Pick Contacts using VBA
› Developer › Pick Contacts using VBA
Last reviewed on April 6, 2016     5 Comments
Use the following VBA code to create a contact picker to link contacts to tasks. You can change the code to allow for a manual pick of contacts folder, ie not hardcoded. If you have contacts stored in another folder, this change will make it easier to use.
Open Outlook's Folder Picker
To use a folder picker with other macros, use this code snippet to bring up the dialog:
Dim objApp As Application
Dim objNS As NameSpace
Dim objFolder As MAPIFolder
Set objApp = CreateObject("Outlook.Application")
Set objNS = objApp.GetNamespace("MAPI")
Set objFolder = objNS.PickFolder
Reconnect Links Macro
Sub ReconnectLinks()
  Dim colItems As Items
  Dim objItem As Object
  Dim colLinks As Links
  Dim objLink As Link
  Dim colContacts As Items
  Dim objContact As ContactItem
  Dim strFind As String
  Dim intCount As Integer
  Dim myFolder1 As MAPIFolder
  'set contacts folder
  Set myFolder1 = objNS.PickFolder
  'set tasks folder
  If TypeName(objFolder) <> "Nothing" Then
    'Set colContacts = objNS.GetDefaultFolder(olFolderContacts).Items
    Set colContacts = myFolder1.Items
    Set colItems = objFolder.Items
    For Each objItem In colItems
      Set colLinks = objItem.Links
      intCount = colLinks.Count
      If intCount > 0 Then
        For i = intCount To 1 Step -1
          Set objLink = colLinks.Item(i)
          If objLink.Item Is Nothing Then
            strFind = "[FullName] = " & AddQuotes(objLink.Name)
            Set objContact = colContacts.Find(strFind)
            If Not objContact Is Nothing Then
            ' remove the old link
            colLinks.Remove i
            ' add the replacement link
            colLinks.Add objContact
        If Not objItem.Saved Then
          objItem.Save
  Set objLink = Nothing
  Set colLinks = Nothing
  Set objItem = Nothing
  Set objItems = Nothing
  Set objFolder = Nothing
  Set objNS = Nothing
    Set objApp = Nothing
Private Function AddQuotes(MyText) As String
    AddQuotes = Chr(34) & MyText & Chr(34)
End Function
Pick Contacts using VBA was last modified: April 6th, 2016 by Diane Poremsky
  • To automatically add recipients to Contacts in Outlook using VBA
  • Choosing the Folder to Save a Sent Message In
  • Working with All Items in a Folder or Selected Items
  • Macro to Move or Copy an Outlook message to another folder
Subscribe
Notify of
5 Comments
newest
oldest most voted
Inline Feedbacks
View all comments
Jay
November 18, 2023 1:22 am
I am use VBA to open word document, however ActiveDocument was not show.
0
0
DoraK
September 6, 2016 3:46 am
hi Diane,
could you please assist?
I would like to link my contacts with their emails and see the emails within contact's form.
(I use a custom form for my contacts, called: "0A-Contacts-text", which is stored into:"outlook:\\ΕΠΑΦΕΣ 1 ΦΕΒ 2015\*0 ΕΠΑΦΕΣ-new ALL.)".
In this form i have put a nickname for each one contact, which matches with a custom field named: "PERSON" in each one email, into the folder: "outlook:\\**007-LIVESTOCK-final\*NEW-all in one folder"
0
0
Author
Reply to  DoraK
January 19, 2017 3:47 pm
If you use 2010 or up, enabling the people pane might be easier - it will show mssages to/from the contact in a small pane at the bottom of the contact, similar to the old Activites feature. Otherwise, you need to use find or restrict to look them up. The old Outlook view control might work too.
0
0
Claud
April 15, 2013 3:20 am
Due to the problems with Links in 2013 will this solution work in office 2013?
0
0
Reply to  Claud
April 15, 2013 6:27 am
I haven't tested it yet, but I am assuming that it won't.
0
0
Latest EMO: Vol. 30 Issue 29
  • New Outlook: Show To, CC, BCC in Replies
  • Insert Word Document into Email using VBA
  • Delete Empty Folders using PowerShell
  • Warn Before Deleting a Contact
wpDiscuz
Never see this message again.
Move Comment
