As AppointmentItem
Dim oRequest As MeetingItem
Dim oResponse
Set cAppt = GetCurrentItem.GetAssociatedAppointment(True)
Set oRequest = GetCurrentItem()
Set oAppt = oRequest.Forward
oAppt.Recipients.Add "alias@domain.com"
oAppt.Send
Set oResponse = cAppt.Respond(olMeetingAccepted, True)
oResponse.Send
Set cAppt = Nothing
Set oAppt = Nothing
Set oRequest = Nothing
Decline and keep a copy of the meeting
Sub SaveAndDecline()
Dim oAppt As AppointmentItem
Dim oResponse
Set oAppt = Application.CreateItem(olAppointmentItem)
With oAppt
    .Subject = "Declined: " & cAppt.Subject
    .Start = cAppt.Start
    .Duration = cAppt.Duration
    .Location = cAppt.Location
    .Save
Set oResponse = cAppt.Respond(olMeetingDeclined, True)
oResponse.Send
Set cAppt = Nothing
Set oAppt = Nothing
Accept and Move the Invite
When you accept a meeting, the invitation is moved to the deleted items folder. Moving it to another folder is just 4 added lines. Use the macro at the top of the page and add these lines, with oRequest.Move after the Send (or Display) line.
The folder needs to exist at the same level as the Inbox. If you want to move it to subfolder, use Session.GetDefaultFolder(olFolderInbox).Folders("SharedCal"); to use a folder outside of the current data file, see Working with VBA and non-default Outlook Folders.
' add to top section
Dim myFolder As Outlook.folder
' add after Dim section
Set myFolder = Session.GetDefaultFolder(olFolderInbox).Parent.Folders("Accepted Invites")
oResponse.Send
oRequest.Move myFolder
'last line before end sub
Set myFolder = Nothing
Accept and Forward a Copy to Another Address
When Exchange server users forward a meeting request, the organizer may be notified the meeting was forwarded. The organizer or administrator can disable this feature, but if you aren't sure if it's disabled and want to avoid generating the notification, you can use a macro to generate a new meeting request and forward it to the address.
This should only be used to forward meetings to your personal account, not to forward the meeting information to other users.
Sub AcceptAndForward()
Dim meAttendee As Outlook.Recipient
Dim oResponse
With oAppt
    .MeetingStatus = olMeeting
    .Subject = "Accepted: " & cAppt.Subject
    Set meAttendee = .Recipients.Add("me@mydomain.com")
     meAttendee.Type = olRequired
    .Send
oResponse.Send
Set cAppt = Nothing
Set oAppt = Nothing
GetCurrentItem Function
With either of these macros (and many others on this site), you need to use the GetCurrentItem function if you want to use the macro with either opened items or selected items. You only need to have this once within your VBA project and can use it with as many macros as you want.
    Set objApp = Application
        Case "Explorer"
        Case "Inspector"
    Set objApp = Nothing
End Function
How to add the macro to Outlook and create a toolbar button
Note: you'll also need to open a meeting request and add a button to it, if you want the macro easily accessible from an opened message.
Accept or decline a meeting request then forward or copy it was last modified: November 16th, 2014 by Diane Poremsky
  • This macro copies a meeting request to an appointment. Why would you w
    Copy meeting details to an Outlook appointment
  • set a reminder using a rule
    Set a reminder when accepting a meeting request
  • Keep Canceled Meetings on Outlook's Calendar
  • Autoaccept a Meeting Request using Rules
  1. dronics says
    February 28, 2020 at 12:32 pm
    I'm trying to use the "Accept and Forward a Copy to Another Address" on Outlook 2016 and it seems to work with my gmail account. Only thing is that it doesn't delete the meeting invite in my inbox like the normal "Accept" does.
    I know that you answered someone with a similar issue in the comments but I think this was back in 2015/2016.
    Could you let me know what needs to be done to the "Accept and Forward a Copy to Another Address" vba to delete the meeting invite please?
  2. Marion says
    April 24, 2018 at 11:30 am
    Could it be that it doesn't work with MS Office Professional Plus 2013 in combination with exchange server? I get an error message. It says: "The operation failed. The message interfaces have returned an unknown error. Cannot resolve recipient" When I debug I see a yellow arrow at the line .Send
      April 24, 2018 at 12:51 pm
      it works with exchange - at least in cached mode. Are you using classic online or cached?
      I'll see if i can repro that error - it sounds like it is not connecting to the address book.
      • Marion says
        April 28, 2018 at 12:56 pm
        I guess I use the cached one. In the company we use outlook from the Office package. It is installed on all the laptops.
      April 24, 2018 at 12:54 pm
      Which macro are you using?
      Does the address its being sent to have single quotes or other characters around the email address?
      • Marion says
        April 28, 2018 at 1:02 pm
        I used the Sub AcceptandForward()
        And I replaced alias@domain.com for my mailaddress
      • Marion says
        April 28, 2018 at 2:04 pm
        I have used Accept and Forward a Copy to Another Address. The macro runs without problems if I cut and paste the text from the macro as it is on this page (with the address "me@mydomain.com"). It is when I replace the me@mydomain.com mail address for my own outlook.com or gmail.com address when the error occurs.
        April 29, 2018 at 12:45 pm
        What is the error message?
      • Marion says
        April 29, 2018 at 5:50 am
        I have tried a few things. The macro works fine when I leave out the dot between my first name and last name in the first part of the email address. So "firstnamelastname@....." works fine, but "firstname.lstname....." doesn't. Unfortunately, my mail address is the one with the dot in it. Also, when the macro has run, the invitation email is still in the inbox.
        April 29, 2018 at 11:00 pm
        So this line: oAppt.Recipients.Add "alias@domain.com"
        when the alias had a got in it, fails?
        oAppt.Recipients.Add "al.ias@domain.com"
        There is no reason why it shouldn't work as long as the address is in quotes but I will see if i can repro.
  3. KLE says
    July 11, 2017 at 4:16 am
    GetCurrentItem only seems to work with selected meeting invite (email) item and not with a selected meeting item in calendar view. How could this be achieved?
      July 15, 2017 at 8:19 am
      Set cAppt = GetCurrentItem.GetAssociatedAppointment(True) is looking for the appointment associated with the appointment, not the appointment itself. Application.ActiveExplorer.Selection.Item(1) applies to the selected item.
      FWIW, it's recommended to accept or decline from the email, not from your calendar - accepting from the calendar doesn't delete the matching email.
  4. Nick says
    May 18, 2017 at 5:40 pm
    I am using Script 3 to Accept the appointment to my Calendar and then send a
    copy to a shared team calendar. The original MeetingItem is left in my inbox.
    I attempted to use the oRequest.Delete line but I don't believe oRequest is
    defined in that example.
    I am a total noob at this and am learning a lot through this site and googling but
    I have reached the point where I am just guessing now.
    Dim oResponse
    Dim oRequest As Outlook.MeetingItem
    With oAppt
    .Subject = cAppt.Subject
    Set meAttendee = .Recipients.Add("email address removed")
    .Send
    oResponse.Send
    Set oRequest = MeetingItem.Delete(olMeetingAccepted, True)
    oRequest.Delete
    Set cAppt = Nothing
    Set oAppt = Nothing
      May 24, 2017 at 4:56 pm
      At the top, either right before or right after Set cAppt, add this line:
      (and use the GetCurrentItem function)
  5. GA Nielsen says
    April 28, 2016 at 2:18 pm
    The Accept and Forward Copy is working for me but it creates a duplicate appointment. How do I prevent this from happening?
  6. Guillaume de Fombelle says
    August 11, 2015 at 9:07 am
    Thanks for the code for declining and saving!
    What would be the line to be added, for the status to show as available?
    I tried .MeetingStatus = 1 and others without success
    Note: I also added .ReminderSet = False which seems to make sense
  7. adsa says
    March 3, 2015 at 9:58 pm
    Keep getting an error run time error 438 : object doesn't support property or method
  8. brandonrsullivan says
    January 7, 2015 at 10:54 am
    Little help with a tweak, please.
    I want to decline a meeting but be able to easily change the response later. I tried Save & Decline, but it creates a copy. Can I Decline and Save the original to my Calendar as Free?
    As my schedule changes, this would allow me to easily change my response from the event and inform the organizer of my change in status.
      January 8, 2015 at 12:48 pm
      I am not aware of any way that will allow you to decline and keep the cancelled appointment, sorry. Tentative was intended for situations like this where you aren't sure if you can attend.
      • brandonrsullivan says
        January 8, 2015 at 1:28 pm
        Thank you so much for the quick reply. The scenario is not quite as you mention, however. Frequently I decline meetings I have already accepted because a more important event is created. This more important event is then canceled and I want to rejoin the original meeting. It is never tentative at all, you see.
        However, in terms of "logic" what I would like to do is to suppress the deletion of an event not from the invite, but from the appointment itself. So would it be possible to create a Macro that would send the decline message to the organizer, but not perform the delete activity? If this is possible, then I'd add in the script to set Free/Busy as "Free".
        Does that clarify or add any thoughts on possibilities?
        Thank you so much.
        Brandon
  9. Aaron B. says
    November 5, 2014 at 3:41 pm
    I'm looking to use these scripts to forward to an external email account (my gmail account) and have it not inform the organizer of the forward as I am only doing this get it on my gmail calendar, does this method work in that scenario?
      November 16, 2014 at 1:17 pm
      The accept and forward one should trigger the notification. The decline and save would not - I'll get the code to forward the appt instead of saving it.
        November 16, 2014 at 1:45 pm
        Ok... new version of macro is near the end of the article.
  10. Colton Spe says
    October 14, 2014 at 2:47 pm
    When I try to add multiple recipients to the Forward it fails. For example:
    oAppt.Recipients.Add "email1;email2;email3,etc"
    Any ideas? Thanks in advance
      October 14, 2014 at 11:16 pm
      Try using oAppt.To "email1;email2;etc"
  11. Curt Faulk says
    September 16, 2014 at 12:55 pm
    Diane:
    As usual, you devise the most interesting and useful code for your fan base. (Yes, we EXIST!)
    What code would be inserted to remove the "FW:" in the Subject to keep that text from appearing in the Calendar entry on the target calendar?
      September 16, 2014 at 1:21 pm
      something like there, where 4 = the # of characters before the subject ("FW: ")
      oAppt.subject = right(oappt.subject, len(oappt.subject - 4))
  12. Chris says
    September 12, 2014 at 4:21 am
    Thanks you so much for this!
    It forwards the email beautifully to another email, however it doesn't delete the invite as it would with a normal acceptance (I'm using Outlook 2010).
    Can you help with this?
    Many thanks,
    Chris
      September 16, 2014 at 10:37 pm
      At the end, try oRequest.delete (for the first macro)
  13. Gary Ricks says
    July 3, 2014 at 9:49 am
    Diane - thanks so much for all of the excellent code here - makes my job easier every day! Question on meeting acceptance notifications - how do we find those and move those?
      July 7, 2014 at 11:32 am
      I assume you mean responses you get back. If you just want to move them, you can configure it in File, Options (it's under tracking options). Rules can also do it - look for the message class of IPM.SCHEDULE.MEETING.RESP.POS and do something.
  14. TJ says
    March 20, 2014 at 10:41 am
    I was searching for this a long time. Looks great and seems to work, poorly I have to work with Outlook 2003. Is there a way to adopt this skript?
      March 20, 2014 at 2:15 pm
      It should work with 2003 too (and older) - it doesn't have anything that is special to the newer versions.
  15. Andy says
    January 16, 2014 at 12:02 pm
    LOVE LOVE LOVE these macros! (Also the one to generate an e-mail to all who haven't responded to a meeting notice!)
    In Outlook 2010, when I run the macro for Decline and Save, the Meeting Notice still shows in my Inbox.
    Is there a way that I can get this to go away, as well? Right now, after using the Macro, I have to again Decline the meeting and then it will be gone from my Inbox.
    Any help would be very much appreciated!
      February 21, 2014 at 11:22 pm
      You need to use oRequest.Delete or .Delete if using a With/End with block.
  16. dstarmerd S says
    November 16, 2013 at 2:45 pm
    When I save and decline, the status still stays "busy". How would I change it as part of the macro to "free"?
      November 17, 2013 at 6:28 am
      You need to set the buy status on the associated appt. Then save it.
      cAppt.busystatus = olfree
      cAppt.save
  17. Frohberg says
    April 18, 2013 at 9:51 am
    Here is what I came up with. It seems to work, though I'm not that much of a pro.
    Sub Delete_All_Declined()
    Dim oOL As New Outlook.Application
    Dim oNS As Outlook.NameSpace
    Dim objItem As Outlook.AppointmentItem
    Set oOL = CreateObject("Outlook.Application")
    Set oNS = oOL.GetNamespace("MAPI")
    Set oAppointments = oNS.GetDefaultFolder(olFolderCalendar)
    For Each objItem In oAppointments.Items
    x = 1
    Do Until x > objItem.Recipients.Count
    ' 0 = no response, 2 = tentative, 3 = accepted, 4 = declined,
    If objItem.Recipients(x).MeetingResponseStatus = 4 Then
    If objItem.Recipients(x) objItem.Organizer Then
    objItem.Recipients(x).Delete
    x = x - 1
    objItem.Save
    x = x + 1
    Loop
    MsgBox "Done"
    Set oAppointmentItem = Nothing
    Set oAppointments = Nothing
    Set oNS = Nothing
    Set oOL = Nothing
    Set objItem = Nothing
    I would thank you very much for input (mistakes or optimization).
    Best
    J. Frohberg
      April 18, 2013 at 12:14 pm
      I'll test it this afternoon but it looks perfect. Thanks for sharing.
  18. Frohberg says
    April 8, 2013 at 12:47 am
    I wanted to ask you if it is possible to use the structure of these macros for following idea. I want to delete all participants of a meeting who declined the invitation from the list of participants.
    Background: We use Exports to excel to monitor the status of our meetings and number of attendees. Unfortunately, the information whether someone declined or accepted a meeting request is not represented in Excel exports thus making it impossible in Excel to tell how many participants really will come to a meeting (or am I mistaken?).
    If it is not possible to do it at once, maybe it's possible to open a relevant meeting as soon as an email arrives which declines the meeting and remove the senders address from the list of participants?
    Thank you very much for your help
    Best J. Frohberg
      April 15, 2013 at 5:06 pm
      It should be possible but I don't have any code samples handy that do it. I'll have to see what i can come up with.
  19. Marco says
    February 15, 2013 at 7:00 am
    I am trying to do something similar, but am a little stuck:
    I would like to forward meeting requests I accept to another e-mail address.
    Normally I would use a simple outlook rule for this. However, before forwarding the accepted meetings, I would like to strip the body and any attachments, in effect only forwarding subject and location of the meeting. Do you know how to do this?
      February 15, 2013 at 2:05 pm
      Two choices: create an email with the fields you want. Code sample here -
      https://www.slipstick.com/outlook-developer/forward-meeting-details-to-another-address/
      or something like this for the body -
      oappt.body = ""
      oAppt.Send
      Because the attachments should be embedded, removing the body might remove the attachments. If not, you'll need something like this
      (from https://www.slipstick.com/outlook-developer/remove-attachments-from-sent-messages/)
      Dim lngAttachmentCount As Long
      Set myAttachments = myItem.Attachments
      lngAttachmentCount = myAttachments.Count
      While lngAttachmentCount > 0
      myAttachments(1).Delete
      Wend
  20. HarleyDavis says
    February 10, 2013 at 8:50 pm
    If it is a Resource mailbox and you are also rebuilding an entire set of calendar folders for different users? No, a forward won't work. That would require grabbing each set of resource bookings for each person, then forwarding for each room, and do it again for each person for each room... And so on. With 17-30 users and 35 rooms? That could end up being worse than trying to send each one individually.
    I just want to input all the events for each user on their new, clean calendar (all events are meetings with resources only), and activate a single send for all of the events. A For Each loop looks right, but I haven't been able to get any scripts to work.
    Example Algorithm:
    For Each appointment in Default Calendar folder
    Select appointmentType
    Case "Meeting Item"
    apt.send()
    Case "Appointment Item"
    apt.save()
  21. Harley Davis says
    December 7, 2012 at 3:55 pm
    Great stuff. I might just try and tweak it a little. I need to send selected meeting requests, not forward, SEND as they are (as if updating them), and there are thousands. The come from a recovered set, and they are all functional on my calendar, but I need them to send to their recipients. We had to rebuild, so many of our boxes were completely lost, including some resource boxes. However, most of our main boxes were backed up, along with a list of all the boxes, and recovered. I just need it to be able to send all meeting requests again. I know the user-recipients will get them again, but they should only get an update if their copy is as intact as mine, and only the resource boxes we lost will respond back. I can sort that out later.
      December 7, 2012 at 7:48 pm
      If only the one mailbox is missing the meetings, you can forward the meeting to that address - forwarding has the same affect as resending.
  22. Don Chairez says
    December 6, 2012 at 1:38 pm
    Thank you. I am always confused by Outlook. Superb advice.
    • Johan says
      May 20, 2016 at 4:34 am
      Thanks! Very helpful.
Latest EMO: Vol. 31 Issue 5
